Member # 42255
Trailer Tire options
I am in the middle of rebuilding my gooseneck and have bought a set of aluminum trailer wheels but have not decided on what tires to get.....any suggestions?
I put a ton of miles on this trailer (about 20G in a year) so I need a good tire. |
Owner TWF
Member # 89489
Between the business my father and I have and TWF I have no less than 8 trailers. We have had great luck with Maxxis tires.
www.TrailWorthyFab.com TWF Double Beadlock Wheels, Cheap 37" Tires, PitBull Tire dealer, RaceLine Wheel dealer, Rock rings, Wheel centers, Custom Splice winch rope, PVC inserts, O rings, Hummer wheels, NIB Rubber Runflats, Rockwell Axles, Marsh Racing dealer, 37" Guard Dogs, Cheap LED Light bars, Loud Horns |
I have run Maxxis on all my trailers for the last 6 years and only blew one
the one that blew was due to not being aired up correctly and hitting a curb
www.iMPAKS.com, www.LoneRiderBeer Tread Lightly Master Trainer My Builds: Bus / RV, New Jeep, Camper / ToyHauler, CTD Tow Rig, Jeep XJ, Shop Last edited by Ken Carter / BRUISER; 08-20-2012 at 01:34 PM. |
Member # 84260
Size, single or duals?
The best trailer tires we have ever run and the only one Made in America is the Goodyear G614 RST. Not only are they made in America, they are actually rated to handle the load (3750# single) durable and are very long lasting, even regroovable. They are a bit pricey when compared to the inferior import junk but more than worth it based on the significant increase in mileage. We Buy American when we can and these tires make for an easy choice! |
Member # 6398
I bought a new import (China) tire from my local Firestone to replace the spare on my trailer (5200lb axles, 16"). I put it on the spare tire mount in the fall and it sat there. Next summer the tread had shifted over and ballooned up on one side, almost like you were driving on a severe sidehill with a heavy load. VERY weird. Never even touched the ground. Firestone actually exchanged it with a different tire (Hercules I think). They could tell from the rubber nubs still on the tread it had never been used. Inflation pressure during "storage" on the trailer was around 70psi.
"Take 300 people and on average 290 of them just generally suck at life" |
What size?
I ask because I prefer damn near any brand of light truck tire. I'm in the same boat as you with a 30' TT and can only find trailer tires for the size that will fit in the wheel well. ![]() I lean away from Maxxis due to a member here getting dicked around by them. With my luck I would end up with that situation myself. Goodyear, have those on the existing trailer. I'm not happy with them. showing funny sidewall wear in random spots, suck as softball sized areas on the sidewall that is spiderwebbing, but you can only see it under weight. The tires are also rated for the weight, and the sidewalls flex BAD BAD BAD. Then again, I've run goodyear LT tires on my abused utility trailer and never had a problem. I'm of the mind that all trailer tires are PIECES OF SHIT. Last edited by Travis Waldher; 08-21-2012 at 10:12 AM. |
