#51 (permalink) | |
Member # 106178
Yes and no there. Every truck has certain things that REALLY need done to it to help prevent problems. |
#52 (permalink) |
anyone wanna take a guess on how many different cooling hoses are on the new ford 6.7? i will tell you it has two radiators, a primary and secondary
tin benders 2002 2003 carnage champs [URL=http://www.tinbenders.org] [B]TIN BENDERS[/B][/URL] |
#53 (permalink) |
Marion Cobretti
Member # 40131
I have an '06 LBZ and love the truck. Even with the crew cab, space is at a premium with my wife and 3 toddlers. I recently developed a boost leak and the IFS is crap
Other than that, it's been a great truck and would only now wish I'd waited for a leather interior setup.
#54 (permalink) | |
Member # 139805
The "engine" cooling system does not have 2 radiators. The engine block is cooled by a single radiator. The "Secondary Cooling System" cools the charge air via a water to air exchanger, transmission oil, fuel and EGR. See page 303-03C. The secondary cooling system has 10 hoses counting the one labelled "hose assembly" as a single hose. The secondary cooling system does away with the need for an air to air intercooler. So total hose count on the "cooling system" is 19 hoses. And that does not include the lines to and from the transmission, nor the charge air hoses. It takes 126 pages in the shop manual to cover the 2 diesel cooling systems. If you want mind boggling, the front accessory drive on a 6.7 with dual "generators" has 11 pulleys ! 2 water pumps, 2 generators, 2 idlers, 1 tensioner, 1 crank, 1 power steering, 1 AC, 1 fan. The single generator engine has 10 pulleys. I cannot believe that people actually buy trucks with those engines ! And I like Ford trucks. Last edited by me2; 05-07-2012 at 11:45 PM. |
#55 (permalink) | ||
Member # 139805
If you add power to a truck with an Allison or if you mess with the shift programming, you can expect trouble. Quote:
The 6R140 is new to the scene, but seems even stronger than the 5R110. So strong in fact that the aftermarket has not seen the need to produce performance parts for it. The TC in it, for example is triple disk, from the factory. Part of the 6R140s longevity may be due to the fact that people aren't (yet) able to make a Ford 6.7 have the same sort of output that the For 6.4 could achieve. Nevertheless, people are having good results towing with tunes with the 6R140. Don't try that with most of the other auto transmissions out there. And lest you think you want a good ole manual transmission, the practical towing torque limit of street friendly (organic double disk) high performance clutches is about 800 ftlbs. After that you get into obscene pressure plate forces and metalic clutch linings that have some nasty side effects, like chattering when backing up a trailer and being prone to warping. And 800 ftlbs is about the limit anyway for the 1 3/8 input shafts in a towing application. That is why the FSO6405/6s and 8405/6s are available with 1 3/4 and 2" input shafts. Hope this helps. Last edited by me2; 05-07-2012 at 11:43 PM. |
#56 (permalink) | |
Marion Cobretti
Member # 40131
![]() And aren't the 6RwhateverTHEfuck going in for service quite frequently for service...electrical/ shifting issues?? ![]() Knock on wood, but have yet to limp my Allison....although yes it does happen.
#57 (permalink) | |
actually there are a total of 67 hoses on the new 6.7
#59 (permalink) | |
Member # 139805
The "shift flare" issue has nothing to do with the hard parts in the transmission. Ford will get the calibration issues worked out and I think the 6R140 will be a fine transmission. Its built like a tank. |
#60 (permalink) |
Member # 181244
id say get an obs 7.3 like 95 to 97. had mine for two years and it hauls everything i throw behind it! deffinitly not the fastest thing on the planet but it always gets myself and the load behind it to the destination and dont get me wrong it has no problem pulling its just no speed demon. you can usually get a decent one for under 10,000 and use the excess cash to change it how u want or throw into your trail rig. i personally added a chip to mine and swapped in a zf6 6spd manual and its been that way ever since.. they push 215 hp and 300 ft lbs not tooo bad for a older truck like that and mine dynoed with the chip on tow tune at 227hp and 395 ftlbs to the rear wheels.
this is my usual setup
Cool Meadows motor sports. [url]http://www.facebook.com/CoolMeadowsMotorpsorts[/url] |
#61 (permalink) |
Member # 193441
01 lb7 ex cab, short bed duramax
180K replaced a water pump, and a few other small things. 40hp tune 33s 18mpg towing. Great truck, just cost a little more to up keep than a gasser and since I only tow around 5K, I might be going back to a gas truck. |
#63 (permalink) | |
Member # 74825
Shit, our 06 has had almost $16k in motor work and the transmission has had only 2 or 3 different filters. Tuned for the past 160,000 all while towing a trailer. |
#64 (permalink) | |
Member # 94825
We towed from Ft. Wayne, Indiana to the hammers with a bone stock Duramax. It would accelerate so hard that it would get wheel hop. it would cruise at 80 MPH. I even hit 90 in it through arizona. All while grossing 30,000 lbs. Much more than that and you are looking at unsafe weights for any 1 ton chassis and are better off getting a MDT. So what can you do with 800 ft. lbs that you can't with 600? Are you drag racing while towing? |
#65 (permalink) | |
Member # 139805
#66 (permalink) |
Member # 163755
Power numbers are just a pissing contest.
How smooth is the power delivered, that's what I'm interested in. At the point that your vehicle can hold its speed, fully loaded, up a decent grade, there is no need for additional torque, in my eyes. The ONLY time I ever wish for more power is accelerating for short on-ramps. Most people see a 50', 25k+ pound chunk of steel heading towards them, and move. So that's not even a very big deal. I run my Duramax stock for now, no complaints. I have every intention of getting a small tune, mostly for improved fuel economy, and to enable the turbo brake to help with slowing things down. Otherwise, I love the power completely stock.
JW Men trained in arms from their infancy, and animated by the love of liberty, will afford neither a cheap or easy conquest. - Declaration of Independence A man with a gun is a citizen. A man without a gun is a subject. -John R Lott |
#67 (permalink) | |
Member # 4243
I'll go a step further and suggest a 87-97 F350 (or F250 with D60 swap). I had one of these trucks. Ironically, it was the 7.3 PSD that made me get rid of it.
90-93 CTD jalopies Last edited by u2slow; 05-10-2012 at 09:32 PM. |
#68 (permalink) |
Member # 139805
Until you are pulling a big fawking trailer in the mountains with a head wind. Then it starts to matter. Its no fun pulling passes at 30 MPH.
Drive from Seattle to San Francisco going through the mountains pulling a 14K trailer when the desert winds are blowing and you might have a different opinion. Sometimes I wonder if people in this forum actually really tow anything. |
#69 (permalink) | |
Member # 163755
#71 (permalink) |
Member # 163755
That would mean going to Commie-fornia, not something I plan on doing. Well, I lied, but Glamis is about the only reason I'd do so.
#72 (permalink) | |
Member # 94825
Bone stock duramax with a tuner set on level 1. It's not exactly flat the entire way to KoH... |
#73 (permalink) | |
Member # 209156
![]() i have to wonder; does me-troll own a truck, or is it all smoke and google images ? ![]() somewhat to the point of the thread, we've had excellent luck with dmaxes. had a stock lb7 and other than a set of injector under warranty, it didn't need anything, towed great, and it was a work truck with 180k. the not quite stock lly would go as fast as you dared while grossing 27k. new 2011 lml is truly awesome, only towed 10-12k lbs so far, but it's like running empty. exhaust brakes are great on it too. as an A-B comparison, LLY quit one night while towing 19k (this is why you don't lay ECM wiring on the turbo). hooked the trailer to a CR Cummins, and damn near lost a tooth everytime we hit a bump. engine was noisier and trans seemed less than happy vs. the allison.
GM 6.2/6.5 & Duramax owner. Pulling tractor crewmember, DT466 with moar b00st. |
#74 (permalink) | |
Member # 8613
Hmm. Do I give the MeTWO response and say this is all wrong, or get a King Ranch? OR do I say this: I'm currently using an 06 Dodge 2500 with a built trans and a Smarty Jr to pull either my YJ or JK. The smarty burned up the trans, yes, the Jr. did that. In the flat lands it tows great. Milage is 10-14 depending on speed and where I am (IL-Co.) In the Co altitude, it loves to smoke, so it's a gear changing game to stay smoke free. I've also run a 7.3 down I-70. Eisenhower and Vail had me at 55 tops, bouncing between 2-3rd gear, and though not hot, it was running out of power. This truck was stock with a 4in lift and 35's (how I bought it.) Milage was similar. I ditched the PSD for the CTD, because I like the CTD better. Just a personal choice. If my old PSD was given to me and I was told to haul the Jeep west with it, I'd do it with no hesitation. Ford has a better interior too. Oh, and body. I've heard few complaints of Dmax's in the mid 2000's but they're IFS going. But that's off what the 'net says. That said, if you need cab space, find what you like best. CTD, PSD or Dmax. You'll get a good truck with any of them.
06 Dodge 2500 CTD 05 Jeep Liberty CRD 95 YJ spring over, high steer and 35in KM2s |
#75 (permalink) |
Member # 64213
I have an '01 F250 PSD and have driven from KY to NC to AK to CO to CA with a 15K goose and then some.
Only time I ever dropped to 30 (due to hills) was on grades approaching 10%.....you are doing it wrong. A mild tune and/or gearing and I would have pulled them easy but I don't want to screw with a good thing. Last edited by 89breaker; 05-11-2012 at 10:33 PM. |
