ctd boost ? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-17-2005, 07:00 PM   #1 (permalink)
stone's Avatar
Member # 19678
Send a message via AIM to stone
ctd boost ?
how many lbs does a stock 94 push? i wired up my gauges and only get 16lbs by the gauge. i thouhgt it was more than that?
buggy V 2.0 in the works. 4.3 Vortech, propane, 4.7 case, th350, rockwells, 44's, all the fun bling
03 z71tahoe for all the hardcore stuff
stone is offline   Reply With Quote Quick reply to this message
Old 02-17-2005, 07:16 PM   #2 (permalink)
Member # 107
Send a message via AIM to The Jerk Send a message via MSN to The Jerk Send a message via Yahoo to The Jerk
you have an auto? i think the range for a stockish 94 is 15-18 ish. jiMMy
my Modded 92 auto hit 27 the other day goin gup a slight incline ont eh freeway. he he, jiMMy
RockZombie:68FJ40 LPG350/420/300/60/70
69FJ40 350/stock | 70FJ55 350/700r4/205 | 72FJ55 stock
The Jerk is offline   Reply With Quote Quick reply to this message
Old 02-17-2005, 07:42 PM   #3 (permalink)
Member # 26797
mine runs 38, but not stock!
Ryan
96zjlimited is offline   Reply With Quote Quick reply to this message
Old 02-17-2005, 08:21 PM   #4 (permalink)
Member # 14437
Mine's a '97 and IIRC stock should be 15-20. Mine however is not stock and see's 47 through my HX-55!
freds40 is offline   Reply With Quote Quick reply to this message
Old 02-17-2005, 08:29 PM   #5 (permalink)
stone's Avatar
Member # 19678
damn i have air intake, and straight pipe, i am going to do a 10lb plate and 3kgsk, will that add boost?
Old 02-17-2005, 08:42 PM   #6 (permalink)
Member # 107
more fuel = more boost. check your intercooler boots for cracks as well as snug up all teh clamps too. jIMMy
Old 02-17-2005, 09:58 PM   #7 (permalink)
Mechanos's Avatar
Member # 6704
If you have a wastegated turbo, all the intake, exhaust and fuel mods in the world aren't going to change the amount of boost. You'll have to make some mods to the turbo or the wastegate on the turbo in order for it to make more boost.
It's
IHeavy
aka TORC
KC0UIC
Nothing is foolproof to a sufficiently talented fool.
Mechanos is offline   Reply With Quote Quick reply to this message
Old 02-18-2005, 06:40 AM   #8 (permalink)
Member # 1860
stock is 15-20 or so.
mine with the mods will hit 38#'s of boost.
derek
the more i play with it, the bigger it gets...... my truck that is
derek is offline   Reply With Quote Quick reply to this message
Old 02-18-2005, 07:51 AM   #9 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
I can hit 38#'s on my 98 12v CTD - only mods are 4" exhaust, #10 plate, & AFE intake kit... Kinda scary really
>David
>It only hurts the first time you agree with me...
>"A little nonsense now and then is cherished by the wisest men."
DRM is offline   Reply With Quote Quick reply to this message
Old 02-18-2005, 08:40 AM   #10 (permalink)
TR
TR's Avatar
Member # 2877
drms turbo is wastegated to 25 psi or so and like he said he is pushing 38 lbs, The wastegate can only dump so much air.
Penn State study finds that heavy drinking is 100% easier than giving a shit
TR is offline   Reply With Quote Quick reply to this message
Old 02-18-2005, 09:10 AM   #11 (permalink)
Mechanos's Avatar
Member # 6704
Yeah, you have point there.... up to the physical limit of the wastegate, it will keep the boost at a preset maximum. Once you exceed the physical capability of the wastegate to dump the excess pressure, you will continue to build boost.
It's
IHeavy
aka TORC
KC0UIC
Old 02-18-2005, 01:44 PM   #12 (permalink)
Eskimo's Avatar
Member # 10429
With the plate, comes a bleeder valve elbow to keep the wastegate closed longer...
Stone's numbers are right on for a stock 94.. the #10 will give you the added fuel and boost..
You wanna keep the turbo around 36-ish psi max, for efficiency, from what I've been told by Piers and the likes..
FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/ORI's/42's - Sold.
Eskimo is offline   Reply With Quote Quick reply to this message
Old 02-18-2005, 07:00 PM   #13 (permalink)
stone's Avatar
Member # 19678
rich i am haveing a nightmare time with my tranny. i took it to the dealership because it the tranny shop guy was out of ideas. dealership said i needed a new computer. so i got one. same problem. so to date i have bought 2 trans temp sensors, 1 tps, 1 computer, and a shit load of tylenol for the headache! tonite i hooked the tranny temp gauge up and it bever passed 150, and that was driving hard through a long neighborhood, stops every block. jody at wnc has been helping me out alot with info from his tech there at the dealership in asheville. and he thinks i am getting fucked by metrolina dodge on the computer shit. so after 1700 for a rebuild, 275 for tps, 75 in temp sensors, 150 in computer, and 190 for a miss diagnosis from the dealership who said fuck off since i didnt let them plug the computer in, i am out of ideas. what would you or anyone else suggest?
94 ctd, auto, driving down the road trannytemp light comes on and shifts me out of o/d no matter what the speed. then will engauge again after a while, only 3 seconds later its back out of o/d. temp according to the strip off the pan hasnt past 190. and by the autometer gauge i havent passed 150. but the sensor trips at 280! any clues? thanks fellas this is bleeding a poor college boy dry!
Old 02-18-2005, 07:27 PM   #14 (permalink)
Member # 107
dang, im sorry bud, im sure the 92's are different but my tps was crapping on me. cruising at 60ish mph it would kick out of o/d then go back in constantly. befor ei tore into it i took apart every electricle connection dealing with it and the trany and re lubed it all with dialectic grease. i have been problem free for 5 months now.
is it possible that you have a break in a wire somewhere inside teh wire coating that woudl only bee seen by a meter?? jiMMy
Old 02-18-2005, 08:04 PM   #15 (permalink)
Eskimo's Avatar
Member # 10429
you've got a wiring problem somewhere... pulling the TPS wiring out of the harness will help, but I'd bet you've got an actual broken wire or bad ground somewhere...
Grab a multimeter, and probe the wiring coming from the trans... there can't be that many on a RH.. connect one probe to the tranny computer end of the wiring, and the other end down at the connector to the trans, and shake the wiring...
Or, depending on how many wires there are, temporarily jumper the factory wiring.. it's GOTTA be the wiring to the sender that's triggering the fault...and the O/D off is a safety precaution I guess when the trans gets too hot...
Old 02-18-2005, 10:53 PM   #16 (permalink)
stone's Avatar
Member # 19678
yeah i am to the point it has to be the wiring from the temp sensor. so tomorrow i am sure yall can guess what i will be doing!
Old 02-19-2005, 02:54 PM   #17 (permalink)
stone's Avatar
Member # 19678
ok here is the latest. i ohmed all the wires that i thought could be part of it and found no problems. so i decided since it has a new computer maybe the old sensor is toast and to get a new one. i went to the parts house and got it. put it it and drove. i have driven 15 miles and no problems. even cold it was shifting better than before. i even sat a powerbraked it 2 times to see if i could heat it up enough to enduce the problem, didnt happen. but it does make some nice burnout marks! so i dont know how confident i am in it being fixed but its the first 15 trouble free miles in over 2 months!
