drive over fenders? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-01-2008, 02:37 PM   #1 (permalink)
NE-Rokrash's Avatar
Member # 88973
drive over fenders?
Post-up your custom solution to drive-over fenders!!
This is why:
I am 84" outside to outside on my Jeep and am buying a trailer with an inside width of 83".
What can be done, short of rebuilding the fenders to make them drive-on capable?
The theory that I was thinking about going with would involve building a tubular ramp that ran on the top of the frame rails, just inside of the fenders. this would give me a ramp to put the majority of the Jeep's weight on to keep it off of the fenders.
Does this sound like a decent solution to my full-width problem?
73 Cj-5 22" stretch 350-400-205 D60/14 38" SX
NE-Rokrash is offline   Reply With Quote Quick reply to this message
Old 05-01-2008, 02:56 PM   #2 (permalink)
Rubicrawler's Avatar
Member # 2037
I just bent a piece of 1.75" HREW to match the fender lines and welded it to the frame just inside the fender with a center brace. I'm 85" so I just used it on the drivers side and drive over it.
Mark Langford
KI6TMK
'86 CJ7, ProRock60's, 4.88's/Detroits/35 Spline Alloys/CTM's, TBI 350, 700R4, 4:1 D300 w/Twin Stick, 17" x 8.5" Trail Ready HD Aluminum beadlocks, 37x13.5x17 Toyo MT's
Dysfunctional Rockcrawlers (TDO)
Wheelers for the Wounded of California
Rubicrawler is offline   Reply With Quote Quick reply to this message
Old 05-01-2008, 03:20 PM   #3 (permalink)
Member # 13731
Air down an lube up the tires --- you'll fit for sure!
I'm in the same boat -- 83" trailer and my 82.50" width just grew a littlw with the addition of some bead locks. It fits - but it seriously squeezes through.
uglyscout is offline   Reply With Quote Quick reply to this message
Old 05-01-2008, 03:35 PM   #4 (permalink)
Member # 15404
1.75x120 tube....
Life begins where the pavement ends!
rcurrier44 is offline   Reply With Quote Quick reply to this message
Old 05-01-2008, 03:48 PM   #5 (permalink)
Member # 20092
so did I. Works just fine. Just drive over the tube and the fender is protected.
'94 Toyota Land Cruiser FJZ80 - Vortec L33 5.3l, 4L60e, elocked, 3" OME lift, 315 KM2s, Warn 8074.
rock-rod is offline   Reply With Quote Quick reply to this message
Old 05-01-2008, 03:59 PM   #6 (permalink)
Member # 52028
Couple of the guys here just cut a piece of 1" angle as a solid corner for the top of the fender, and then ramped it down on both sides. Works just fine, and they've had 1-ton jeeps up to a fully caged, 1-tonned K5 on them.
dubbyx is offline   Reply With Quote Quick reply to this message
Old 05-02-2008, 05:55 AM   #7 (permalink)
Member # 86666
02 ZR2 SFA that gets abused:smokin:
gogogadgetbiker is offline   Reply With Quote Quick reply to this message
Old 05-02-2008, 06:34 AM   #8 (permalink)
Member # 4878
Send a message via ICQ to Travis Waldher Send a message via MSN to Travis Waldher Send a message via Yahoo to Travis Waldher
I just framed mine out with 1"x.120 square tube.
Then I used what I had around to fill in the openings, 1/4" plate steel.
My fenders can double as a medium duty winch anchor point if needed. :dork:
Travis Waldher is offline   Reply With Quote Quick reply to this message
Old 05-02-2008, 07:57 AM   #9 (permalink)
speedo's Avatar
Member # 23262
This one is my wife's trailer, mine is similar.
Gus
The ultimate result of shielding men from the effects of folly is to fill the world with fools.
--Herbert Spencer, English Philosopher (1820-1903)
speedo is offline   Reply With Quote Quick reply to this message
Old 05-02-2008, 07:59 AM   #10 (permalink)
Member # 82603
laminated wood cut to contour the fenders, just a bit higher, no welding and works on many other trailers.
Soup Man is offline   Reply With Quote Quick reply to this message
Old 05-02-2008, 11:08 AM   #11 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
I had the tube as well over the fender, worked well until I slipped off............
THen I just made new drive over fenders. Loads better.
You can actually sit on the fenders and not crush them, unlike the sheetmetal stockers.
Mark
Old 05-02-2008, 03:03 PM   #12 (permalink)
moonshadowmetals's Avatar
Member # 28836
Why don't you just space each fender out one inch?
moonshadowmetals is offline   Reply With Quote Quick reply to this message
Old 05-02-2008, 06:58 PM   #13 (permalink)
Hillbilly's Avatar
Member # 857
No pics at the moment, but i "framed" mine out of tubing to build the shell and covered with plate. I got the idea from 4RnrRick. here's the thread
http://www.pirate4x4.com/forum/showt...railer+fenders
Hillbilly is offline   Reply With Quote Quick reply to this message
Old 05-02-2008, 07:50 PM   #14 (permalink)
Trailer Guy's Avatar
Member # 49181
It might put the trailer over the legal width.
Around the shop we either bend up some tubing and make mounts that slip into the stake pockets of the trailer. This way they can be removed and won't be in the way if you haul a car, or anything else for that matter.
OR
You can cut off your old fenders and build new ones using 10" jr. channel with a center brace under the fender between the two tires. It's what we build all our HD fenders out of. Works killer, tractors drive on them without issue. The new trailer we building now is using that exact stuff. Build thread coming soon..........
Better to die fighting for freedom then be a prisoner all the days of your life. -Bob Marley-
Most people do not really want freedom, because freedom involves responsibility, and most people are frightened of responsibility. -Sigmund Freud-
Trailer Guy is offline   Reply With Quote Quick reply to this message
Old 05-02-2008, 08:01 PM   #15 (permalink)
Member # 67882
120 fabrication
Two fj40s on 60s
fj40forlife is offline   Reply With Quote Quick reply to this message
Old 05-19-2008, 12:20 AM   #16 (permalink)
Member # 78377
i just did this to protect my friends trailer when loading my jeep. worked great for the jeep. at the end of the day i jumped from my jeep to the fender and dented the crap out of the fender. if it was mine id build better fenders
jeeplt1 is offline   Reply With Quote Quick reply to this message
Old 05-19-2008, 07:30 AM   #17 (permalink)
Mechanos's Avatar
Member # 6704
My fenders are stout as hell already... they're 1/8" plate. I'm not worried about the fenders, but the expected width of my trail rig is ~86" and the deck between the fenders is ~82". With so little of each tire on the fenders, I'll probably have to build kind of ramp things (probably stacked wood) to sit just inside the fenders.
It's
IHeavy
aka TORC
KC0UIC
Nothing is foolproof to a sufficiently talented fool.
Mechanos is offline   Reply With Quote Quick reply to this message
Old 05-19-2008, 10:21 AM   #18 (permalink)
RustoleumWhite's Avatar
Member # 4506
Friend of mine did the stacked wood (never mind that his fenders were probably the same Jr. Channel that Trailer Guy spoke of) for when his rig was super wide. Worked great, cheap, little effort and made it much easier to drive up and over.
Personally, I'm just making my rig fit BETWEEN the fenders
I wheel a mean jackstand
RustoleumWhite is offline   Reply With Quote Quick reply to this message
Old 05-21-2008, 06:02 PM   #19 (permalink)
alwaysbrokeYJ's Avatar
Member # 36773
[QUOTE=RustoleumWhite;8265278]Friend of mine did the stacked wood (never mind that his fenders were probably the same Jr. Channel that Trailer Guy spoke of) for when his rig was super wide. Worked great, cheap, little effort and made it much easier to drive up and over.
That's what I did with mine, just screw some 2x4's together. It worked good for a while and cheap too!
alwaysbrokeYJ is offline   Reply With Quote Quick reply to this message
Old 05-22-2008, 09:53 AM   #20 (permalink)
Member # 79578
3/16 Diamond plate. Notice how the front & rear "ramps" on the fenders drop down to the bottom of the frame rail with a gusset welded in. It prevents them from "rotating" due to the moment arm created when you drive on 'em.
The inner seam is also fully welded to the deck........angry.
sb406 is offline   Reply With Quote Quick reply to this message
Old 05-23-2008, 01:49 PM   #21 (permalink)
dblue351's Avatar
Member # 1001
Send a message via AIM to dblue351 Send a message via Yahoo to dblue351
71 Bronco with stuff.....
dblue351 is offline   Reply With Quote Quick reply to this message
Old 05-23-2008, 07:26 PM   #22 (permalink)
Member # 104800
Heres mine.
csmith24 is offline   Reply With Quote Quick reply to this message
Old 05-25-2008, 10:28 PM   #23 (permalink)
simon5ay5's Avatar
Member # 114469
Send a message via AIM to simon5ay5
one we built
simon5ay5 is offline   Reply With Quote Quick reply to this message
Old 05-30-2008, 11:09 PM   #24 (permalink)
RADDONKEY's Avatar
Member # 23810
Heres some I built
RADDONKEY ROCK RACING - RDRR :grinpimp:
RADDONKEY is offline   Reply With Quote Quick reply to this message
Old 05-31-2008, 05:45 PM   #25 (permalink)
Banned
Member # 24704
You guys should sell those tube and plate fenders, I'd buy a set even if they came unassembled.
Tim84K10 is offline   Reply With Quote Quick reply to this message
