Towing with a K5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-18-2007, 07:19 PM   #1 (permalink)
1981k20's Avatar
Member # 30390
Towing with a K5
I've got a 1989 K5 that I want to use to haul my 7500lbs trailer (both axles have brakes). My plan is to swap in a 14 bolt diff and a heavier leaf pack in the rear. Has anyone here towed at highway speeds with a short wheelbase rig? Is it all over the road? My only other tow rig is one of our Freightliner's, but I drive one every day and would rather not be in them on weekends too. Any advice is appreciated!
1990 K5 Blazer, Built 383, D60/14B Locked, 39.5 Boggers, M12000 etc.
1981k20 is offline   Reply With Quote
Old 04-18-2007, 08:16 PM   #2 (permalink)
Member # 44439
According to the brochure from GM for my 89 Blazer, a "properly equipped blazer" has a GCVR of 12k lbs. I'm thinkin' you're gonna be over that. My blazer tips the scales at 4800lbs empty.
Personally offended by people who think only girls can be sluts
89smurf is online now   Reply With Quote
Old 04-18-2007, 08:51 PM   #3 (permalink)
Member # 1636
I had an 89 K5 with 32s on it, otherwise stock. Most of the time I just towed a sports quad but I also towed my freind's Mustang to the race track on an ex-uhaul trailer. I'm guessing we were around 6k in extra weight. It was slow, didn't sway or bounce, but the braking sucked.
[url]http://www.pirate4x4.com/forum/misc-stuff-sale/1192938.html[/url]
chris demartini is offline   Reply With Quote
Old 04-19-2007, 04:46 AM   #4 (permalink)
1981k20's Avatar
Member # 30390
I've towed a '94 Isuzu Trooper on my trailer before but nothing as heavy as my Jimmy. I'm thinking of removing the door guts, tailgate and cap on the wheeler to loose weight, do you think it'll help? Anything else that's useless and heavy on a K5 that I can remove?
After all of this if it's still unsafe there's a '91 Suburban I've been eying up...
Thanks again
Old 04-19-2007, 04:51 AM   #5 (permalink)
1981k20's Avatar
Member # 30390
I must be confused, my 1 ton motor home has a GCVR of only 10500lbs, am I reading the tags wrong? I'll check the K5 today. Either way, either vehicle, I'll be over weight...
Old 04-19-2007, 09:00 AM   #6 (permalink)
Member # 17632
My uncle used to tow his 28' travel trailer with his 69 K5, never had any problems. He used a weight dist hitch and both axles had brakes. This was also not his primary tow rig, he just used it when he went hunting for a week or more so he could use the blazer in the woods. So don't get all down with the weight police comments.
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s
91.5 Dodge 6BT 5 spd tow rig
crashnzuk is offline   Reply With Quote
Old 04-19-2007, 11:04 AM   #7 (permalink)
Member # 8421
A Suburban is nicer if you can get one. I towed a lot with my stock 1990 K5. It got the job done, but things would get squirrely sometimes. I towed up to 6000 lbs with it (mainly because I was young, that was what I had to tow with, and I didn't know any better). Proper trailer weight distribution is critical on the K5, you don't want the trailer to sway at all.
My 1990 Burb tows way better. The trailer moves the K5 around, but with the Burb you can't feel that the trailer's back there. Both are 1/2-tons, so I'm just comparing difference in weight/wheelbase - axles/brakes/springs are the same.
thecarman is offline   Reply With Quote
Old 04-19-2007, 04:14 PM   #8 (permalink)
Member # 52554
i know it's not a blazer but, it's very close to the same wheel base.
i tow my xtracab yota (3800#'s) with a 95 chevy c1500, short bed ,single cab, 350, 5spd on a 2000# car hauler. It's not the fastest but, as long as i put enough tounge weight on it, it tows comfortably. I'm stupid for not doing it yet but, i havn't added a brake controller so, i only use the brakes on the truck.
79 CJ7 , Tons, D300, chevy 4.3, 39.5 IROKS
toyota88 is offline   Reply With Quote
Old 04-22-2007, 05:17 AM   #9 (permalink)
Member # 72000
id remove that stuff anyway. im of the opinion that a trail rig should have as little sprung weight as possible. unpsrung weight(bigger axles) add beef and can help you find traction,but sprung weight rarely does anything good for you
105" WB blazer is not the optimal tow rig,but that doesnt mean it wont suit your needs. load the trailer properly,use a good brake controller with brakes on both axles and drive like you have some sense and youll be fine. a WD hitch with sway control im sure would make it feel alot more stable,but you could prolly get away without it.
the 14 bolt/spring pack swap is a good idea. get it from a 3/4 ton truck and it will bolt right in. if you want a softer spring for a decent ride when the trailers not there,look into a set of airbags.
ive got it in my head that someday im gonna build a blazer with a C&C dually axle,1 ton springs and hangers,no top and a gooseneck ball right overtop of the axle. its whole purpose would be to manuver trailers around in tight quarters and run shit back and forth to the shredder. the yard is alittle tight,so it can be tricky to turn my crew cab around in there
a SWB workhorse would not be a great idea for long hauls with heavy loads,but would be really useful in alot of other situations
scotty
85 grand waggoneer(what's left of it)
77 scout II truggy
84 chevy home made crewcab
Delightfully Tacky,Yet Unrefined
nightcrawlers is offline   Reply With Quote
Old 04-22-2007, 07:01 AM   #10 (permalink)
Member # 76828
Send a message via Yahoo to BLUE VEIN THROBBER
i have a club member that pulls his 1-Ton CJ-7, i think it is crazy to pull with that short of a wheel base,
i just think it is wrong, and Dumb, to much can go wrong, way to fast, when it happens. jack knifing or some thing...IMO
[B][I][COLOR="Blue"]1-TON TRUGGY-- Doubler 3 Stk, 1410 Shafts, 513 Grs, Lockers, PROPANE 454 /5--47''LTB's, TR locks, WARN 16,500 F/ 10,000 R--CROMO inners/ outers CTM's [/COLOR][/I][/B]
[B][I][COLOR="Red"]WHEEL HARD OR GO HOME.[/COLOR]
MIDNIGHT FOUR WHEELERS FOR LIFE!!![/I][/B]
BLUE VEIN THROBBER is offline   Reply With Quote
Old 04-22-2007, 09:57 AM   #11 (permalink)
Member # 45125
Send a message via AIM to adrianspeeder Send a message via MSN to adrianspeeder Send a message via Yahoo to adrianspeeder
Never had a problem with the bronco's, but wasn't ever in a panic stop situation. Short wheel base just can't compete with lenght of a pickup.
Adrianspeeder
08/02/74/66 F-250s, 97/79 F150s, 79/71 F100s
92/88/84 Broncos, 96/96 Exploders, 85 M1009
adrianspeeder is offline   Reply With Quote
Old 04-22-2007, 10:47 AM   #12 (permalink)
Member # 51692
Send a message via ICQ to rocknbronco Send a message via Yahoo to rocknbronco
You can do it just be safe but in all honesty I could get a dedicated truck set up for that much weight.
Space for rent sold it all....
rocknbronco is offline   Reply With Quote
Old 04-22-2007, 10:52 AM   #13 (permalink)
jasonmt's Avatar
Member # 3236
The part that would worry me would be if you were planning on hauling on the FTR (40, 41, 940, 734 etc.) or on any of the many offshoots.
[QUOTE=Roxywheels]The trolls always out themselves :laughing: :roxy:[/QUOTE]
jasonmt is offline   Reply With Quote
