ABS light is on? 2000 PSD - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-06-2003, 04:57 PM   #1 (permalink)
Member # 940
Anyone else have ABS problems with their 2000 Fords. This one is a PSD 4x4 dually chassis cab so it has the 80 rearend. Let me know what you/they fixed/replaced.
Every once in a while when you are about stopped you will feel the peddle kick back slightly and it will glide for about 1/2 of a second and then go back to doing what you were doing as far as peddle pressure goes. The light started out off and on for a while but is on all the time now so I need to do something about it and hope it is simple.
Anyone???
WWW.PCRYO.COM
Deep Cryogenic Tempering Service
Find all my products at
www.KICKASSOFFROAD.COM
916-434-6978
Custom Axles built to order.
Got 40 spline? I have the hubs, spindles, and axles you need to kickass!
Custom Hummer wheels and centers
Axle Resplining
66CJdean is offline   Reply With Quote
Old 10-06-2003, 05:31 PM   #2 (permalink)
Member # 9222
more than likely it is the rear wheel abs sensor. it is on top of the diff housing. they are pretty inexpensive. around $20 from ford.
edit,if that doesn't do it let me know and i'll come up with the code scanner...maybe for some hummer re-bar rock rings .
larryboy is offline   Reply With Quote
Old 10-06-2003, 05:58 PM   #3 (permalink)
Member # 940
Is it something I can just ohme out? What should it read if working correctly.
WWW.PCRYO.COM
916-434-6978
Axle Resplining
Old 10-06-2003, 06:06 PM   #4 (permalink)
Member # 9222
i can look it up tomorrow,i never go that far. scanner says rear wheel abs sensor and i replace it .
Old 10-06-2003, 06:43 PM   #5 (permalink)
Member # 940
well we just might have to work a out a deal for some scanner time
WWW.PCRYO.COM
916-434-6978
Axle Resplining
Old 10-06-2003, 06:46 PM   #6 (permalink)
Member # 5021
I would suggest that sensor also. That same problem occurs with GM rear ABS systems alot. What works alot of the time is to do a rear diff service. When you have the cover off brake clean the tone ring and sensor. They get crap on them and it throws off the reading to the sensor.
Don't be "THAT GUY" on the trail.
www.voodoowax.com
The Rockslut is offline   Reply With Quote
Old 10-06-2003, 07:32 PM   #7 (permalink)
Member # 9222
let me know .
Old 10-07-2003, 01:10 PM   #8 (permalink)
High5's Avatar
Member # 1700
my 99 did that and it was the ABS sensor in the rear end. it was only like $18 for a new one from ford.
High5
IT'S 1TON O' FUN!
High5 is offline   Reply With Quote
Old 10-07-2003, 02:38 PM   #9 (permalink)
Member # 940
Cool! That is what I was hopeing to hear.
WWW.PCRYO.COM
916-434-6978
Axle Resplining
Old 10-07-2003, 07:27 PM   #10 (permalink)
Member # 11798
Send a message via AIM to scoutkid
happened on my 97, check your fuses, sounds stupid, but for some reason, ford put the abs on the same circuit as the blinkers AND the brake lights!! so when my abs light was blinking, it meant i had no blinkers and brake lights, which i didn't know for like a week of driving!! Pretty scary stuff, i kept putting in new fuses, i finally just took it back to where i bought it from and told um to fix it, or the would pay for a new truck when i got in an accident from the one they sold me with funky abs light in my searching i too found out about the weak rear abs sensor, and the guys at the dealership said they sold a lot of them, so there you go
2003 E350 7.3L Diesel UJOR 4x4
scoutkid is offline   Reply With Quote
