Converting 2WD '01 CTD to 4WD? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-03-2005, 07:42 AM   #1 (permalink)
Member # 717
Send a message via ICQ to Desert Jeepin Send a message via AIM to Desert Jeepin Send a message via Yahoo to Desert Jeepin
Anyone done it? Anyone have any advice? Anyone want to donate stock parts?
Http://www.TinBenders.org
Spotter, Team Raffle F-Toy, #50.
Originally Posted by trampas View Post
wait... hold the homophone... you're ghey?
Desert Jeepin is offline   Reply With Quote
Old 01-03-2005, 08:20 AM   #2 (permalink)
Member # 14780
man, that seems like it would be a lot of work!
04.5 cummins lb,qc,white, 4x4,,bddl, outlook,, exhaust 315 bfg's
02 WRX caged etc
new buggy
http://www.pirate4x4.com/forum/showt...43#post5890143
save tellico post #830
35xj is offline   Reply With Quote
Old 01-03-2005, 09:40 AM   #3 (permalink)
Member # 85
Cake, just do it. I'm gonna do one as soon as my buddy get's his 2WD stuck again
2007 JK, 4.5 RE LA,Atlas 4spd,40's,18"Raceline BLs,Longfields,ARBs,Superiors,etc.
ASTAR is offline   Reply With Quote
Old 01-03-2005, 09:41 AM   #4 (permalink)
Member # 800
my advice is not to do it, loads of work involved, if you use stock parts you'll start finding all the places that dodge cut corners in the 4wd bits and start upgrading and then it'll be money too.
my dodge sucked, I went superduty
mytzlflick is offline   Reply With Quote
Old 01-03-2005, 09:50 AM   #5 (permalink)
Member # 717
I understnad and even expect nay-sayers.
My truck is almost payed for. It'd be cheaper to convert it than it'd be to sell it, and buy a 4x4.
Old 01-03-2005, 09:54 AM   #6 (permalink)
Flake's Avatar
Member # 19732
Just curious are you planning to use stock Dodge coils and control arms, go leaves or custom stuff?
Flake is offline   Reply With Quote
Old 01-03-2005, 09:58 AM   #7 (permalink)
Member # 85
It really wouldn't bee all that tough. You could use some stock springs , the stock sway bar (with modified links) and make some links up. If you go that way, I would just take measurements off of a stock Dodge to handle the link locations etc. Otherwise, you can leaf spring it and that would be silly easy. The only problem I'd see with that is sagging springs from the motor weight. Just make sure you do utilize a sway bar, and be sure to have proper steering geometry so it drives well. How much height do you want?
Old 01-03-2005, 10:04 AM   #8 (permalink)
Member # 717
I want it to look like it came from the factory.
I intend to utilize as many stock pieces as possible.
Old 01-03-2005, 11:49 AM   #9 (permalink)
Member # 4406
Have you ever driven a stock 4x4 model? The whole front end design is a disaster. If you're going to do the conversion, at least make it better than stock.
Pete
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways , beer in hand, body thoroughly used up, totally worn out and screaming "WOW, what a ride."
pcorssmit is offline   Reply With Quote
Old 01-03-2005, 12:29 PM   #10 (permalink)
Member # 717
Pete
Honestly, I have not. All I know is I'm sick of getting stuck, and in looking at a new towing setup, I think I'll need 4wd for 24K GCTW.
Old 01-03-2005, 01:41 PM   #11 (permalink)
Member # 5943
Location: Southeastern MN. (formerly near Chicago, I've ESCAPED!)
I may have to replace the front axle housing on my 99 2500 CTD. Junkyard price in the Midwest is anywhere from $1,100 to $1,750. Add in a 241HD tcase and driveshaft. Don't forget the shifter as well.
You sure it's gonna be cheaper?
ChiXJeff is offline   Reply With Quote
Old 01-03-2005, 01:48 PM   #12 (permalink)
Member # 717
I can make my own driveshaft, Basically I'm thinking I'll need the axle, springs, arms and T-case.
I'm est. $400 for the tcase, I'm hoping I can get the stock springs and arms from someone who is doing a lift, so maybe what $200? Then the axle, and I'm guessing $1000 or so if I watch around like I did for the Jeep.
Old 01-03-2005, 01:54 PM   #13 (permalink)
Member # 3893
is the trans different from 4x2 to 4x4?
'97 TJ - D60 Ford Front, D60 E350 rear, build is going slowly...
'06 Dodge CTD 4x4 QuadCab
TornadoTJ is offline   Reply With Quote
Old 01-03-2005, 01:57 PM   #14 (permalink)
Member # 717
I assume so. I will either be forced to sell my 2wd to buy a 4wd, or maybe jut swap outputs. I don't know. I need to buy a manual I guess.
Old 01-03-2005, 03:24 PM   #15 (permalink)
Member # 15945
I would rather nail my hand to a tree than spend 1 cent on a stock 4x4 steering box for that truck. DO NOT use the factory steering or track bar parts. They suck, big time!!!!! I know the tail case on the auto is different not sure about the output shaft.
Pens and Paper for peace, help our troops win hearts and minds! -
[url]http://www.freemanproject.org/about-the-project/our-mission[/url]
weedwacker is offline   Reply With Quote
Old 01-03-2005, 03:33 PM   #16 (permalink)
Member # 717
I have the 5spd..
Old 01-03-2005, 06:53 PM   #17 (permalink)
Member # 85
Pete
This I don't understand. My truck drives kick ass...
Old 01-03-2005, 10:11 PM   #18 (permalink)
Member # 2892
Send a message via AIM to Pavement Pounder83 Send a message via Yahoo to Pavement Pounder83
sucks u are down there there is currently a v10 4wd truck in the junk yard. complete fron end and all that suspension and everything in good condition.
Drew
Drew Reynolds
[SIZE="4"][COLOR="Red"]ECV 7-11[/COLOR][/SIZE]
1991 Toyota Ex Cab
All Stock
1993 Xr650L
[COLOR="Red"][URL="http://www.startprepared.com/forums/"]http://www.startprepared.com/forums/[/URL][/COLOR]
Isautia[88:54] Delta World, Town: PBB Broski
Pavement Pounder83 is offline   Reply With Quote
Old 01-04-2005, 06:51 AM   #19 (permalink)
Member # 4406
Some of the quality parts that are part of the OE suspension:
Ball Joints.
$300 non-servicable front wheel bearings, which are absolutely impossible to buy on Memorial Day (and in my case, required a service truck to remove while sitting on the side of the road).
Track bar with a ball joint at the top end, which often lasts as little as 20k miles.
Death-wobble prone Inverted-Y steering (except for '98-'99).
Crappy Brakes (before ~'01)
Pete
Old 01-04-2005, 09:58 AM   #20 (permalink)
Member # 40795
Why?
Take a look at the Dick Cepek (or whoever is selling it now) long arm kit. It comes with new locating brackets and arms - might even work on a 2wd frame. Might save some hassle in making your own mounts.
Brian
brian4wd is offline   Reply With Quote
Old 01-04-2005, 10:19 AM   #21 (permalink)
Member # 717
I had actually planned on doing that. I looked for that thread wher Lance had shown off his new lift kit. Something I was thinking about.
Also...
1) Trac Bar is easy fix with a 2003 and bracket.
2) Steering is an easy fix.
Not sure how to address the Bearings...
Old 01-04-2005, 10:52 AM   #22 (permalink)
Member # 40795
Lance's 'lift kit' ain't cheap and I believe it uses the stock control arms and locating brackets.
To address the unit bearing/wheel bearing use an older axle with regular wheel bearings and manual hubs. Dynatrac makes a manual hub kit for the '94-up front axle but it's expensive.
What's your plan for the steering? I have an '00 2500 4wd CTD and I haven't had any death wobble problems with it. I did have problems with a '96 2500 4wd 360 V8 truck though - caster adj solved the problem.
Any differences between a 2wd and 4wd frame?
Brian
Old 01-04-2005, 01:31 PM   #23 (permalink)
Member # 85
Ball Joints.
Pete
Ok, I guess I'm lucky cause my wheel bearings are fine, ball joints are fine, track bar lasted 60k, no death wobble at all, and brakes are great (have drilled, slotted rotors) oh wait...it's an '01
Another idea is...hold the bullshit... using a Dana44 front. I don't know what your intentions are with the truck but it sounded "tow riggish" and I know that if I had a D44 in mine it would be fine (till the 30lb boost 4WD launches) but with normal "get it out of the snow, tow down a snowy road" it'd be fine. That would take care of every problem noted above. Oh, an I'll be putting in an 03 Track Bar in mine when this one goes out as well.
Old 01-04-2005, 01:43 PM   #24 (permalink)
Mechanos's Avatar
Member # 6704
I'm not so sure about that. What's the weight capicity of a D44? My '01 CTD weighs in at 4200lbs on the front axle with me in the seat and a 1/3 tank of fuel. I'm not convinced that the D44 wheel bearings would last very long toting around that 1025 lb. engine mounted above them.
It's
IHeavy
aka TORC
KC0UIC
Nothing is foolproof to a sufficiently talented fool.
Mechanos is offline   Reply With Quote
Old 01-04-2005, 01:47 PM   #25 (permalink)
Member # 717
Hey, I think maybe I should have mentioned the 4.10s, Straight Pipe, BHAF, and Drag Comp...
