towing capacity of chevy 2500? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-16-2007, 08:06 PM   #1 (permalink)
Member # 23172
Send a message via AIM to KenTheJeepGuy Send a message via Yahoo to KenTheJeepGuy
Any idea what a 1994 chevy 4x4 2500 long bed std cab with a 6.5L diesel could resonably tow?
or better yet does anyone know the exact capacity?
and is there a way to easily increase capacity?
like what all goes into figuring out the "rated max capacity"?
1979 jeep CJ5. 430hp chevy V8, 46" tires, rockwell axles, full fiberglass body, custom 4-link double triangulated rear suspension.
1983 jeep CJ7. Fiberglass body, 3" lift, shackel reversal, wrangler leaves, 31" MT
KenTheJeepGuy is offline   Reply With Quote
Old 06-16-2007, 09:33 PM   #2 (permalink)
CJ5inFourWheelDrive's Avatar
Member # 19668
There should be GVWR stickers on the inside of your door frames or on your doors or under the hood above the radiator vailance. If nobody here knows you could ask on www.fullsizechevy.com .
(1975 Jeep CJ-5) Being built: 2x4 A-500C frame, C&C 14 bolt w/discs & Detroit, D44 mini-spool, Flat Tops, Mad Mac Double Arms, 4.56's, SM420, D300, AA & Novak adapters, SOA on 2in. BDS YJ springs with a reversal, extended wb; 6in. front, 3in. rear, TJ flairs, hummer rims, hydroboost w/68' Vette M/C…
CJ5inFourWheelDrive is offline   Reply With Quote
Old 06-16-2007, 09:50 PM   #3 (permalink)
Member # 92543
Send a message via AIM to Mark13
A friend of ours pulled upwards of 20,000 with his 94 ext cab, long bed 4x4 with the 6.5 td. Chevys limit- check your door sticker or owners book.
06 Chevy 2500hd
Mark13 is offline   Reply With Quote
Old 06-16-2007, 09:52 PM   #4 (permalink)
Member # 42888
if you have the owners manual it should tell you.
Is it a Light duty 2500 or the eight lug 2500
manual or automatic?
Gear ratio?
you could ask at the diesel place the 6.5 guys would know
2007 Gmc Sierra 2500hd SLT Duramax
94redrodeo is offline   Reply With Quote
Old 06-17-2007, 06:35 AM   #5 (permalink)
Member # 23172
It is an automatic, i will check for you on the number of lugs. does the light duty have 6 lug? is there any other way to tell LD/HD?
is there an easy way to figure out gear ratio? would it say somewhere?
I am contemplating buying this vehicle, as my tow-rig... and just want to make sure it will suit my needs.
anything else i should look for or ask about?
Old 06-17-2007, 09:09 AM   #6 (permalink)
NJ
NJ's Avatar
Member # 27082
LD is 6 lug, SF 14 bolt
HD is 8 lug, FF 14 Bolt
Rear End RPO Codes, check the glove box for a list of codes
GQ1 -- AXLE REAR, STD RATIO
GT4 -- AXLE REAR, 3.73 RATIO
GT5 -- AXLE REAR, 4.10 RATIO
GU4 -- AXLE REAR, 3.08 RATIO
GU5 -- AXLE REAR, 3.23 RATIO
GU6 -- AXLE REAR, 3.42 RATIO
G80 -- AXLE REAR, LIMITED SLIP (POSITRACTION)
HC4 -- AXLE REAR, 4.56 RATIO (mostly military issue trucks)
NJ is offline   Reply With Quote
