Allison 5 speed Rebuild, Guru's needed.. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-31-2012, 11:44 AM   #1 (permalink)
TPIJeep's Avatar
Member # 2082
Send a message via AIM to TPIJeep
I am tearing into my Allison out of my 03 Duramax this weekend and just want to make sure I have all the parts I will need along with the common wear parts that should be changed.
I am building with a PPE Stage 5 kit and a Precision Industries ML Convertor.
In addition to these parts I have purchased a complete bushing kit, I also got a PI drive flange and an assortment of bearings listed below.
2- Allison T1/T6 Bearing - Early
1- Allison T2 Bearing
2- Allison T3-T5 Bearing
1- Allison T4 Bearing
I also got two PTO cover gaskets, Deep pan, filter loc and some assembly lube. I got a Transfer case wear kit and gasket and the fluids needed for both.
What else can I expect to need to complete this build, I don't mind getting small parts if there in a possibility of needing them. The truck has 150k on it but it has been driven hard so I just want to cover my bases.
Thanks!
I am normally only a danger to myself don't make me include you!!
BioHazard Buggy Build Thread
Southern Motor Sports
Ruston, Louisiana
TPIJeep is offline   Reply With Quote
Old 07-31-2012, 11:56 AM   #2 (permalink)
Member # 30996
You sound like your ducks are in a row, just make sure you do a pump rub kit since you will have the tcase out.
Also, report back as i want to do this in the next year.
Good luck.
90yj, Vortec350, th400, np205, 14bolt detroit 4.88, 8lug waggy44 4.88 open, 106"wb, recentered hummers, 39.5 TSLs
mines4x4 is offline   Reply With Quote
Old 08-02-2012, 08:54 PM   #3 (permalink)
Member # 67493
Send a message via AIM to lodikrawlingkiller Send a message via MSN to lodikrawlingkiller
hey shoot me a pm. my best friend is an allison tech he could give you all the walk through you need. he isnt on pirate so pm me and ill get you his number.
93zj-linked-spooled-9in/d44-atlas-exo'd-37's
'06 ,mega cab, 5.9 CR, edge, banks 4in, k&n intake
mateya"daddy do you know there's turtles in the desert and they're endangered?"
me "yep"
mateya "well they're stupid…don't they know turtles cant live in the desert theres no water.
lodikrawlingkiller is offline   Reply With Quote
