Member # 6136
Why cross tie-down straps
I see a lot of rigs tied down with the straps crossed, you know, right rear of the vehicle to left rear of trailer, and so on. What's the benefit of this?
I like potatos |
Member # 17313
no clue on straps.. those are for tieing down rubermade totes..
![]() But the reson for crossing your CHAINS to your rig, is to help keep it centered on the deck of the trailer.
A recent survay of over 1000 trailer parks in the southeast found the 350 chevy out numbered the mullet by nearly 4:1, draw your own conclusion. |
Member # 11921
In order to apply force equally in three dimensions, (given the right rear, you want to pull down, left and back) you ideally would want it at 45 degrees to all planes. In order to get the left to right angle crossing gives you more distance to work with. Its just a geometry thing, some people think its required, others don't. I like to on mine, but I also use straps, so I guess I must be wrong.
My build thread: [url]http://www.pirate4x4.com/forum/showthread.php?t=508537[/url] |
I don't know that one way is any better than another....I tie down the frame because I don't like bouncing going on back there. I guess one way of looking at it is, where does the factory locate the transport brackets?
Sam Towel Boy for Team Deliverance BACON - [URL="http://rrorc.com"]The Fuel of Team F.A.T.[/URL] [URL="http://home.bluemarble.net/~n9emz/Vehicles/gaymobile.jpg"]Primary Tow Rig[/URL] Last edited by n9emz; 11-01-2005 at 10:56 AM. |
Member # 1757
I recently switched from strapping the frame down to a chain over the rear axle and ratchet straps to the front axle. I had had one or two times where the ratchet straps had come off on rough roads. It's been fine since, although I haven't had an emergency lane change under hard braking yet either.
Chris |
Super Moderator
I can tell you one thing - if you lose one strap or chain while crossing them you pretty much just defeated the entire system. At least if you tie down in a "burst" pattern and lose one of the 4 corners, you still have the opposing corner on the other end to keep things relatively snug.
>David > 4x4Spot.com >It only hurts the first time you agree with me... >"A little nonsense now and then is cherished by the wisest men." |
#9 (permalink) | |
Non-Lemming
Member # 840
Oh B.S. on the dissing straps. Proper straps, properly attached work just fine. |
#10 (permalink) | |
Member # 17313
#11 (permalink) | |
Non-Lemming
Member # 840
I've heard people claim that attaching the straps or chains to the body keeps the load (vehicle) more stable on the trailer. Well, I have both a SOA CJ7 and a rock buggy that I have trailered and I always strap them down by the axles. Both of them are very softly sprung and I don't feel them bouncing around at all. I've had NO stability problems. It's been a non-issue. |
#12 (permalink) |
HeiserOilMotorsports
My jeeps frame has holes perfect for the hooks in the straps to go into, so I'll attach the STRAPS (no chains for me) to the frame front and rear, and cross them as well... IF I can ever get my damn trailer done.
Scott
#14 (permalink) |
Member # 56574
trailer tie down
I have heard bad news in the past about strapping your axles down with CHAIN. When I loaded my 5600 lb scout down on a trailer, I did four individual chainbinders, 1 per corner, and bought nylon straps to wrap around the axle tubes. I believe Calif requires four tie down points.
63 Scout 80, 350 sm465 klune 205, 1 tons, 40" Mtr's |
#15 (permalink) |
OK, webserver is back up....
![]() I use straps around the axle and then chains crossed in the back. The hanging chain is just the excess held up with a bolt. ![]() 3500lb WLL hooks on the trailer end ![]() And combo axle ratchet straps in the front, also crossed. My junk doesn't budge at all once tightened down.
Unwheeled |
#16 (permalink) | |
Body can bounce around and let the link loosen up/un hook. The axel dosent bounce. I then put 2 strap on each side on the rocker guard to control boucing/sway of the body.
[URL=http://www.xfaktor.net]XFaktor.NET[/URL] Last edited by xfaktor; 11-01-2005 at 05:37 PM. |
#17 (permalink) |
Member # 33536
might want to look at professional auto transporters. they cinch the vehicle down to the bumpstops or pretty darn close to it. you never see a car tied down on a large transporter by its tires or axles. even if you cant see up into the underside of the car, the wheels will be stuffed into the wheel wells, showing that the body and frame are pulled down tight. Not saying that there is not any other way. Just looking at the people who make a living doing it day in and day out all year...
#18 (permalink) | |
X2 I have a set of mac's straps, VERY quick and VERY stout. Reinforced where they wrap around the axle.
93 YJ, SOA. 37's locked '08 6.7L 4 door 4x4 LB. Mineral gray. Lorenz bilstein leveling kit. SRT hood. AFE CAI. Mag-hytec's. SMARTY ME. 120HP injectors. II stage 2 turbo. |
#19 (permalink) | |
Member # 1757
#20 (permalink) |
I use chains from the front and rear bumper to compress the suspension and keep it tight.
Then a pair of straps from the axles, all of them in the >< pattern. Never had a problem with it. It keeps the vehicle from shifting from one side to another...
[URL="http://www.Jeeperos.com/foros"]Jeeperos.com[/URL] Well, the guy wants to run for president, he thinks Moby Dick is a venereal disease. |
#21 (permalink) | |
Member # 10429
I chain the rear axle in a X, strap the front axle, and then run straps to the sides of the rig (rock rails usually) to control the body roll, but they are not cinched down really tight, just enough to take the slack out of them. My 3500 doesn't care about the rig flopping around on the trailer, but it's just more secure. I have had to perform an evasive maneuver (thanks to my dumb ass being inattentive) with the rig strapped down like this, and if the frame wasn't held in place at all, I don't think the trailer would have tracked as well because of the weight shift. basically, it was nail the brakes as hard as possible to scrub off speed, then release, steer around the stopped car in front of me (that I didn't notice because of said dumb-assness), then back on the brakes again hard once straightened up. A couple of the hot shot guys I know/talk to have been using straps over the tires of cars, and are very pleaseed with the results.. That's how my Audi was transported when I sold it, and the body kit wouldn't have allowed using the frame tie-downs anyway. I think Porsche and Ferrari both say to not tie down to the frame, instead, use straps through the wheels? Anyone know for sure?
Rich Q. FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/ORI's/42's Last edited by Eskimo; 11-02-2005 at 05:51 AM. |
#22 (permalink) | |
Super Moderator
#23 (permalink) | |
I agree One of the most important things is to strap the outer most part of the axle tube then go to the other side of the trailer The advantage to the x pattern is to hold the rig from moving side to side and front to back
#36. If I wanted to drive a foreign 4x I would move to another country. [color=orange]80 cj 5 104" wb rockwell 16"kings 39.5 tsl[/color] AND 1995 Hummer H1 Wagon [SIZE="3"][url=http://search.ebay.com/_W0QQsassZhumvee4x4QQhtZ-1]buy my stuff[/url][/SIZE] Last edited by 4x4extreme; 11-02-2005 at 08:32 AM. |
#24 (permalink) |
Banned
Member # 33748
Seems to me strapping down the axles is the most secure (impossible for the vehicle to "hop" because of suspension movement.)
Then a couple of light duty straps run to the sliders to keep the body from bouncing around if you notice that it is prone to do so. I think the "X" pattern would be the worse placement IF you had a tie down failure. The "starburt" pattern anchored well away from the vehicle (as opposed to straight down) to me makes the most sense. Also, since I chose a short trailer (14') I run my front axle straps/chain to the rear deck rings and the rear axle straps/chain to the front deck rings. Again, the greater the separation (within reason) the more secure the load. Just my .02
