PRODIGY is the way to go.. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-28-2004, 04:36 PM   #1 (permalink)
Member # 13384
Send a message via AIM to SolidAxleDurango
That's right folks... A Tekonsha PRODIGY brake controller for towing.
I've read about these on all the RV forums, and the reviews have been great.
Now that I've got the Ram 2500, I needed to get a brake controller and decided to see what all the hooplah was about. Well they're right. This thing friggen rocks. I will never go back to any other type of brake controller again.
For those of you familiar with brake controllers and towing, you know there are two settings you adjust: 1) the maximum amount of brake you want; and 2) the rate at which the brakes are applied.
The problem with this is the fact that every single stopping scenario is not the same. In some cases you want to "cover" the brake pedal and take a long slow stop... In other cases you want an abrupt, smart stop. Normal controllers can't handle this. They only work like you pre-set them. The only time a normal brake controller operates smoothly is when (and IF) you press the brake pedal, and you come to a stop at the EXACT same moment that the brake controller reaches maximum stopping setting. Otherwise you end up lifting the brake pedal and re-applying - creating a ton of jerking/lurching. This annoying behavior is most common when doing ANY (and ALL) in-town driving or ANY kind of backing/parking maneuvers.
Hows the Prodigy better? The only setting you give it is the maximum braking force you'd want it to apply. This will of course change as you change your trailer or load. Once set, you're done. It uses decelleromoters that use inertia to determine both how much and how quickly the trailer brakes are applied. In essence, it's a seemless integration with the vehicle brakes...
I cant' be happier!!!!
08 Kawasaki ATVs / 07 SeaDoos <- we ride / 07 Ram <- we pull / 12 Keystone Avalanche <- We sleep
SolidAxleDurango is offline   Reply With Quote
Old 02-28-2004, 04:37 PM   #2 (permalink)
Member # 13384
Oh.. and "Why?" you ask didn't I get one of these for the Durango in the first place?
Well, the average run-of-the-mill brake controller is about $80 retail. The Prodigy retails for $140-$160. I thought for sure what I got for the Durango was "good enough".
Fork that.. I was wrong. Prodigy all the way baby.
Old 02-28-2004, 04:43 PM   #3 (permalink)
Member # 10379
104 bucks HERE
fabricator is offline   Reply With Quote
Old 02-28-2004, 04:49 PM   #4 (permalink)
Member # 13384
Originally posted by fabricator
104 bucks HERE
I Ebay'ed it for 103 + shipping... Initial sticker-shock kept me from "shopping around" eons ago when I outfitted the Durango. Now me know better.
Old 02-28-2004, 05:21 PM   #5 (permalink)
Member # 6906
there was a post on here a few months ago that had them for like $85 or so through amazon I think. got mine on my 03 2500 and it truly is awesome, I don't know how I towed as many miles with no controller as I did
99TJ sport, 5.5" RE long arm, dual detroit locked 44's, flipped d300 w/4:1, 37" MT/Rs
03 Ram, HO cummins, 6spd,quad cab, rhino, Edge EZ,AFE PG7 intake,375 HP,775ft lbs torque:P
03 Jetta TDI
carolina 4x4 parts
www.4by4parts.com
robobx is offline   Reply With Quote
Old 02-28-2004, 08:35 PM   #6 (permalink)
Supergper's Avatar
Member # 2159
Send a message via ICQ to Supergper Send a message via AIM to Supergper Send a message via MSN to Supergper Send a message via Yahoo to Supergper
I got one from teh amazon deal, its in my 99 F350...I have yet to use it though because my trailer doesn't have brakes yet good to hear it works so well
-Caleb Call
Supergper is offline   Reply With Quote
Old 02-28-2004, 10:44 PM   #7 (permalink)
Member # 107
Send a message via AIM to The Jerk Send a message via MSN to The Jerk Send a message via Yahoo to The Jerk
old tow rig + cool crusier on cool trailer = stopping a must. i have one and it is sweet. also know 2 others with it and they wouldnt buy anything else.
jiMMy
RockZombie:68FJ40 LPG350/sm420/d300/d60/d70
The Jerk is offline   Reply With Quote
Old 03-21-2004, 07:44 PM   #8 (permalink)
64Trvlr's Avatar
Member # 6582
Count me in too. I have one and it's the best controller I've ever used.
Originally Posted by Muddin
You must be able to blow harder than me
Originally Posted by Bubba Ray Boudreaux
Shooting is gay.
D.A.V. Life Member
N.R.A. Life Member
64Trvlr is offline   Reply With Quote
Old 03-22-2004, 07:46 AM   #9 (permalink)
Member # 5943
Location: Southeastern MN. (formerly near Chicago, I've ESCAPED!)
My Dad & brother have 2 Prodigy controllers on the farm. One is on a 24' gooseneck, the other is on a 16' tiltbed.
The gooseneck (double axle, dual tires) hauls cherries in the summer for 3 weeks solid, gross weight on the rig is almost 32,000 lbs. The Prodigy works awesome on it.
ChiXJeff
ChiXJeff is offline   Reply With Quote
Old 03-22-2004, 09:59 AM   #10 (permalink)
Non-Lemming
SanDiegoCJ's Avatar
Member # 840
I have one on my '03 RAM3500. Excellent controller.
SanDiegoCJ is offline   Reply With Quote
Old 03-22-2004, 11:10 AM   #11 (permalink)
YJ4RoX's Avatar
Member # 1930
I just put one in my 98 ram 2500, i LOVE it. You can barely tell the trailer is back there when coming to a stop. Brakes on both axles help too.
Prodigy all the way!
YJ4RoX is offline   Reply With Quote
Old 03-22-2004, 11:22 AM   #12 (permalink)
Member # 20304
Send a message via AIM to BarrelRoll
Sounds like it's the way to go. I had a real cheep auto zone one that took a dump and now have a voyager. If i ever buy another one i guess i'll spring for a prodigy.
BarrelRoll
This board is no doubt slowly moving from Pirate4x4 to ElitistYuppyWithTooMuchMoney4x4.
-Braxton 357
BarrelRoll is offline   Reply With Quote
Old 03-22-2004, 11:24 AM   #13 (permalink)
Member # 3893
Yup, had mine about 6 months now, by far the best. And I agree with the above, it works great with 4 wheel brakes.
'97 TJ - D60 Ford Front, D60 E350 rear, build is going slowly...
'06 Dodge CTD 4x4 QuadCab
TornadoTJ is offline   Reply With Quote
Old 03-22-2004, 01:07 PM   #14 (permalink)
Mechanos's Avatar
Member # 6704
I have one on order now..... I had a decent one from Redline, but it got douched with Coke since it was mounted directly underneath the cup launcher in my '96 Ram. It still worked, but the slides were all sticky and wouldn't move freely. I tried to take apart to clean it, but busted the case all up trying to get it apart. Searched around and found the Prodigy on sale for $106 w/ free shipping. Should be here in a day or two.
It's
IHeavy
aka TORC
KC0UIC
Nothing is foolproof to a sufficiently talented fool.
Mechanos is offline   Reply With Quote
Old 03-22-2004, 01:23 PM   #15 (permalink)
Member # 3893
[hijack]
Damn I hated the cup holders in my '96. Cops could see my beer.
[/hijack]
Old 03-22-2004, 01:49 PM   #16 (permalink)
Big Meanie
Haole's Avatar
Member # 5859
104 bucks HERE
Guess you like paying an extra $20. Dude on Amazon.com auctions is selling them for $82.99.
Ka 'aina uluwehi, ko kakou
kuleana.
- The lush life-giving land, our personal responsibility.
Ventura County Axle Snappers - Nevada County Chapter
Haole is offline   Reply With Quote
Old 03-23-2004, 01:54 AM   #17 (permalink)
Member # 10379
don't be shy old boy...... post a link !
Old 03-23-2004, 12:26 PM   #18 (permalink)
rockcrawler304's Avatar
Member # 5601
Send a message via AIM to rockcrawler304
Excellent info and answered my questions...Now I know what I am buying.
06 Dodge Mega Cab 2500 4x4 CTD 325/610 6spd hand shaker, Smarty tuned!
rockcrawler304 is offline   Reply With Quote
Old 03-23-2004, 10:25 PM   #19 (permalink)
m-class's Avatar
Member # 19949
Just ordered mine from Amazon, $91.99 shipped ups. Hopefully will get it soon
m-class is offline   Reply With Quote
Old 03-24-2004, 01:15 PM   #20 (permalink)
Member # 1926
Got mine on Amazon some time ago.... Best brake controller I've ever used. I had to stop really fast on the highway once, and I noticed that I was able to lock up the trailer tires while braking really hard. My old controller would not worked this way. IMHO, everything else is junk.
'69 FJ40 with very few stock parts.
2000 Cummins with some goodies to make it smoke.....
Trail Gear's Bad Ethics=Bad Business.
fj40charles is offline   Reply With Quote
Old 03-24-2004, 02:08 PM   #21 (permalink)
Big Meanie
Haole's Avatar
Member # 5859
Search! It's already in this forum. That's where I found it.
kuleana.
Old 03-24-2004, 09:17 PM   #22 (permalink)
Mechanos's Avatar
Member # 6704
My Prodigy showed up today.... it took longer for me to decided exactly where to mount it than it did for me to actually install it. Once I settled on a spot, it was just a matter of drilling two holes, mounting the pocket and plugging in the harness to the under-dash connector and plugging the other end into the controller. Took maybe 5 minutes to install....
It's
IHeavy
aka TORC
KC0UIC
Old 03-25-2004, 01:02 AM   #23 (permalink)
Member # 8730
wow that guy on amazon is selling them cheaper then allowed hell my cost as a dealer is $94 and change and thats if I tak 10 units
people like him put the small guys out of business
[QUOTE=ScottFJ40]
With a face like that, she better piss 100 year old scotch, and fart sunshine. [/QUOTE]
bigNATEŽ is offline   Reply With Quote
Old 03-25-2004, 02:33 PM   #24 (permalink)
FYRMAN's Avatar
Member # 4358
Send a message via Yahoo to FYRMAN
No shit....
My cost is $119.
[COLOR="Red"]Central Washington Muff Dive and Rescue Team[/COLOR]
FYRMAN is offline   Reply With Quote
Old 04-01-2004, 08:27 PM   #25 (permalink)
Member # 2274
Send a message via AIM to Dust Puppy
im picking up my trailer next week and im now looking at controllers but i really dont know what im looking at from one to another.
The sticker shock got me too when i was looking around but it seems it can be found at a decent price.
anyone have any more suggestions?
thanks
DP
Its all about the Bling!!!!!!
"no voodoo, no black magic" -- BillaVista
Originally Posted by JESSE_at_TLT
I could make rollcages shaped like balloon animals and they sure would be different and eye catching. Want one?
Originally Posted by Dieselmh
Do the world a favor and just kill her. It needs to be done.
Dust Puppy is offline   Reply With Quote
