Member # 8294
Forest River Sandpiper
Anyone have any experience or opinions about the Forest River Sandpiper sports or Sierra Sports(there pretty much the same trailer)? There was a thread last week that mentioned them. We went and looked at them at a local dealer and really like them. They have a 34ft tag model that has a cargo carrying capacity of 6800lbs. I am going to go back in a take some measurements but I think the tonka will fit if I remove the rear fold down bed. The dealer is going to let me bring the tonka in and load it up,
That should be fun.I crawled under it and all through it and it looks to be pretty well made. The frame is pretty beefy. I am just wondering if they are overrating their specs. They are asking $27k on sale right now, normally it is $30K. We will probably wait to buy and have to order since they do not stock the color scheme the wife wants. Pic Specs MODEL : T34SP HITCH WEIGHT : 975 BASE DRY WEIGHT : 7720 GVWR : 15950 NET CAPACITY : 6871 TIRE SIZE : ST225/75R15D BOX LENGTH : 35'4" FRESH WATER : 100 BLACK HOLDING : 40 GREY HOLDING : 80 Features RVIA Coded for Safety Air Conditioner 13,500 BTU Awning A&E ABS Sport Table CD Player w/ Cassette AM/FM Create-A-Breeze Vent Fan Water Filter System TV Antenna w/ Booster Metal Frame Sport Sofa Large 2 Door Refrigerator Roof Rack and Ladder (N/A T18) Spare Tire and Carrier Exterior Lights all Sides Solid Raised Oak Cabinet Doors Cable and DSS Wiring Diamond Plate Front Easy Lift Ramp Door Full Walk on Rubber Roof Full Linoleum Floors Generator Ready (N/A T18) Higher GVWR Package Large Capacity Storage Outside Shower Power Front Jacks FW Tinted Glass (Safety FW) Wide Body Design Water Heater By-Pass Fully Insulated with R-7 Oak Drawer Fronts 3 Burner Range Hi-Output with 22" Oven 18" Overhead Storage Cabinets in Cargo Area Dual LPG Tanks w/ Cover TT Spring Assist Rear Ramp w/ 2600 lb. Cap. Dual LPG Auto Regulator Safety Chains TT Safety Break Away on Brakes 100 Gallons Fresh Water (Ex. T18) 12V Cut Off in Storage 93-1/2" Ramp Opening 6" Box Frame T18, T21, T25 10" I-Beam Chassis No Wheel Wells on Larger Units Side Walls Mounted on Top of Floors for Extra Strength
If life gives you lemons, throw them at the stupid people. |
Sale -> schmale.....
Going rates for TTs and 5vers is generally 70-80% of MSRP depending on demand. Haven't bought one from them, but have you priced the trailer you want here?? http://www.rvwholesalers.com/ It'll give you the MSRP and their price.
08 Kawasaki ATVs / 07 SeaDoos <- we ride / 07 Ram <- we pull / 12 Keystone Avalanche <- We sleep |
#3 (permalink) | |
Member # 8294
Still looking for opinions and experience with Foret River. I have found opinions about their travel trailers and most people sound satisfied.
#5 (permalink) | |
Member # 14644
1986.5 Nissan crawler - dual cases, one tons, 42's... 2003 SV650 1997 F350 DRW PSD |
Also, if you're looking for review of a manufacturer's trailer, don't be overly concerned with people's comments on appliances or the fixtures... There all the same regardless of what brand of trailer it is... Hehe.. there's only about 2 manufacturers for anything in there.
As an example, If someone is posting "I hate Jayco, because their fridges suck..." then they're a moron. There's Norcold fridges, and there's Dometic fridges... That's it.. On one lot, you might even see some Jayco models with one brand, and some Jayco models with the other brand. What you should be concerned with is the assembly quality and structure. Pay special attention to tendencies for leaks.
#7 (permalink) | |
Member # 8294
#8 (permalink) | |
Member # 8294
I agree. I am more interested in the opinions on chassis, ramp, floor, and how they tow.
#9 (permalink) | |
Re: Forest River Sandpiper
Also, not sure what this ramp capacity means. Hopefully I'm just misunderstanding something. I really like these trailers as well and had wondered what they cost. The price seems pretty reasonable to me. I also assume these are the 5th Wheel variety?
Larry [url]www.columbiaoverland.com[/url] |
#10 (permalink) | |
Member # 8294
Re: Re: Forest River Sandpiper
The ramp capacity is a question for the dealer/manufacturer. I still have to weigh the tonka because I came to the realization that I don't actually know how much it weighs. If that ramp can only handle 2600lbs at a time i'll probably break it. The tonka's kinda dead or I'd be at the dealer trying to stuff it in that thing, they said I could .
If life gives you lemons, throw them at the stupid people. Last edited by TheTonka; 04-05-2004 at 11:08 AM. |
#11 (permalink) | |
The GVW will always be equal to the weakest rated part in the equation. You can't just put bigger tires on it and call it good. The tires on that trailer better be rated for the GVW of the trailer, or they are in some serious trouble.
[COLOR="Red"]Central Washington Muff Dive and Rescue Team[/COLOR] |
#12 (permalink) | |
Re: Re: Re: Forest River Sandpiper
#13 (permalink) | |
Member # 8294
Re: Re: Re: Re: Forest River Sandpiper
I think it'll easily be 5000lbs. So I have to wonder how many times those ramps can handle that much weight and what about the hinge. Am I being too paranoid? If I am going to finance this thing for 1- years I want it to last.
#14 (permalink) |
Member # 8294
Only picture I can find right now.
More here Its changed a little since those, but not much. Major changes are in store that might add a little weight(i.e. full cage in bed to protect 2 passengers.)
#15 (permalink) | |
#16 (permalink) |
Member # 10066
You know the weights they list for the trailer are BASE model weights with no options....
I'd see if the dealer will let you take it across the scales full of water , dishes, clothes, shit paper, etc.. and see what the real weight is.... Full water tank is going to add 800lbs ! Add your rig inside and thats a WHOLE lot of tag along trailer... I'm not an expert but don't recall ever seing a vehicle rated for more than 10k tag along??? |
#17 (permalink) | |
Member # 8294
I have already talked to the dealer and he is willing to let me do whatever I have to to check if the trailer will work for me. He is very accomidating, of course he is also on commission.
#19 (permalink) |
Personally if I went with that trailer, 5th wheel is the way I would go. I know you can tow a lot more than 10K with a bumper pull, but I would rather not. I can't imagine the handling characteristics of a 12-14K bumper pull at 70 MPH!
#20 (permalink) |
Member # 8294
I'd kinda like to stay away from the fifth cause I use the room in my bed under the shell for my car audio business. I know a fifth would be better.
As for what I am looking for from an RY style toy hauler this tag has the largest carrying capacity with the interior dimensions I need. I am still looking for info on the quality of forest river products. I know weekend warrior is really good as well as Thor but neither of them have haulers, even fifth wheel, that have enough room inside or carrying capacity to hold the tonka. The only reason I have been looking at these is the wife is more impressed with the comfort of the toy haulers than the race trailer. I want a stacker, but I am probably 6 months from purchase and need to cover all possibilities before I sell my current trailer.
#21 (permalink) | |
Member # 10495
Doc
You gonna do something or just stand there and bleed? |
#22 (permalink) | |
Member # 8294
#23 (permalink) |
When you start to look at them... STAND IN THE DAMN SHOWER
Many TT and 5vers have a small step up into the shower stall. But the ceiling does not accomondate.. Nothing worse than having to slump over to shower in something you're paying dearly for every month. Mine has a bubble-style sky light that allows me to stand up straight!
#24 (permalink) | |
Member # 8294
I don't get it. I'm not a big guy at 6' and 220 but it just seems they think all RVers are little or really flexible.
#25 (permalink) | |
