Member # 50628
Aggie007 - Drive Over Fenders
I started widening my trailer and building driver over fenders today. I just bought a bender and the bend-tech software and needed a project to get me familiar with the new tools before I start the chassis. I plan to cover the top with 3/16" plate.
Member # 17632
Why so much clearance between the top of the tire and the tube? There can't be that much travel in your suspension. I'd lower them down as close as I could before they hit. My stock fenders are only about 2" above the tires on my trailer.
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s 91.5 Dodge 6BT 5 spd tow rig |
Member # 50628
There is 3.75" of space between the top of the tire and the bottom of the DOM. The springs are under the axle so the trailer sits lower than normal, the previous owner used to tow race cars with it. There is 3" between the frame and the top of the axle, so I made the fenders a tad taller incase I messed up my bends, but they came out as planned. The top of the fenders to the deck will be 14" tall, and the slope is 45deg so I wouldn't imagine any vehicle that wide will have any problems driving over the fenders. Is there real gains by lowering the fenders? I don't want to rework what I started, but if I will benefit from it then I will.
Member # 119312
harder to pull a dead vehicle over the fenders being that there taller and also if you ever have to tow a car mostly the door wont clear the fenders when you try to open it...just my 2 cents
edit: looks like you might be able to just shorten the ends and move it down with out scrapping the tube you've already bent Last edited by Ranger5.0L; 03-07-2012 at 05:39 AM. |
Member # 26472
I built something similar on my flatbed.
![]() Build details here; http://www.cj-8.com/forum/showthread.php?t=23039
'84 Bobbed -8, LT-1, TH400, STaK 3 speed, front 60 with Detroit/35 spline shafts, rear 14 bolt with detroit, garage built rear four link, front radius arm, 42" TSLs on locked Racelines, PSC assist, WARN 8274, lots of plating. '82 -'8 As stock as it gets... |
Member # 68839
Looks pretty good to me. You could lower them an inch or two but in the end, I don't think it makes a big difference for functionality. As for pulling a dead rig on it, you're still pulling it at the same angle of approach. The only difference is another couple inches of height. I don't see any issues with it. You will probably have a winch at the front of the trailer anyway. It seems like more of a cosmetic difference than anything else IMO.
'79 F250, Rocks, 460, NP205, T18 and PSC 4-Wheel Steering '99 F250, PSD, Rocks, BTS Tranny and PSC Hyd Ram Assist Steering Project Sarge build thread: http://pirate4x4.com/forum/showthread.php?t=777450 |
hate keeps me warm
Member # 151139
Looks good.
Any idea of how much weight you are adding to the trailer with the pipe and 3/8 plate?
There ain't no good in an evil-hearted woman And I ain't cut out to be no Jesse James And you don't go writing hot checks down in Mississippi And there ain't no good chain gang |
White Trash Fab
Its seems like 1/8" plate would be more than strong enough.
"If you are gonna live life on the edge you better have good balance" 06 Tundra DC The "Trifecta" 3 seat yota buggy ![]() http://pirate4x4.com/forum/showthread.php?t=1027210 http://www.AddictedOffroad.com/ www.ruffstuffspecialties.com http://f-o-a.com |
#13 (permalink) |
one handed mechanic
Member # 119289
the fenders on my 12k skid steer trailer are just 1/8" diamond plate, rolled on the edge to form a lip; no "structural" tube of any kind. i transport farm tractors all the time with one, or both rear wheels right up on the fenders. ive never had an issue, nor do the fenders show any sign of damage/wear/beds.
[i got nothin' |
#14 (permalink) |
Member # 83837
Mine are the same way - while these builds are well done, I think they are seriously overkill. I've driven all sorts of shit on these fenders and nothing moves- ![]()
74' Bronco - Mustang Injected 5.8 - 105:1- Locked D60/70HD - NP435 -Atlas2 3.8 - PSC Full Hydro - 5.5" lift - Cage Arms - 37" Cut & Grooved Boggers Bronco Build Thread |
#15 (permalink) | |
Member # 50628
I have the exact number on my computer at home and will post it up.
Here is some updated pics. I ended up using 1/8in plate to cover the tubing, diamond over the fenders and smooth everywhere else. I welded on a receiver hitch so I can add a removeable winch later on and I stripped the trailer so I can take it to get it galvanized. ![]() ![]() ![]()
#16 (permalink) |
White Trash Fab
I think you just added 20lbs of weld to the trailer, nice work.
#19 (permalink) |
Member # 29868
Nice job, I just picked up a used 10K bumper-pull last winter and have plans to do something similar. Just went to Moab and my trailer is trashed. Had a last minute funeral and didn't get to repacking wheel bearings and a drunk friend "helping" me load and it now needs some love. I like what you did.
1996 Tacoma V6 5spd, duals, Dana 60, 14 bolt, 5:38's, 42" Iroks, exo-cage 1997 Dodge Cummins 5spd 4x4, 79 Dana 60 under leafs, Dana 80, 4:10s, 37's /forum/tow-rigs-trailers/850288-1997-dodge-cummins-towho-expo.html |
#20 (permalink) | |
Member # 50628
Total weight added was: 103lbs in tube plus 169lbs in plate plus 10lbs of welding wire...so roughly I added 282lbs to the trailer. Thanks for the compliments! |
#21 (permalink) |
Awesome Fab Tools
Member # 84883
Nice. Clean job abd you will have a little better traction from the diamond plate in case it's wet/muddy. Nothing like dropping your axle on your own trailer.
ROGUE FABRICATION -Portland, OR Air/Hydraulic Tubing Bender $580 with 180 Degree Dies Drill Press Reduction Kits $119 Shipped Joe@RogueFab.com www.RogueFab.com |
#22 (permalink) |
Member # 43251
Great job and you can never have too much overkill on these narrow trailers and whimpy stock fenders, now a tractor or dually or 20 winch wide tractor tired 4x4 can fit with no prob especially at night or with muddy wheels, great job!!!
#23 (permalink) |
Dynomite!
Member # 86280
Looks good, but you really need to learn how stitch welding works. Fully welding all that sheet metal is beyond over kill.
Yota Offroad #99 Co-Driver Thanks to our Sponsors: Down South Motor Sports, Barnes 4wd, Chassis by Tommy Glenn, Carolina Driveline, Griffin, Raceline, Maxxis, Detroit Locker, Stak 4x4, K&N Filters 86' 4runner Build |
#24 (permalink) | |
Member # 50628
Also since I am galvanizing the trailer, I was advised to fully weld all seams by a local trailer manufacturer. http://www.galvanizeit.org/about-hot...alvanizing/faq "29. If I stitch-weld, will there be uncoated areas after galvanizing? When stitch-welding is used, there is a possibility of gas release between gaps, which will prevent the galvanized coating from forming in these areas. By leaving at least a 3/32” (2.4 mm) gap between the contacting surfaces, gases are allowed to escape and cleaning solutions and molten zinc are allowed to flow in between the surfaces for a complete and uniform coating." Last edited by Aggie007; 05-03-2012 at 05:56 AM. |
#25 (permalink) |
Member # 50628
Finally had an opportunity to pick up the trailer this past week. I am very pleased with how it turned out. It was a little more than I expected but at least I won't have to mess with it for a while. I went ahead and put new lights, wiring and new brakes on the axles. I am going to reuse the old wood I have and replace it next year or the year after.
