Need help with a 12v CTD thermostat ASAP! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-01-2004, 05:48 PM   #1 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
Well, found out my heat/temp problem was that the rubber shroud on the thermostat was half sucked down inside it and was therefore never closing.
That is the good news - the bad news is the autozone t-stat is the WRONG ONE
Advance Auto Parts says they can get me one by tomorrow, am gonna check the dealership in the morning too...
Someone wanna talk me out of a parts store replacement t-stat in favor of a dealership or Cummins one? Is there some reason I should avoid a parts store one?
Thanks
>David
> 4x4Spot.com
>It only hurts the first time you agree with me...
>"A little nonsense now and then is cherished by the wisest men."
DRM is offline   Reply With Quote
Old 02-01-2004, 08:28 PM   #2 (permalink)
Mechanos's Avatar
Member # 6704
You might try reading this thread over on the DTR site. It's in the 24v forum, but some of the info might apply to you undervalved folks as well.
It's
IHeavy
aka TORC
KC0UIC
Nothing is foolproof to a sufficiently talented fool.
Mechanos is offline   Reply With Quote
Old 02-01-2004, 09:04 PM   #3 (permalink)
flimmy's Avatar
Member # 3101
Re: Need help with a 12v CTD thermostat ASAP!
Thanks
because the Mopar and Cummins part #'s are posted here if you search
[url]www.trailbrightled.com[/url]
flimmy is offline   Reply With Quote
Old 02-02-2004, 05:38 AM   #4 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
Re: Re: Need help with a 12v CTD thermostat ASAP!
Funny, I did search, but didn't remember seeing it in my own thread, so I didn't looked in there again
>David
> 4x4Spot.com
Old 02-02-2004, 10:49 AM   #5 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
Well - Dealer down the street from work - nope.
Called the local diesel shop in the town on the OTHER side of where I live (from where I work) and they have it in stock - $20 and some change for the stat and gaskets... Now I just gotta get there before they close @ 5:30
Dealer wanted $30, and she said they used to be higher than that.
>David
> 4x4Spot.com
Old 02-02-2004, 11:04 AM   #6 (permalink)
Mechanos's Avatar
Member # 6704
Dodge dealer or Cummins dealer? I've found that the Cummins dealer prices are a bit lower than the Dodge dealers.
It's
IHeavy
aka TORC
KC0UIC
Old 02-02-2004, 01:06 PM   #7 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
Dodge dealerships - the only Cummins dealer I found were a bunch of JERKS and I will never be visiting them again.
Wife picked it up for me - ain't she sweet?
Can't wait to install it to night and see what improvements are made. Maybe at least I won't FREEZE on the way to work in the morning...
>David
> 4x4Spot.com
Old 02-02-2004, 07:40 PM   #8 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
installed - and temp gauge is now working , as is cab heat
Hopefully economy will improve since the engine is actually coming up to normal operating temps now...
>David
> 4x4Spot.com
