Member # 62837
2003 Tahoe Trailer Lights Not Working
I have been towing my samurai around with a 2003 Tahoe, and i noticed that my right turn signal no longer works.
The tahoe has the big connector with two prongs in the center, and prongs all the way around it in a 1.5 inch diameter circle. I tested the right signal/brake with a probe, and it doesnt work. I was going to mess around with the wiring harness underneath, but it looks like it is going to be a pain. Would anyone happen to know what color wire the Right signal/brake is? Thanks! By the way, i also noticed this same problem with a friend on an 05 cummins dodge. Is this a common occurence for the right prong to fail?
88 Samurai, 104WB, Locked Up Yotas, 6.5's, 36's. Chop and stretch: [URL="http://www.pirate4x4.com/forum/showthread.php?t=643403"]http://www.pirate4x4.com/forum/showthread.php?t=643403[/URL] [QUOTE]I blew through two D60's ring and pinions, and three sets of superior shafts. I run 42" tsl's, and finally stepped up to a Cryo'd D30..... I will never look back[/QUOTE] |
Member # 5021
Do the lights work on the Tahoe but not the trailer?
GM put in a seperate fuse block for the trailer stuff. Same thing happened on my 00 Silverado. /forum/tow-rigs-trailers/181086-2000-silverado-wiring-issue.html Last edited by The Rockslut; 06-23-2006 at 09:49 PM. |
Member # 62837
Lights on truck work good.
I will check the fusebox under the hood. Is that a total of 3 fuse boxes in this truck now!! I will let you know if that solves the problem.
Member # 67907
Yep check your underhood fuses, I'll bet your Left turn trailer fuse is blown, then check your trailer wiring to see why it blew.
The Beepster [url]http://www.pirate4x4.com/forum/showthread.php?t=727456[/url] |
