Brake Controler Q - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-30-2002, 10:46 PM   #1 (permalink)
Member # 6002
Send a message via ICQ to Toy 4Runner Man Send a message via AIM to Toy 4Runner Man
Brake Controler Q
What do U all think about this controler? http://www.brakecontroller.com/sentinel.htm
Thanks
Toy 4Runner Man is offline   Reply With Quote Quick reply to this message
Old 07-01-2002, 06:57 AM   #2 (permalink)
JackA's Avatar
Member # 2129
I run that one. It does the job just fine.
2013, 2012, 2011 ASCC Ultra4 Class Champion, 21st place KOH 11, 20th place KOH 10, 16th place KOH 09, 9th place KOH 08
Huge thanks to Ballistic Fab, ADS shocks, Pro Diesel, Bulldog winch, Desert Rat Off Road Centers, BFG Tires and all my friends and family
JackA is offline   Reply With Quote Quick reply to this message
Old 07-01-2002, 08:33 AM   #3 (permalink)
DRM
Super Moderator
DRM's Avatar
Member # 8
I need to add a controler to my tow rig, that one looks good. How's it work? Pretty stable, or hard to get set right?
>David
>It only hurts the first time you agree with me...
>"A little nonsense now and then is cherished by the wisest men."
DRM is offline   Reply With Quote Quick reply to this message
Old 07-01-2002, 10:07 AM   #4 (permalink)
Member # 107
Send a message via AIM to The Jerk Send a message via MSN to The Jerk Send a message via Yahoo to The Jerk
i have the drawtite activator 2 model digital display and thumb roller adjustment, uhaul seemed to have teh best price! jiMMy
RockZombie:68FJ40 LPG350/420/300/60/70
69FJ40 350/stock | 70FJ55 350/700r4/205 | 72FJ55 stock
The Jerk is offline   Reply With Quote Quick reply to this message
Old 07-01-2002, 03:59 PM   #5 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
I have the voyager
its the lower model, I love it, I had a draw tie and it just never seemed work smoothly,
the Tekonsha ones are supposed to be the best, i like mine, i trust it so much I let Stacie tow the horse trailers with it
Mark
Old 07-01-2002, 05:21 PM   #6 (permalink)
Member # 324
I have the Tekonsha voyager in my personal truck and my work truck and i love them. With the level adjustment you can adjust it a little out of level to make the brakes come in earlier if you want. I do it depending on the load and conditions. Just dont test your trailer brake breakaway system with it hooked up as it will the controller.
Family, Friends, riders and racers, its who we are.
smurfsdad is offline   Reply With Quote Quick reply to this message
Old 07-02-2002, 04:08 PM   #7 (permalink)
J Bruce's Avatar
Member # 3235
I haven't used the brake controller mentioned but I wanted to throw in my opinion on the Tekonsha Prodigy. I've got one love it. Super smooth, very adjustable, works properly in both forward and reverse, proportional braking (no jarring stops or locked up wheels).
Prodigy Brake Controller
Jon B.
'82 CJ7 some mods.
There is no replacement for displacement!
J Bruce is offline   Reply With Quote Quick reply to this message
Old 07-02-2002, 04:18 PM   #8 (permalink)
Rudezuk's Avatar
Member # 4500
can you use the trailer brakes with out the controller???
My Dodge has the wiring from the factory....(with a spot on the plug that sais electric brakes).....do i need a controller to add into that?
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Rudezuk is offline   Reply With Quote Quick reply to this message
Old 07-02-2002, 05:59 PM   #9 (permalink)
flimmy's Avatar
Member # 3101
Did your truck come from the factory with the tow package ? I have a 2001 Dodge that did not have the towing package and it still had the plug under the dash. The only problem is the wires for the trailer brakes don't go anywere, or at least thats whatt the mechanic at the dealer told me. The plug does have some of the wiring done for you. It's allready connected to the trucks brake wiring. If you did have the tow package than all you need is the plug, you can get that were you but the controller. Just connect the wires from the plug to the contoller and your ready to go.
btw, I guess you put the 60 and 70 under your truck since the off-road only came in the 1500's.
flimmy is offline   Reply With Quote Quick reply to this message
Old 07-03-2002, 09:20 AM   #10 (permalink)
Rudezuk's Avatar
Member # 4500
Yeah you are right on the axles.....they are from a 99 3/4 ton diesel............but mine did come with the towing package, plug and everything..............
The question is can i hook that wire, (if it is hot) straight to my brakes? Or do i need to place a brake controller on the inside too?
Old 07-03-2002, 12:28 PM   #11 (permalink)
Member # 324
You need to use a controller. The controller will have the same color coded wires to match the wires on your truck with the exception of one wire and the instructions will tell you the right way to hook it up.
Old 07-03-2002, 01:44 PM   #12 (permalink)
Member # 24
Send a message via ICQ to Lemoore-on
And it lets you control the amount of braking that you get from the trailer brakes. More if your loaded or less if its empty.
I ordered the sentinal yesterday. I have flat towed my rig once and trailered it once without the T brakes, next time we'll see what kind of improvement it makes.
Lemoore-on
Mike, 85 Toyota SUV
[B]
[/B]
Lemoore-on is offline   Reply With Quote Quick reply to this message
Old 07-03-2002, 06:35 PM   #13 (permalink)
FYRMAN's Avatar
Member # 4358
Send a message via Yahoo to FYRMAN
The Sentinel is a good controller. It works just fine, and it's a Tekonsha. The Voyager is better. It's been around forever. Hardly anyone has problems with them. They are kind of a "set it, and forget it" kinda deal. The best in the Tekonsha line is the Prodigy. It has the boost feature, the digital read-out of how much voltage is actually going to the trailer.... It's also removable. If you have more than one rig that needs a controller (but not at the same time) you simply unplug the controller from the harness, slide it out of the cradle, and move it to the next rig. You will have to buy another wiring harness from Tekonsha, but worth the money if you have more than one rig. Those three, in that order, IMHO.
The Draw-Tite is a good controller. For an all electric controller, they are one of my favorites. The only thing I don't care for is that they have that roller wheel to adjust the power. I can't just look down at the controller and get an idea of where the controller is set. You have to wait till you have to stop and read how high the numbers go. The Reese Brakeman Compact is just the same as the Draw-Tite, but it doesn't have the digital read-out, and it has a slide lever instead of the roller wheel. That way you can just look and see where the controller is set.
To pick a controller to go in my rig is a toss-up. I'd either spend the bucks and get the Prodigy, or go cheaper and get the Voyager. For simplicity, easy of operation, and something that doesn't look like it just came off of the Star Trek set, I'd go with the Voyager.
[COLOR="Red"]Central Washington Muff Dive and Rescue Team[/COLOR]
FYRMAN is offline   Reply With Quote Quick reply to this message
Old 07-04-2002, 10:38 PM   #14 (permalink)
Member # 4228
Send a message via AIM to AGGIECJ-7
i got mine from Tractor Supply. i dont think it was anywhere near $70 though. if i remember correctly it was around 40 or so....It works great once you get it set right...i have even locked up the trailer breaks by hand when i was testing it out...
Steven W
82 CJ-7 - SOA, geared, locked, 35's
02 Ram 2500 - Cummins, 4x4, 6spd
AGGIECJ-7 is offline   Reply With Quote Quick reply to this message
Old 07-04-2002, 11:37 PM   #15 (permalink)
Member # 347
Drop the change and go for one of the 'smart' controller that vary power to the brakes based on the amount of deceleration, or the amount your brake pedal is depressed.
Tekonsha Prodigy: http://www.bargman.com/tekcat/prodigy.html#
a solid-state accelerometer-based controller
Jordan Ultra 2020: http://www.jordanbrake.com
a cable-actuated progressive controller
...the Prodigy is more portable.
In my experience, most regular brake controllers either give you to little or too much braking most of the time. You end up setting them high on the gain to avoid rearending someone when you really need them. Also, most regular controllers don't actuate the trailer brakes when going backwards.
Randii
[B]
[/B]... you pick up after your dog, so clean up after YOU, too.[I][SIZE="1"]
- [B]VIRTUAL RALLY[/B] for the HAMMER TRAILS in JOHNSON VALLEY
- [B]VIRTUAL RALLY[/B] for TELLICO
and
- [B]KOH Pledge Drive:[/B] for
[/SIZE][/I]
randii is offline   Reply With Quote Quick reply to this message
Old 04-16-2005, 08:19 PM   #16 (permalink)
Member # 19304
Send a message via MSN to gipper Send a message via Yahoo to gipper
Randii
How's that? Those cheapo controllers just activate the trailer brakes based on whether the brake lights are on or not.
I'm trying to decide to spend the money on the prodigy, but I'm just wondering if it will work as flawlessly as one of the el cheapos with the manual level adjustment.
For sale: 1984 CJ7 ... 4.10's, superwinch hubs, more.
gipper is offline   Reply With Quote Quick reply to this message
Old 04-17-2005, 03:04 PM   #17 (permalink)
Member # 13384
Send a message via AIM to SolidAxleDurango
Originally Posted by gipper
....I'm trying to decide to spend the money on the prodigy, but I'm just wondering if it will work as flawlessly as one of the el cheapos with the manual level adjustment.
Don't waste your time pondering it. Just get the Prodigy. Yes it works great.
If $100 (ebay specials are readily available) is too much, and you ~need~ to go cheaper, then may I suggest another hobby ??? j/k.
08 Kawa ATVs / 14 AC Wildcat X <- we ride / 07 Ram <- we pull / 12 Keystone Avalanche <- We sleep
SolidAxleDurango is offline   Reply With Quote Quick reply to this message
