"solid axle" unitbearing replacement kits
4K views 25 replies 17 participants last post by  cgraham1
#1 ·
I was checking out the new spyntech kits solid axle is selling to replace the unit bearings on dodges and fords. I have an 05 dodge 3500 and solid only sells a kit up to 04. Whats the difference between years?
#6 · (Edited)
Viola!! You'll have to ask about the dually hubs, mine is SRW so I haven't looked at that.
http://www.polyperformance.com/shop...vy-Duty-Front-Hub-Conversion-Kit-p-19444.html
http://www.polyperformance.com/shop...lly-Front-SpynTec-Conversion-Kit-p-26569.html
http://www.pirate4x4.com/forum/showthread.php?t=939821
And Wheelin66's thread, which has my wheels turnin' on upgrading Cs and knuckles on my 60 and throwing the stock stuff on my '04 CTD.
http://www.pirate4x4.com/forum/showthread.php?t=880388&highlight=
#14 ·
#9 ·
I used ballistic fab conversion on my '05 dodge. You can by just what you need and source other parts locally. The only issue I had with mine is I had to take 1-16" off the ballistic fab kit to allow the stock wheels to fit. Not a bad price for a one stop shop if you go that route.
#19 ·
I put in a Dynatrac hub eliminator kit on a customers Dodge. Nice kit. Very complete. Even kept the abs. I've got some pics I may post later.
He says that he has gained 4 mpg, and I know that if I ever have to change out ball joints on the thing, I won't be spending another hour beating the unit bearings out.
#25 ·
I've got one of the Solid Axle Spyntec kits in my E350. Service was top notch as is the product. Even to the point that they custom made mine to a 6x6.5 bolt pattern for my 03 F350 front end.
very straightforward install and knowing I can get parts at any neighborhood parts shop to rebuild it for less than the cost of a single unit bearing is good.
