Member # 19733
NV 4500 5speed lube
How important is it to run the Dodge NV 4500 gear lube. Their is a warning on the trans not to use anything other or Eminent trans failure will happen. At 20 dollars a quart trans fluid changes are pretty expensive. Is anybody using anything else?
Mike
Yes, I drive a big ATV http://www.rpm4x4.com/specs-mike.shtml You dont know if your wrong till your upside-down. |
Non-Lemming
Member # 840
You DO need to use it, or an equivalent lube. If you don't the syncros will die at an early age.
Look here for more info. http://www.pirate4x4.com/forum/showt...00+AND+rebuild Last edited by SanDiegoCJ; 01-06-2006 at 12:35 PM. |
Member # 19733
Thank you very much. Thats definately good info. I will spend the xtra money on the OE lube.
Mike
#6 (permalink) | |
Member # 2632
Two stock Fords. Need to get a wheeling rig sometime. |
Member # 4406
I bought fluid for mine from a place called Standard Transmission (or something like that) in Texas, it was the cheapest I could find it. They buy it buy the drum, and ship it to you in a 1-gallon container.
Pete
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways , beer in hand, body thoroughly used up, totally worn out and screaming "WOW, what a ride." |
Member # 27445
Fluid
Just changed mine. I bought it from the dealership for 15 a quart. Don't put anything else but what is required. The syncros will tear up.
[COLOR="Navy"][SIZE="4"][B]GDI4x4.com[/B][/SIZE][/COLOR] [COLOR="Navy"][SIZE="4"][B][URL="http://www.gdi4x4.com"]http://www.gdi4x4.com[/URL][/B][/SIZE][/COLOR] |
Member # 752
It is very important to use the correct fluid on the 4500. The Product is called Castrol "Syntorq" . Dodge part #4874459 , GM part #12346190
got a jeep and a yota. I hate myself.......Wrong Way Wheelers. Camino, CA |
