Member # 49159
Cummins powerd school bus?
Any of you guys know if any school manufactures made a short school bus w/ a cummins. I'm playing w/ the idea of a tow rig/ rv type of build up. Maybe rockwells and 44's for cruisin glamis later Any one done this or have any input?
Member # 62687
I bought a short bus a few months ago, to use as a tow rig/rv for my jeep.
If you're looking for a 5.9 cummins, you'll find a lot of Blue Bird buses that are equipped with them. Unfortunately most of them are the flat-nose buses, and you might be looking for something a bit shorter than that, older than that, or more of a "conventional" type. International provided chassis for some 4x4 buses. These generally have diesels (7.3) or gas (345). Most short buses are going to have gas engines or ford & international diesels. Dunno about the larger cummins - 8.3 is it? - so, sorry if thats what you're looking for. Older ones (pre 80's) will be all gas (my ford has a 390). One thing to keep in mind, my short bus (1970 superior body, on a ford frame - less than 20 feet long, 2 inches shorter than my x-cab longbed F-250) weighs 17,600 pounds (This is what I was told by the tow truck driver - I haven't gotten it weighed yet). I expect that fully loaded, wet weight, with jeep in tow it will be pulling about 25k, assuming that 17k was accurate. I want to do a cummins swap eventually (beyond my budget right now). |
Member # 52361
I know alot of the flat nosed blue birds run 3208 cat turbodiesels with allison trannies, I love the cummins for a P/U truck, but for pulling 10tons, I'd check out the cats. You can get a big bus for about $5k with this drivetrain. You could cut it down to shortbus size, but personally I'd like to make a toyhauler out of a long one, It'd be sweet to have a garage as the back half of a RV.
Member # 62687
I haven't used it yet. We pulled the engine and have one waiting to go in next week, I hope. It will be a gasser 390.
I'm worried about having to pull 24-26k with it though, that's a lot of work for the engine. |
#6 (permalink) | |
Gearing is your friend, and you are not going to do anything fast.
Ask me anything about a Cummins, I stayed at a Holiday Inn last night. |
Member # 62687
I know, but it will make a fun toy...it's been a great project.
Bringing it home I got it up to about 65-70 before it just smoked too much. It had a 330MD in there. It should be able to run 60-65 while towing. Even 55-60 is fine by me. |
This is my buddy's bus he has a gooseneck hitch in it. He also has future plans of a front axle with at least 44's on it to play in the dunes.
I realize its not the short bus but I figured everyone might like this.
Kristen 85 chevy, 350, T400, d60, corp 14 -4.56 gears, locked front & rear with 44" boggers 84 Toyota 02 F250 Diesel |
#12 (permalink) |
Member # 4406
FWIW, the local school district has newer full-length conventionals with the 5.9 Cummins, I think they are 275 hp and a Freightliner Chassis. From what I heard they went this route at least partially due to consistently poor warrenty service from the local Navistar dealer.
Pete
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways , beer in hand, body thoroughly used up, totally worn out and screaming "WOW, what a ride." |
#14 (permalink) |
Member # 27082
www.nwbus.com is here in washington, they might be able to help you find what you want
