Member # 30045
Diesels in the winter
I've been thinking about getting a diesel pickup to use as a daily driver and tow rig, but at work there's nowhere for me to plug in a block warmer, and when I leave work in the morning, it's been around -10* out...
How do you guys deal with starting your oil burners up when it's cold out, and you're unable to plug in the block heater?
[url]http://omghi2.us/[/url] |
just say no to glow plugs... he he. i dont live in that cold a weather. but guys who do with dodges have no problems. run a good fuel conditioner. have a dual bat set up and cycle the grid heaters and should fire right up. jiMMy
RockZombie:68FJ40 LPG350/sm420/d300/d60/d70 |
Member # 5943
Location: Southeastern MN. (formerly near Chicago, I've ESCAPED!)
My 99 Dodge CTD works pretty well down to zero or so.
For an alternative to a plug in, look at http://www.webasto.us |
we haven't had a morning abouve approx 20-25 degrees in over a month, if i don't plug in, my truck will fire just fine if i cycle the key a few times, but usually runs rough for the first few min, like it's waiting to pick up the last cyl or two. the only time i've had a cold weather hard start was at approx 0 degrees, took a few min to get it to go, and when it did, it smoked and knocked pretty hard.
i haven't been using any standyne or fuel conditioner's until this last tank, it helps!
Thanks to the companies that make it happen: Bilstein Shock Absorbers, Trail-Gear, Trent Fab, PRP Seats, Raceline Wheels, PSC, MJ Motorsports |
i DD an f-250 with the 7.3L
strong batteries and it always starts, bitches a little for the first minute or two sometimes but it always starts. i'm considering a diesel fired coolant heater to get the engine up to temp faster, but it's for me, not the engine. the diesel takes a while to warm up those 4 gallons of oil without help. |
Member # 17313
My dad's 83' F-250 with a a 6.9 always started just fine at -40 with no block heater.
His 89' with a 7.3 is fine till around 0, then you need to plug it it in. After the -20, -30 mark, it needed ether at times to get it started. Everyone I know with newer PSD's and cummins have no problem getting them started at forty below, you just gotta plug them in. The diesel fired coolant heaters like mentioned above are getting popular aswell.
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion. |
Member # 30045
The problem is that it's gonna sit in the parking lot while I'm at work for 9 hours in below 0 weather without anywhere to plug it in. Is there an on-board solution to getting the engine warm, or keeping it warm so that it starts and doesn't damage anything (I'm a diesel n00b)? If not, I may have to go gas, just because of the nasty weather and lack of block warmer.
Member # 5943
Yes.... see http://www.webasto.us like I posted above. You're looking for the BlueHeat package.
You can set it to start the heater at a specific time, or remotely start it with a key fob. |
Super Moderator
Good batteries go a long way.
Why nowhere to plug in? You park that far from the house or something?
>David > 4x4Spot.com >It only hurts the first time you agree with me... >"A little nonsense now and then is cherished by the wisest men." |
Member # 2967
My dd with a C9 cat and it started today when it was 0 out. I usually park inside though at night.
Everyone said there would be bad days, I just never figured there would be this many. |
#13 (permalink) |
Fawkin Fordhead
I've had no problems with my PSD this winter, and there's been a couple days it was -30 out, and I hadn't plugged it in, BUT, I run 0W40 synthetic in there. Glow plug engines do tend to start better in the REALLY cold stuff, but, an intake heat engine will still start, they just are less happy about it. I've seen both start unassisted at -45 with the 0W40 in them.
A Webasto or Espar or such is NICE, but pricey.
96 F350 XL CC PSD/5 speed 4x4... New Tow pig in the making 96 F250 XLT Ex Cab PSD/5 speed 4x4... DD/Tow Pig 92 W250 LE, CTD/5 speed 4x4, tow pig/DD/snow pushin pig 86 F250... 460/T19/1345/D60/welded 10.25, 44 Boggers, reg cab, some junk... Build |
#14 (permalink) |
Member # 30045
Thanks for all the replies, but I think I'm just gonna go with a gasoline truck, considering I don't really need a diesel as a daily driver.
#15 (permalink) |
Member # 21766
Temperatures here get COLD. We just came out of two-week stretch where the temps didn't get above -25C. I always plug in at night with my timer set to come on about 4 hours before I start my '04 F250.
But I can't always plug in during the day, so what I do is hit the remote start a couple times throughout the really cold days just to cycle things. Heats up a cold motor and prevents it from getting too frozen throughout the long day.
Trail rig: Propane-powered Jeep CJ buggy w/454, TH400, Atlas, linked front and rear-steer Rockwells, 49" Iroks on 20" beadlocks. Street truck: 1970 5-ton M818 6x6 on 53" XZLs |
#16 (permalink) |
Member # 11903
My 04.5 CTD starts just fine every time in below 0 weather. My apartment has a deck so I can't plug in either. The F250 I had before this truck required a new glow plug relay every winter. Rude suprise when it goes out and you can't get it cranked. It seemed to do a good job of waiting till Jan Feb every year to go. My Dad's Dmax has been good as well.
84 Scrambler, Rockwells 44's etc Duct tape would cure cancer if we could figure out how to apply it |
#19 (permalink) |
Member # 20999
I never had to cycle my cummin's trucks more than once, becasue they have an intake air temp sensor, keeps it on as long as it needs it, i guess because down to -35* i have always been able to fire them even without plugging them in down at hunting camp and letting them sit for a week or so. i did carry a small portable torch for heating the fuel filter and lines for when i had #2 in my tank and it got too cold, otherwise i would just hold the throttle a little and keep the rpms up to insure that she didnt die out. 1000 rpms or so. oil be damned the engine lasted well past 400k miles in those kind of conditions like that for years. 15/40 rotella every oil change. i recommend plug in below 20 degrees just to be nice to the truck but its not necessary. i used to run 50/50 in the winter in one tank and then had 15 gallons of straight #1 in the front tank, if it was getting cold id flip the tank before i shut her down fill the system with #1 and i was good to go the next morning.
I AM ONE OF MANY WHOM WASHINGTON HAS CHOSEN TO IGNORE OR FORGET But i Vote GO UM Montana Griz "Jeep Lurker" ![]() KEEP REMEMBERING 9/11 Jeep with Rambler motor, SUA, front 608.9 and some bolt on stuff. I miss my old 4bt powered chief Support Frank the Tank Last edited by ddestruel; 01-25-2005 at 03:33 PM. |
#20 (permalink) | ||
Member # 6582
For you guys that think you don't need to plug your diesel in when it's cold. Try a few weeks of cold starts then run an oil sample and see what it says.
N.R.A. Life Member |
#21 (permalink) | |
'85 K3500 6.2diesel th400/203/205 d60 14b locked 4.10s 305/85-16 Coyotes hyd Koenig winch One ton or none! http://www.4x4support.com/ |
#22 (permalink) |
Banned
Member # 11268
I will be sending an oil sample into Blackstone Labs in a week or two. I was on a 5K mile drain interval, but in their last report to me, they said try 8K mile. That's this one.
I have a 98.5 24valve, and I had a mix of cold starts/plugged in starts. I'll post up any interesting results. |
#23 (permalink) | |
LMAO We have the same problems here to. Sometimes it gets down to about 25* at night!! But that is when it's REAL cold. On the down side though, I won't talk about our summer time temps.
06 Dodge Mega Cab 2500 4x4 CTD 325/610 6spd hand shaker, Smarty tuned! |
#24 (permalink) | |
Member # 10124
Any good websites for diesels? I'd like to keep this one in good shape for a lonnnnnnnng time.
I crashed that piece of shit...and then stepped away....... |
