Member # 106178
Superduty D50 tech
So today I sheared the front pinion on my 2000 F250, 7.3L 35's and 3.73 gears. I assume the abuse I have put it through weakened it and today just wasn't its day, I gave it a little throttle up a rock and it popped and the drive shaft hit the ground
![]() How do I keep it from happening again? Will a lower gear ratio help prevent it or do I need to look at swapping in a 60? And no, I don't want to quit wheeling my Superduty.
Member # 4243
I'd put in the 60. Housing, r&p, carrier, and inner shafts. You can recycle your outers since they are the same anyways.
90-93 CTD jalopies |
Member # 106178
Would just going to 4.56 gears prevent this failure from happening by relieving stress on the pinion or would it not help that much?
Member # 140580
I have seen this alot, I would suggest going to a 60...
1996 DODGE 2500, 4X4, CUMMINS, 370'S, 5GSK, MACK PLUG, STUDS, SFI FLEX PLATE, DERALE DEEP PAN, EMS HUB KIT WITH 35 SPLINE INNER AND OUTTER MOSER AXLES, WARN GOLD LOCK-OUTS, 3 IN. LEVELING KIT, DUAL EDELBROCK REMOTE RESERVOIR SHOCKS, ROUGH COUNTRY STEERING STABILIZER, STEERING BOX BRACE.
