Drilling for Pyrometer - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-02-2005, 09:07 AM   #1 (permalink)
jwag's Avatar
Member # 7638
Send a message via AIM to jwag
Did you remove your exhaust manifold?
I am getting ready to install an EGT gauge and my assumption was that I had to remove the manifold to ensure that no chips made their way to the turbo; but now i have read a couple of installation articles that don't remove it Seems to me you are asking for trouble by not taking the time to take it off.
Is it better to have the pyrometer on the cast housing or weld a bung on the pipe going to the turbo?
Thanks
jwag is offline   Reply With Quote
Old 05-02-2005, 09:10 AM   #2 (permalink)
Member # 1860
i didnt remove mine. just greased the drill bit and tap and cleaned and regreased a lot.
then ran a magnet around the hole for a while to get the big chunks.
that was like 20,000 miles ago and no problems so far.
derek
the more i play with it, the bigger it gets...... my truck that is
derek is offline   Reply With Quote
Old 05-02-2005, 09:30 AM   #3 (permalink)
Member # 11256
if you are super anal you can remove the exhaust manifold, but honestly there is no good reason to. If you take out the chips while you're drilling and pause before you break all the way through and clean out everything you're only going to have a couple little chips and the second that you start the engine it's going to blow them all out through the turbo. The miniscule amount of metal shavings that goes through the turbo isn't going to hurt it.
As for where to put the pyro the closer to the engine the more accurate the temperatures. However the difference between putting it on the manifold (that's where I have mine) and putting it on the pipe to the turbo probably won't be very large.
-ben
m016324 is offline   Reply With Quote
Old 05-02-2005, 09:39 AM   #4 (permalink)
RE:Todd's Avatar
Member # 422
derek
Grease is your friend
Todd Steele
TINBENDERS
Formula Toy #006; Thanks to Deaver Spring, High Angle Driveline, Longfields, Rock Buggy Supply, PRP Seats, Marlin Crawler, Coast Motor Supply and RockStomper.
[url=http://www.tinbenders.org]TinBenders.org[/url]
RE:Todd is offline   Reply With Quote
Old 05-02-2005, 10:23 AM   #5 (permalink)
Joey D's Avatar
Member # 20053
I have read that leaving the motor running while you drill and tap is the way to do it, unless you remove the manifold.
98 K2500 SAS dynatrac pro rock 60, ORD high steer, RCV CV's, arb's front and rear, 4.56 gears
06 D Max Express
Joey D is offline   Reply With Quote
Old 05-02-2005, 10:45 AM   #6 (permalink)
Member # 20025
Send a message via Yahoo to pimptony
I dont know about leaving it running but I greased, drilled, regreased, finished and inspected then tapped slowly. Its been fine for 10K miles. I have read that post and pre temps differ by about 200 degrees depending on the post location. FYI.
[COLOR=DarkOrange][I]I really hope that God has the capacity for forgiveness that Christians claim, because I am going to test the absolute outer limits.[/I][/COLOR]
pimptony is offline   Reply With Quote
Old 05-02-2005, 03:59 PM   #7 (permalink)
Member # 1708
I just left the motor running and used grease on the bit with no problems. be sure to wear some safety glasses if you do it while running.
1986 4-runner sas,v6rear,4.88s,dual cases w/ cust. homemade xmember,Marlin Hy-steer, some other nifty shiznit,
98.5 Dodge Ram 2500 CTD 4x4, 4" exh, bully box, big fuel kit airaid intake,
02 YZ 250
GOT BEER? NORCALBMX.COM
fire_beer_mayhem is offline   Reply With Quote
Old 05-02-2005, 04:54 PM   #8 (permalink)
TR
TR's Avatar
Member # 2877
Send a message via ICQ to TR Send a message via AIM to TR Send a message via Yahoo to TR
i just did mine this past weekend and i started with a greased 5/32 bit then a greased 5/16 bit and ended with a greased 7/16 bit and greased the tap up really good. then i just fired it up and the turbo is still spinning
Penn State study finds that heavy drinking is 100% easier than giving a shit
TR is offline   Reply With Quote
Old 05-02-2005, 07:29 PM   #9 (permalink)
Member # 12387
I drilled mine until I almost broke through, cranked it up and finished drilling and it blew all the chips out. I then greased the tap and finished it up. I did regrease it twice. Had no problems so far and dont plan on any either!!
Brad
bchesley is offline   Reply With Quote
Old 05-02-2005, 07:58 PM   #10 (permalink)
Member # 15945
I guess that makes me one of the anal retentive type. I pulled the turbo off pushed it over after loosening the down pipe, cleaned it out. Only takes a little longer. Stuff a rag past the drill point, vacume out pull rag, send a magnet down just to make sure.
Pens and Paper for peace, help our troops win hearts and minds! -
[url]http://www.freemanproject.org/about-the-project/our-mission[/url]
weedwacker is offline   Reply With Quote
Old 05-03-2005, 07:14 AM   #11 (permalink)
thump93yj's Avatar
Member # 14874
4 bolts, loosten the turbo enough to slip some cardboard/posterboard or something in there and then vacuum the shavings out when your done.
Not that much extra effort to be safe.
-clint
Secret black text says... Buy my Stuff!
For Sale: Driveshaft
thump93yj is offline   Reply With Quote
Old 05-03-2005, 09:02 AM   #12 (permalink)
jwag's Avatar
Member # 7638
I just ordered the gauges from John at Diesel Performance Shops and he confirmed that he leaves the engine running while drilling the manifold. The 20 or so psi of pressure pushes any chips out as you are drilling. He also sent a picture showing where to drill for a boost gauge on an LLY Duramax. Great guy to deal with.
Old 05-03-2005, 08:13 PM   #13 (permalink)
CTD600's Avatar
Member # 34536
Used grease on drill bit and tap last weekend. used magnet to clean up any leftover chips. no problems
CTD600 is offline   Reply With Quote
Old 05-03-2005, 10:15 PM   #14 (permalink)
Member # 14836
Ditto, just use the oil and magnet.
Wildjeeper is offline   Reply With Quote
Old 05-04-2005, 06:23 AM   #15 (permalink)
Member # 7163
Could hold a shop vac there while you're drilling. I'd still crack the bolts on the turbo and put the paper or cardboard in there as mentioned.
Oxjockey is offline   Reply With Quote
Old 05-04-2005, 09:20 PM   #16 (permalink)
Member # 693
Exactly what I did. I'm ususally the better safe than sorry type.
46 2A
Jeepdude_Jay is offline   Reply With Quote
Old 05-06-2005, 06:18 PM   #17 (permalink)
Member # 27843
when i did mine .. my wife controoled the shop -vac while i driller .. and just before i broke through i duct tapped my tailpipe and quickley started the truck and proceed to drill .. i am telling you i had a blast of exhaust through that hole !!! i am sure and filling came out !! simple stuff !!!!
Good luck
1987 sas 4runner GEARED LOCKED AND READY FOR ROCK
2004.5 Dodge 3500 tow rig
A friend helps you move ......
A good friend helps you move a body ...
swansong04 is offline   Reply With Quote
Old 05-07-2005, 10:10 PM   #18 (permalink)
Member # 39153
I magnatized the drill bit, then put a shop vac on the whole. Then tapped it with grease, shop vac again. Just to be safe I magnatized a small allen key and swished it around in the whole till there were no more shavings. I've done it on 3 different trucks. No problems.
dirtydury is offline   Reply With Quote
Old 05-08-2005, 06:17 AM   #19 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
Well, cracking the turbo bolts on my 1998 truck with almost 300,000 miles on them looked like potentially more trouble than it would be worth.
>David
> 4x4Spot.com
>It only hurts the first time you agree with me...
>"A little nonsense now and then is cherished by the wisest men."
DRM is offline   Reply With Quote
Old 05-08-2005, 07:06 AM   #20 (permalink)
Member # 107
Send a message via AIM to The Jerk Send a message via MSN to The Jerk Send a message via Yahoo to The Jerk
3 days of pb blaster should do the trick
RockZombie:68FJ40 LPG350/sm420/d300/d60/d70
The Jerk is offline   Reply With Quote
Old 05-11-2005, 11:45 AM   #21 (permalink)
ROCK & ROLL OFFROAD
Member # 3906
Send a message via AIM to Jeepmangled87
just did mine last night, lots of greese, and the Edge instructions, say to start the motor right after you drill and let it run for 15 to 30 secs.
Jeepmangled87 is offline   Reply With Quote
