couple trailer building questions - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-02-2012, 08:53 PM   #1 (permalink)
Member # 212108
im looking into rebuilding my current trailer and have been running into a couple questions.
which would be a stronger/better material to build with? 6''x1/4'' web channel iron or 2''x6''x1/4'' wall boxed steel?
and the biggest one, where should i place the axles? it will have a 22' deck (20' useable and 2' for storage box)
car66 is offline   Reply With Quote Quick reply to this message
Old 04-02-2012, 09:01 PM   #2 (permalink)
Member # 119827
lol
use the search button my friend
... this has been covered extensively
c -channel has lower torsional stiffness ... but boxtubing may rusts from the inside out
i prefer to build with box tubing ... but i live in rustfree AZ
"Steels gonna be the death of me" ... Gangstergrass
RoosterBooster is offline   Reply With Quote Quick reply to this message
Old 04-02-2012, 09:48 PM   #3 (permalink)
Member # 212108
sorry, new here. i live in northwest washington so it would probably rust like crazy up here lol.
Old 04-03-2012, 06:38 AM   #4 (permalink)
cj7jeep81's Avatar
Member # 15718
i'd go with c-channel as well, and the middle of the axles should be 60% of the distance. so for a 22' deck, you should have the center line (in between both axles), about 13' back.
cj7jeep81 is offline   Reply With Quote Quick reply to this message
Old 04-03-2012, 10:51 AM   #5 (permalink)
370
Member # 153116
don't you wanna be 60% of the distance from the coupler to the rear of the deck? not 60% of the length of the deck?
370 is offline   Reply With Quote Quick reply to this message
Old 04-03-2012, 02:04 PM   #6 (permalink)
Member # 212108
i read online, might have been on here, that the axles should be at the 40/60 split. i just dont know if it should be 60% of the deck or the total trailer?
Old 04-04-2012, 06:05 AM   #7 (permalink)
cj7jeep81's Avatar
Member # 15718
pretty sure its 60/40 split of the deck itself, not including tongue.
http://www.trailerplans.com/index.ph...d=40&Itemid=29
Old 04-04-2012, 07:47 AM   #8 (permalink)
Member # 120550
I was just in same position of needing to rebuild 20' trailer to 22'-24' and beef it up a little. After planning what I'd need, it turned out to way cheaper to sell my current trailer and buy a bigger one. Going this route I went from 20' 7k car hauler to a 24' 14k deckover trailer for about $600. The rebuild would have been around $1200 plus supplies and my time.
jraoffroad is offline   Reply With Quote Quick reply to this message
Old 04-05-2012, 07:48 AM   #9 (permalink)
Member # 79578
An old timer who ran a trailer shop in the city years ago told us that the rule of thimb is:
"For every foot of deck, the center of the axles should be offset 1 inch to the rear." You don't count the tongue.
For example, an 18 foot trailer has a centerline at 9 ft. The axles should be offset to the rear 18". This puts the Center of the axles at 10.5 ft from the front of the deck. This is 58%, which is close enough to the 40/60 rule above.
Edit: Just read the link above. It says the same thing.
Please, Try My Product
sb406 is offline   Reply With Quote Quick reply to this message
Old 04-17-2012, 09:09 PM   #10 (permalink)
Member # 212108
awesome, thanks for the help guys. another question popped into the ole noggin the other day. does the way the channel iron is oriented make a difference is it just a personal preference? meaning flat side in or out.
