#4 (permalink) | |
Member # 37519
It's a 20 inch drop adjustable
[COLOR="Black"]..............[/COLOR]/´¯/) [COLOR="Black"]............[/COLOR],/¯../ [COLOR="Black"]...........[/COLOR]/..../ [COLOR="Black"].....[/COLOR]/´¯/'...'/´¯¯`·¸ [COLOR="Black"]..[/COLOR]/'/.../..../......./¨¯\ [COLOR="Black"].[/COLOR]('(...´...´.... ¯~/'...') [COLOR="Black"]....[/COLOR]\.................'...../ [COLOR="Black"]......[/COLOR]''...\.......... _.·´ [COLOR="Black"].......[/COLOR]\..............( [COLOR="Black"].........[/COLOR]\.............\ |
#6 (permalink) | |
Member # 34555
That's what I was thinking. Soft. flexy long travel suspension, no sway bar, lots of leverage......
Run when you can, walk if you have to, crawl if you must; never give up. |
Member # 6704
Raise the trailer or the tounge of the trailer.... or lower the tow vehicle.
It's IHeavy aka TORC KC0UIC -.- -.-. ----- ..- .. -.-. Nothing is foolproof to a sufficiently talented fool. |
#8 (permalink) | |
Member # 37859
You would normally have bars going from the bottom of the hitch (ball mount area) and then diagonally up and bolted to the frame. If you go that way it's just as strong if not stronger than a regular set up. |
#9 (permalink) | |
Member # 53528
have you ever tried moving a rock with a big long stick? somone needs to learn the definition of leverage i wouldnt tow more then 2500 pounds with that thing and id still be worried
#10 (permalink) | |
Non-Lemming
Member # 840
Yup. I won't use anything more than a 6" drop. |
#12 (permalink) | |
Certainly nothing much taller than stock 4x4. |
#13 (permalink) | |
Banned
Member # 11268
#14 (permalink) |
Chubby Chaser
If you 'need' a 14" drop hitch tour truck is way too tall, but I bet it looks sweet crusin the mall
Eric Anderson TIN BENDERS Hendrix XR Chassis #001 Ultra4 #66 4Wheel Parts, Raceline, PSC, Bilstein, Marlin Crawler, Smittybilt, HendriX, PacificFab, G2 Axle, PAC Spring, G&J, MAXXIS Roxy's in the industry and I'm a sponsored professional driver. The two of us together make a powerhouse. Accepting the things I cannot change. |
#15 (permalink) |
Member # 24973
Valley Spring Service makes some huge drops. I don't know what they're rated but I know of quite a few guys in Texas running them. I think they start around $300.
![]() http://www.valleyspringservice.com/images/photo215x.jpg
75 Bronco 02 Superduty |
#18 (permalink) |
Member # 2895
have 8" lift on my power smoke with 38s use it for towing my 24' boat 6000lbs
found drop hitch out of Portland Oregon professionally made this way if it brakes i will get a NEW boat!!! |
#20 (permalink) | |
Banned
Member # 11268
#21 (permalink) |
Member # 49181
I'm not even going to get started on this subject again.
There's my .02
AJ's 4x4 (530) 227-2969 BSW Racing, CalRocs, Super Mod #12 Driver: Aaron Whitehead Spotter: Adam Kovarik Thanks to: Raceline Wheels (800)529-4335 Hutchins Auto Repair (530)221-5113 Check out PARAphernalia GEAR for 550 Paracord and items |
#24 (permalink) | |
Cuts the capacity of the receiver in half? |
