Member # 6704
Truck/trailer ID lighting requirements
Here's a situation I've been pondering... Federal lighting requirements on a trailer > 80" wide requires rear identification lamps (exactly 3 red lights spaced 6" to 12" apart in the center of the vehicle and as high as practicable). Front clearance lights are required but front identifiacation lights are not required on a trailer.
On trucks > 80" front identification lights are required to indicate the presence of a wide vehicle. In my situation, my truck is a SRW 3/4 ton and is < 80" wide and my trailer is > 80". So the trailer has rear ID lights, but the truck has none (I don't want to put them on my truck either). So, when the truck is hitched to the trailer, is the whole combination considered a wide vechile? I'm going to have a slide-in truck camper on the front of the GN and was thinking about putting front ID lights along the top of the camper. Would this be considered technically "wrong"? Does the narrow truck/wide trailer fall into a loop-hole for front ID lights?
It's IHeavy aka TORC KC0UIC -.- -.-. ----- ..- .. -.-. Nothing is foolproof to a sufficiently talented fool. |
Member # 76684
I'm not sure about the law or not, it's sketchy around here. I went by DOT law. I have two amber markers on the sides in front, two red markers on the sides in back, and 3 red markers across the back of the trailer. You may have to add some in the middle on the sides, depending on length. I also added conspicuity tape to over 50% of the trailers length. I figure I can't go wrong that way. Lights are relatively cheap, even LED ones.
[QUOTE=nahmus;9175355]asking chit chat to stop before they are done is kinda like asking piranhas to stop after one bite.[/QUOTE] |
#3 (permalink) | |
Member # 6704
And that's not counting the ones on the camper.
Member # 6704
Who said I was worried? I said I was "pondering it" and was "curious".... but I'm definately not worried about it. Hell, 2 years ago I was doing 80 mph down I-80 out of Sacremento with the unmodified version of my trailer (with only 4 lights total... only about 1/2 of what I should of had for clearance lights and no rear ID lights at all) and never got hassled.
#6 (permalink) | |
Addicted to Gear Oil
Member # 56050
I have no idea, but ID clearance lights along the front of the camper would look cool.
1965 Scout 80 7.3PSD/ZF/203/205 D60F/14BFF Member: 4 Jackstand Wheeler's Association Quote:
David H. Petraeus for President 2016 |
ΜΟΛΩΝ ΛΑΒΕ
I don't know what size trailer you're pulling, but the word "Commercial" means nothing in this context. The trailer should have the three lights on the rear, and at least one amber on each front corner.
The tow rig doesn't need the three across the back, because without the trailer, it's less than 80". However, it does need five ambers across the top of the cab.
SECEDE! Truth is treason in the kingdom of lies. |
#8 (permalink) | |
Member # 6704
#10 (permalink) | |
Member # 9316
However if you really wanted them I would put them on the camper, rather than cutting up the roof of your truck for some lights.
ROCKHEADS transplant in Indiana |
#12 (permalink) |
Member # 6704
I think they look perfectly fine and actually do like them myself..... on a DRW truck. Never cared for them much on an SRW truck though. They just look out of place and a little "wanna be" to me on an SRW for some reason.
#13 (permalink) |
Member # 72000
you could mount the 5 amber lights on a magnetic light bar that you could take on and off
scotty 85 grand waggoneer(what's left of it) 77 scout II truggy 84 chevy home made crewcab Delightfully Tacky,Yet Unrefined |
#14 (permalink) |
Member # 71185
If i'm reading this right then I need front clearance lights on my SRW superduty when pulling my 102" wide 10' long snowmobile trailer, correct?
I've towed a goose with the lights on the front of the trailer but never had a second thought that I needed them with a little trailer. Humm I wonder if anyone makes a factory style led roof clearance light. Brewchief
#15 (permalink) | |
ΜΟΛΩΝ ΛΑΒΕ
Now I repeat NO ONE WILL BOTHER YOU FOR NOT HAVING CAB LIGHTS WITH A CAMPER OR A SMALL TRAILER!!!!!! If a cop writes you for that, he's gonna find something to write you for anyway.
#16 (permalink) | |
Member # 71185
BTW the lund visors are kinda gehy, at least in my opinion. Brewchief
#17 (permalink) | |
I can understand the desire to meet the requirements though. If it were my setup I would be putting the lights across the front of the camper and leaving the truck alone. |
#18 (permalink) | |
1962 YellowSubmarine
Member # 1494
Peter S. Di Primo PSD Enterprises, LLC - Waterjet, laser, metal forming, CNC work, Fiberglass and Carbon work, patterns and molds. No job too small. Prototyping and small production is our specialty, but we have the network to handle large jobs as well. Email me if you need something cut, bent, formed, milled, machined, etc. Founding Member - VCAS4WDC www.axlesnappers.org Help Fight Global Warming- turn your A/C on high and open all your windows. Alcohol, Tobacco, and Firearms should be a convenience store - NOT a government agency!!!! |
