Good place for siding for enclosed trailer? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-24-2006, 06:26 PM   #1 (permalink)
Member # 8977
Building a 25' gooseneck and want to make it an enclosed trailer with bed up front.
Where can I order siding from? I don't care if it is smooth side or not.
Thanks,
Chris
ZJSAMPLE is offline   Reply With Quote Quick reply to this message
Old 05-24-2006, 08:27 PM   #2 (permalink)
Guest
Member # 7938
Thanks,
Chris
Got some place close that sells aluminum? White 4x8 sheets go for $50 here in KS.
7938 is offline   Reply With Quote Quick reply to this message
Old 05-25-2006, 05:08 PM   #3 (permalink)
Member # 2463
United aluminum up on 1-17 and Indian school has a lot of stuff. I know they had sheets last time I was in there, the ones that interlock. 602-263-0834.
pmurf1 is offline   Reply With Quote Quick reply to this message
Old 05-26-2006, 07:30 AM   #4 (permalink)
yager's Avatar
Member # 10695
Send a message via AIM to yager
curious as to how it will be contructed ?
metal frame with plywood then glue alum to it ?
can you buy the cool corner rounded pieces somewhere?
any pics ?
-mike
Mike Yager -
- Ecotec, Toy axles etc..
Stroke - Coumadin(warfarin) - INR - Heart Valve - Ask me (true story)
yager is offline   Reply With Quote Quick reply to this message
Old 05-26-2006, 07:43 AM   #5 (permalink)
ibrocun's Avatar
Member # 26196
Send a message via Yahoo to ibrocun
any pics ?
-mike
X2 I always thought the aluminum sheets were just riveted over eachother with some caulk between them where they overlap.
ibrocun is offline   Reply With Quote Quick reply to this message
Old 05-26-2006, 07:07 PM   #6 (permalink)
Member # 8977
any pics ?
-mike
Not exactly sure how it will all be done. Right now I have a bare flatbed frame. I will try and take pics during progress.
Old 05-27-2006, 05:55 AM   #7 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
Take a look at this stuff: http://www.alpolic-usa.com/Products/ACM.html
Around here the local glazing company can special order it at about $3.50 per square foot. It is structural in the 4mm and 6mm depending on support spacing, though. Wouldn't need to affix it to anything other than the frame.
94 GMC 6.5TD K1500 Yukon SLE / 93 Chevy 6.5TD K2500
85 Toyota 22R RN60 4x4
PAToyota is offline   Reply With Quote Quick reply to this message
Old 05-27-2006, 09:35 AM   #8 (permalink)
Urban Wheeler's Avatar
Member # 26369
Send a message via Yahoo to Urban Wheeler
Yes, that is the way semi trailers are built, buck riveted to the posts and caulked before assembly to seal it.
Maybe you could buy a van body and bolt that on, or a semi sleeper cab
Urban Wheeler is offline   Reply With Quote Quick reply to this message
Old 06-02-2006, 03:47 PM   #9 (permalink)
Brutpwr's Avatar
Member # 481
We got our white coated aluminum in 8 ft wide rolls from a place in Hollister CA. That and white powdercoated rivets and some polished stainless steel trimming and we were good to go!
Jason
Brutpwr is offline   Reply With Quote Quick reply to this message
Old 06-02-2006, 06:51 PM   #10 (permalink)
Member # 15945
I have been pondering constructing a box for the front of my gooseneck also. I was thinking about using 4 ft wide sheets of painted galvalume (sp?). It comes in flat sheets and is rolled for use in roofing so some companies that sell the roofing will also have large rolls. Best part about this stuff is it cheap.
weedwacker is offline   Reply With Quote Quick reply to this message
Old 06-27-2007, 02:36 PM   #11 (permalink)
Member # 8977
Jason
Do you remember the name of the place?
Do you have a place that sells the flat stuff? All I can find is the corrugated stuff.
Old 06-27-2007, 06:21 PM   #12 (permalink)
Member # 71185
A few years ago I helped a friend reside a 36 foot gooseneck, after a lot of searching we found the best price at a sign shop for alum. this was 4x8 sheets. We ended up having to order ours from a trailer shop because haulmark used 49" wide sheets
We used stainless screws with a button head to screw it to the framework.
I talked to a friend just after we finished that was building a hauler out of a semi and they were useing a one piece fiberglass side panel that they could glue over there plywood sides. The fiberglass must have been pretty thin b/c it was shipped rolled up. I have lost touch with them and have no idea how it worked or if they ever finished it, sorry.
Brewchief
brewchief is offline   Reply With Quote Quick reply to this message
Old 07-01-2007, 12:29 PM   #13 (permalink)
Brutpwr's Avatar
Member # 481
Don't recall the name of the place but I've left a message with a friend so hopefully he'll remember... I'll should be able to get the name one way or another. I may go riding at Hollister Hills OHV park later today so I may be able to swing by the place and get the name that way lol!
Jason
Old 07-01-2007, 02:32 PM   #14 (permalink)
Member # 11016
My father built a neat little camper a couple years ago. He purchased pre painted aluminum sheets from a local trailer dealer for reasonable money. Might want to check it out.
ALEX Bronco is offline   Reply With Quote Quick reply to this message
Old 07-02-2007, 11:06 PM   #15 (permalink)
Member # 70933
Check with local pole barn suppliers. We get them to sell us the sheet metal the form into the raised panel siding (barn tin) before they send it thru the rollers. They get it in huge rolls so they can cut you whatever lenght you like..
Tyler
Rockrunner86 is offline   Reply With Quote Quick reply to this message
Old 07-03-2007, 06:57 AM   #16 (permalink)
Trailer Guy's Avatar
Member # 49181
Just get with a local trailer shop that sells enclosed trailers, they should be able to order the flat sheets in many different colors. Much of it does come 49" wide, this is so that it will over lap to help seal. You can use a thin double sided sealer tape, or caulking to make the seal. Instead of rivets, use a self-tapping screw. Most enclosed trailers use them. They look like a torx head screw, but a square bit is what really fits them. The alum. sheets go directly over the steel uprights on enclosed trailers with the plywood inner wall on the inside of the uprights. This creates a small space between the wood and the siding. This can be used to add insulation if you wanted.
Oh, most enclosed trailer sales yards can order the sheets for you, but understand that the manufactures usually only ship the sheets inside of the trailers so that they don't get damaged. So be sure to ask the dealer when they are getting their next load of trailers. You can also get the little screws from them, and most of the manufactures parts dept.'s can also get you the square bit if you needed it.
Better to die fighting for freedom then be a prisoner all the days of your life. -Bob Marley-
Most people do not really want freedom, because freedom involves responsibility, and most people are frightened of responsibility. -Sigmund Freud-
Trailer Guy is offline   Reply With Quote Quick reply to this message
Old 07-03-2007, 03:17 PM   #17 (permalink)
Member # 613
might also try a roundy round racecar fab shop. I seen some at a buddys shop in white red and blue colors. They use it to make the body panels out of.
odee is offline   Reply With Quote Quick reply to this message
Old 07-10-2007, 12:36 AM   #18 (permalink)
Brutpwr's Avatar
Member # 481
We did not get the siding in Hollister--got confused I think we got windows in Hollister... The place is in Salinas, Ca and is called Valley Fab. I can get the phone # if you can not locate it.
Jason
Old 07-11-2007, 05:58 PM   #19 (permalink)
Member # 15945
Benton metal depot in Statesboro Ga. Most the flat stuff is pressed to make the corrugated stuff.
Old 07-11-2007, 06:57 PM   #20 (permalink)
Member # 8977
I found a place that sells materials for signs. They can get 4'x10' sheets of polar white .040 aluminum. If you order more than 10 sheets the price is only $53/sheet. I went with them. I should have it by friday.
Old 07-13-2007, 06:24 PM   #21 (permalink)
Member # 8977
Just got to my house. The sheets look great. Far cheaper than buying from an actual metal supplier.
$20 to $50 per sheet cheaper depending on what place you call.
Old 05-04-2009, 05:33 PM   #22 (permalink)
dobsogj's Avatar
Member # 16561
Anybody ever try this stuff?
http://www.rvsurplussalvage.com/cata...roduct_id=1879
4 seat FJ40 buggy. Alum 5.3 - Th400 - Atlas 4 speed - 60/14 - 42" stickies...etc...
Gone but not forgotten: 81 toyota truggy - LT1 - Th400+203+atlas3.0 - 60 / 14 - 42s.
dobsogj is offline   Reply With Quote Quick reply to this message
Old 03-23-2010, 06:40 PM   #23 (permalink)
Member # 156924
just went to factory rv surplus 1611 w bristol st in elkhart in.
Bob was great to deal with. great deals and products seem good. have not installed windows and door yet. his phone # is 574-262-3327. a friend went to rv salvage and said they had good deals also. i'm going to check them out next time also. ran out of time this trip.
volvoman is offline   Reply With Quote Quick reply to this message
Old 06-09-2012, 10:55 AM   #24 (permalink)
Member # 84464
bump!
God Bless America
mike_belben is offline   Reply With Quote Quick reply to this message
