Duramax run on gasoline for 30 miles... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-22-2012, 12:49 PM   #1 (permalink)
Indy Will's Avatar
Member # 114707
So my dad managed to fill up his 2006 Duramax with gasoline the other day and drive it 30 miles down the road before it quit.
He said it had about a 1/4 tank of diesel and he filled it all the way up. He managed to get 30 miles down the road before it went into 'limp mode' in the shop driveway. The code said fuel pressure so I hoped that it might just be a fuel filter. When I popped the filter we knew what had happened.
So what might I be needing to fix on this? I'm assuming both pumps, injectors...what else? Entire engine toast?
Facebook/Instagram - @WillCarterRacing
Indy Will is offline   Reply With Quote Quick reply to this message
Old 05-22-2012, 12:52 PM   #2 (permalink)
Ford Bigot
FordFascist's Avatar
Member # 31227
You're on the right track for what disintegrates on a CRD when gasoline is introduced.
Originally Posted by MtnYota
It sucks I took a dump earlier, now I'll never know if that roll would have caused me to crap my pants
FordFascist is offline   Reply With Quote Quick reply to this message
Old 05-22-2012, 12:55 PM   #3 (permalink)
Member # 47397
had the same thing happen hear several times at work with our duramax
1 drain the hole tank
2 put fresh diesel in tank
3 put new fuel filter on (fill with diesel or clean atf )
4 prime the hell out of the system
5 crank over till she fires
6 dont fill with gas again...
theres only one pump ( the CP3 * High pressure pump* ) on a stock Dmax
the4wheeler is offline   Reply With Quote Quick reply to this message
Old 05-22-2012, 12:57 PM   #4 (permalink)
BackNBlackTJ's Avatar
Member # 18157
I know on mine the shop did just a flush of the system, cleaned the tank and I was on my way...
at worst you may need injectors...
at best you will only need filters and a tank cleaning...
make sure to clean all the lines out, especially at the fuel pressure regulators and injectors.
Good luck...
BackNBlackTJ is offline   Reply With Quote Quick reply to this message
Old 05-22-2012, 01:17 PM   #5 (permalink)
D45
Member # 102974
I would suggest draining the whole tank
2012 Ford F150 FX4; Long Bed; 3.5L V6 ECO; Max Tow; 3.73; Leveled; 275/65R20 Goodyear Duratracs
D45 is offline   Reply With Quote Quick reply to this message
Old 05-22-2012, 02:17 PM   #6 (permalink)
Member # 117771
If I were footing the bill I'd drain the tank and refill, replace all filters and drain lines as best as possible. I'm do my best to crack and clean all lines. I doubt gas did anything in that short time span.....I'd get on the flushing quick though.
If someone else were....whole different story.
montecarlo31 is offline   Reply With Quote Quick reply to this message
Old 05-22-2012, 07:18 PM   #7 (permalink)
Member # 162643
I have seen this happen more than once working at different shops and here is what I do.
1. Drain the tank.
2. Get the gas out of the fuel lines going to and from tank.
3. Fill tank with diesel, a gallon of engine oil or ATF, and a bottle of Stanadyne.
4. Replace fuel filter but instead of priming it with diesel use Stanadyne.
5. Crank it over until it starts and then run it.
Hopefully no permanent damage has been done.
shortbus4x4 is online now   Reply With Quote Quick reply to this message
Old 05-22-2012, 07:31 PM   #8 (permalink)
Member # 83301
Since no one has asked........how do you fill your diesel truck with gas on accident??
'79 chevy k30 vortec 350/sm465/205/205/5.13's with big tars and toob
Old 05-22-2012, 07:39 PM   #9 (permalink)
chops24's Avatar
Member # 30100
Wrong colored pump handle. Very common mistake
Segway with a spool and 33" thornbirds
I kill at least a million children a night.
chops24 is offline   Reply With Quote Quick reply to this message
Old 05-22-2012, 08:33 PM   #10 (permalink)
Member # 133589
Ive came close a couple times. All diesel pumps here are green, but when out travelling I've found some gas pumps which were green, or they all were all yellow, when your driving at midnight running on caffeine you don't pay good attention.
I hate everybody, don't it feel great.......... to hate?
mvanhelden is offline   Reply With Quote Quick reply to this message
Old 05-22-2012, 10:03 PM   #11 (permalink)
Member # 18157
When I did mine it was 3am... I saw a green pump and put 30 gal. of unleaded in before I realized what I had done... the pump itself was green but the handle was black.
I've seen diesel pumps that were blue with yellow handles, black with either green or yellow handles... but I try to stay to the truck stops... where green IS Diesel
Old 05-22-2012, 10:53 PM   #12 (permalink)
BassnTruck's Avatar
Member # 86582
BP stations are bad about this. 87 is green diesel is usually black.
BassnTruck is offline   Reply With Quote Quick reply to this message
Old 05-23-2012, 01:40 AM   #13 (permalink)
Member # 212466
That's the usual standard in the UK and europe.
Proudly supporting Black Jewish Gays since 2005.
DasLandRoverMan is offline   Reply With Quote Quick reply to this message
Old 05-23-2012, 04:58 AM   #14 (permalink)
Member # 185461
Yeah, that almost got me once.
[QUOTE=f3arn0fj;13890184]No one hates you, you just walked into the lion's den dressed in that wierd lady Gaga meat outfit....[/QUOTE]
[QUOTE=MaxPF;13897261] The new car smell is the most expensive fragrance there is... well, except [i]maybe[/i] for pussy :D[/QUOTE]
FSJPat is offline   Reply With Quote Quick reply to this message
Old 05-23-2012, 08:52 AM   #15 (permalink)
Member # 86724
the local BP station has all the gas handles green, diesel is yellow.
they don't seem to have any rhyme or reason.
Old 05-23-2012, 09:02 AM   #16 (permalink)
Member # 13731
We just make someone else pump it for us in Oregon - then we blame them when they jump it full of unleaded when you said diesel...
uglyscout is offline   Reply With Quote Quick reply to this message
Old 05-23-2012, 01:49 PM   #17 (permalink)
matzell's Avatar
Member # 42081
Remove fuel filter, replace and fill new filter with ATF, add 15 quarts of ATF to tank, top off with Diesel. Prime system as normal. Once you get to 3/4 full top off with diesel again.
I work at a GMC dealer and we see and hear people doing this quite often. It it was at a shop we would drain tank, flush lines and replace filter. One the road we did the above to a friend of mines Duramax coming back from a trip. He filled his with gas. Two cases of ATF (dextron) and he made it home. 3 years later still no problems with it.
General rule is one quart of ATF to one gallon of gasoline. My boss runs all his farm equipment on the used ATF (and diesel 50/50 mix) we have after trans flushes.
Rob Matzell
2014 4WD HARDWARE EASTERN SERIES 4500 CLASS CHAMPION
Matzell Motorsports #4573
Thanks to: Weldone Fabrication, BFG, Fox, PRP, PSC, Raceline, Reid Racing, Liquid Iron Industries, Ruffstuff, Willow Lawn Service Center, JB Custom Fab, Yukon Gear, Dynomax, 150tunes.com,Lugnut4x4
matzell is offline   Reply With Quote Quick reply to this message
Old 05-25-2012, 10:58 PM   #18 (permalink)
2big bronco's Avatar
Member # 66684
on my way to work, 430 am i begin pumping and walk inside to get a rockstar. my co worker comes in and says " hey your filling the truck with gas" i replied with " yep thats why were here, just like every morning" . it took me a good couple seconds for it to even register. i didnt drive it but across the lot. syphined 70% of whatever mixture out of it, topped it off with diesel and never a problem, however my dads 6.0 didnt make it 2 blocks before it died. complete fuel drain, filter and diesel and it was fine
Old 05-26-2012, 09:32 AM   #19 (permalink)
Ho Shorts's Avatar
Member # 109328
Around here more often than not I see the opposite problem, most people (especially women) fill up thier car with Diesel .
How you do this is beyond me because the nozzel is larger and won't fit into the filler neck. It doesn't stop them, I see at least a couple cars and mini vans a year come in full of diesel.
Derek
I had a clogged sewer pipe. After cutting the pipe, reaching in past my elbow, and removing the obstruction; about 12lbs of shit started flowing. Bits of corn and peanuts washed over my neck, down my shirt, some even got in my mouth.
It was still a better experience than buying from Ballistic Fab
Ho Shorts is offline   Reply With Quote Quick reply to this message
Old 05-26-2012, 10:34 AM   #20 (permalink)
Indy Will's Avatar
Member # 114707
I sure was missing a P pumped 12 valve when I was changing out a CP3 yesterday.
Ridiculous...
Old 05-29-2012, 08:07 AM   #21 (permalink)
Member # 98110
When I was a kid my Mom's boss filled a diesel school bus with gas and ran it. I never forgot that and am now super anal when filling the power stroke to make sure to read the word diesel and not rely on the pump color.
tbrockey is offline   Reply With Quote Quick reply to this message
Old 05-29-2012, 08:44 PM   #22 (permalink)
rockwellyj's Avatar
Member # 148940
I put about a gallon of gas in my truck the other day and thank god realized what I was doing before it was too late. I drive a half ton gas for for work and fill it up daily.
I seen it happen a lot years ago at a small station i worked at in HS. They would drain the tank flush the system change filters and done.
H & H Fab buggy
rockwellyj is offline   Reply With Quote Quick reply to this message
Old 05-30-2012, 06:17 AM   #23 (permalink)
bobbing for fries
billy bones's Avatar
Member # 190574
Ridiculous...
So flushing it didn't work? Or was this on a different truck?
A few months ago at a local station. . .
Fuel company filled the wrong tanks at the station. Gas in the diesel, diesel in the gas. They figured it out within an hour or so. But it caused some damage in the meantime.
If Everyone Is Thinking Alike, Then Somebody Isn't Thinking
billy bones is online now   Reply With Quote Quick reply to this message
Old 05-30-2012, 09:30 AM   #24 (permalink)
Member # 86724
somebody would be buying me new stuff if that was the case.
how the fuck does the delivery guy not notice he's filling the tanks wrong?
Old 05-30-2012, 09:52 AM   #25 (permalink)
bobbing for fries
Member # 190574
Dunno, but is unemployed. I buy fuel from that supplier occasionally.
Heard they ruined several fire trucks that day, but the damage didn't spread much beyond that. One expensive clean up though.
