Duramax Injectors? Are they bad? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-04-2008, 08:37 PM   #1 (permalink)
Member # 20304
Send a message via AIM to BarrelRoll
Yes I searched
I've got an '04 Duramax with 133k on it. It smokes a fair amount at idle, usually a little puff of black when it's cool and then it becomes a cloud at stop lights when it's hot. Does this sound like injectors? Is there a way to check them? I have acess to a moids, does that have an injector test function?
How much does it suck to replace injectors? I was told it was a 16 hour job and not fun. Where is the cheapest place to get new injectors?
This board is no doubt slowly moving from Pirate4x4 to ElitistYuppyWithTooMuchMoney4x4.
-Braxton 357
BarrelRoll is offline   Reply With Quote Quick reply to this message
Old 08-04-2008, 11:34 PM   #2 (permalink)
nissancrawler's Avatar
Member # 76684
I thought they had a 200k warranty on injectors, but I don't know much about it.
[QUOTE=nahmus;9175355]asking chit chat to stop before they are done is kinda like asking piranhas to stop after one bite.[/QUOTE]
nissancrawler is offline   Reply With Quote Quick reply to this message
Old 08-05-2008, 01:20 AM   #3 (permalink)
CaseyP's Avatar
Member # 12557
Send a message via AIM to CaseyP Send a message via Yahoo to CaseyP
injectors are warrantied to 200k iirc...
[COLOR="DarkOrange"]
[/COLOR]
[QUOTE=ndeepoffroad;12310146]A well rounded wheeler will be prepared to prepare a delicious meal after a day of quality wheeling. Shit man errbudy know dat. :shaking:[/QUOTE]
CaseyP is offline   Reply With Quote Quick reply to this message
Old 08-05-2008, 02:30 AM   #4 (permalink)
Newbie
Member # 110034
Changed the fuel filter recently?
LB7 engines (8th character of the VIN is a #1) from '01 to '04 are covered for 7-years/200k miles. LLY's ('04.5 - '06) and newer aren't covered.
If it is found that your injectors are bad and not covered for whatever reason, you're looking at $800-$900 per injector (the part only). The downside of the LB7 is that its injectors are under the valve covers (a lot more labor).
93_Burrito is offline   Reply With Quote Quick reply to this message
Old 08-05-2008, 03:56 AM   #5 (permalink)
Member # 4140
That does not sound right to me, but what do I know.
Tim
There is no accounting for taste
1936, 1937, 1943, 1950, 1952, 1954, 1955, 1997, 1998, 2002, [B][COLOR="Red"]2008[/COLOR][/B].
Black Dog is offline   Reply With Quote Quick reply to this message
Old 08-05-2008, 07:20 AM   #6 (permalink)
Member # 90212
x2 on the filter change. I can look up your truck through gm to check if you still have warranty if you want. not trying to id teft your vin, Im a cheby dealer tech and have access to all that stuff. I just need the last eight.
just read my own post, I sound like a sketchy salesmen over the phone
"all I need is you credit card number and ss number"
"This truck is probably going to end up like a retarded kid. You wanna get rid of it but in your heart you know you'll have to keep it."
stomp-a-jeep is offline   Reply With Quote Quick reply to this message
Old 08-05-2008, 10:09 AM   #7 (permalink)
Member # 3974
Send a message via MSN to Isley
X2
I had mine replaced under warrantee recently. I'll dig out the reciept to see what cost was listed. I want to say they were listed around $200 each.
'93 YJ 4Banger
Isley is offline   Reply With Quote Quick reply to this message
Old 08-05-2008, 03:47 PM   #8 (permalink)
Member # 25230
Only on 01-03, 04s had less of a warranty, I think
I refuse to let ignorant, emotional "thinking" create public policy that infringes upon my constitutional rights, especially when such policy has already failed and caused the very incident thy compels the ignorant to cry for more of the same.
southern k5 is offline   Reply With Quote Quick reply to this message
Old 08-05-2008, 04:00 PM   #9 (permalink)
pilothillcrawler's Avatar
Member # 76609
Location: Pilot Hill, CA now Woodland, CA; 1 hour further from the con :(
yep they bring the suck, lb7's are covered for 7 years and 200,000 miles.
Also another prob with lb7's is the glow plugs in the federal emission vehicles, and they were picked up at the beginning of the year under warrantee for like 10 years 200,000 or 300,000 miles. I would also check the fuel filter first, and also check the engine oil to see if there is diesel in it.
YJ on custom frame 350 sm465 twin stick Dana 300, 35 Spline 60's f/r, arbs f/r, hydro, on 42" IROKS
pilothillcrawler is offline   Reply With Quote Quick reply to this message
Old 08-05-2008, 06:21 PM   #10 (permalink)
Member # 20304
Fuel filter is fresh, power service additive in the fuel. I'm pretty sure it's not covered, had it looked up in May at a chevy dealer, i'll dig up the vin and PM it to you.
The injectors were $550ish a piece at advanced before running my account any other sources?
-Braxton 357
Old 08-05-2008, 07:25 PM   #11 (permalink)
Member # 38771
If it's an 04 and 133k miles, it IS covered. Whatever dealer told you it wasn't doesn't know his ass from a hole in the ground. It's not actually warranty coverage though, it's a special policy coverage and not every dealer knows about it if they don't service diesels much (which also means you don't want to go there). Just this year the 04's were included in the coverage, so ALL LB7 motors are covered now. The 04.5 LLY's had a design change and are not a problem. They won't just replace them because the truck is smoking though, the policy states they have to have high fuel return rates, which is caused by internal cracks or excessive wear. This will cause smoking too, but the specific test is the return rate test for them to replace them. The test is pretty intrusive into the motor and by the time they finish the test, all that's left to replace the injectors is remove one bolt on each one and pop them out. The b!tch part is that if the truck passes the test (injectors are ok), you have to pay for it and it's quite a bit of labor (pretty much the same as replacing the injectors). A good dealer tech will know to do a balance rate test on the Tech 2 and see which injectors are pulling fuel back to compensate for the leakage before tearing into the motor. That's a simple 20 minute test on the computer and will tell them a lot. I know some techs that will see high balance rates and just make up numbers for the return rate test so they don't actually have to do it, then just replace the injectors. All the info from the return rate test has to be sent to GM for coverage approval.
My recommendation is to find a dealer in the area that knows what your talking about first, then talk to their diesel tech and make sure he's familiar with the job. A lot of dealers in my area send the jobs out to a single larger dealer who is used to doing tons of diesel work so that'd be the kind of place you want to find in your area.
$550 per injector is absurd, GM's dealer retail price is $322 each and that includes $30 worth of O-rings and gaskets.
If, for some strange reason, you end up having to do this job yourself check out www.dieselplace.com for info. There are several guys on there who can sell you the injectors and all the associated gaskets/parts you'll need to do the job for a good price and there's tons of info on the forum about doing the work yourself. It's not that bad of a job if your competent with tools and have lots of patience. I did the head gaskets on my 01 last fall and it wasn't that bad, just LOTS of parts to take off and keep track of and lots of time. I figure it was a solid 50 hours of work for me taking my time after work and weekends. Injectors would be around 16-20 hours for the skilled DIY'er on their first time.
Good luck, and feel free to ask if there's anything else you need to know!
Joe
'88 GMC K5, lots of dents
'01 Chevy 2500HD D/A
"It's only sheetmetal!"
Joe_88k5 is offline   Reply With Quote Quick reply to this message
Old 08-05-2008, 08:19 PM   #12 (permalink)
Member # 3974
Checked my receipt, my recollection was off a little bit. Joe was within a couple of bucks. List is $314.39 and Net is $250.88, pn 97729095.
'93 YJ 4Banger
Old 08-05-2008, 08:32 PM   #13 (permalink)
Member # 67907
If its an LB7 then its most likely injectors, I thought that only 01-03's were covered unless they extended the policy.
If its an LLY, then it could be your injector wiring harness, they had problems with those as well.
The Beepster
Jeepermat is offline   Reply With Quote Quick reply to this message
Old 08-05-2008, 10:21 PM   #14 (permalink)
RustoleumWhite's Avatar
Member # 4506
OK, since this seems like a logical thread to ask in. I'm in the market for a D-max, and am looking at 03's and 04's. Because I like the body style (05's are different enough) plus the LB7 motor has the best fuel economy figures.
How does one tell if the truck your looking at has the LB7 or the LLY. From an earlier post, apparently the 8'th VIN digit is a 1 for the LBY.... what is the LLY??
thanks. I've just started to research.
Is there (obvious to the uninitiated) visual clues?
I wheel a mean jackstand
RustoleumWhite is offline   Reply With Quote Quick reply to this message
Old 08-06-2008, 09:29 AM   #15 (permalink)
Member # 90212
^^^^ thats what you need to know. ^^^^
if your oil level is high then its a safe bet to say injectors are leaking.
Old 08-07-2008, 04:58 AM   #16 (permalink)
woodchuck2's Avatar
Member # 116651
For any and all ?? on D-Max's go to www.dieselplace.com.
79 F-150 302,np435, rest of the truck has been sold and is now retired.
woodchuck2 is offline   Reply With Quote Quick reply to this message
Old 08-07-2008, 07:01 PM   #17 (permalink)
Member # 8783
thats ALOT of time. i can do them in a pickup truck in under 7 hours. a 4500 series or a van reaches near 10-12
1 ton bronco
custom zuk or two
BurnedBronco is offline   Reply With Quote Quick reply to this message
Old 08-07-2008, 08:46 PM   #18 (permalink)
SteelFuser's Avatar
Member # 107225
Click on over to www.dieselplace.com Click on your year of pickup and you will find out everything you need to know there about D-max. Good luck
Baja Duramax more shit than yours.
NO FARMS, NO FOOD
SteelFuser is offline   Reply With Quote Quick reply to this message
Old 08-09-2008, 06:06 PM   #19 (permalink)
Member # 20304
I figured out how to test the ballances, when it was some what cold ballances were between 0 and .6. It's warming up right now.
-Braxton 357
Old 08-11-2008, 10:53 AM   #20 (permalink)
Member # 38771
I can too, I was just being generous for someone who'd never worked on one of these before. I'd hate to cause someone to tear the top of a dmax apart and have them not be able to get it back together by the end of the weekend.
Joe
Old 08-28-2008, 10:37 PM   #21 (permalink)
BackNBlackTJ's Avatar
Member # 18157
The stealership is telling me that mine are toast again... second set of injectors in my 04' D-max in the last 2.5 years... 175K on the truck and it started smoking "White puffs" at idle about a month ago. I'm looking for aftermarket options, the mechanic said the injectors are a known problem with the Duramax engines.
BackNBlackTJ is offline   Reply With Quote Quick reply to this message
Old 04-21-2009, 10:49 AM   #22 (permalink)
Member # 134369
assistance please
Anyone heard of the 10yr/200k implementation?
if any GM "gm's" know of any update to the "Special Policy Number 04039" that would be relevant to the '01 lb7 owners, would be of great help and very appreciated ... ..in a timely fashion, the trucks in the shop!!! ..
haha thanks a mill guys
--01 LB7 4dr short, 8"lift, fox, rgb, banks 6-gun, centerlines..
-07 fatboy 80%
Jebro4 is offline   Reply With Quote Quick reply to this message
Old 04-21-2009, 12:22 PM   #23 (permalink)
Shefron's Avatar
Member # 80692
Just had my injectors done and they were not covered. Its still the 7 year warranty on them so nope. Thank goodness I got the aftermarket warranty when I bought the truck two months ago.
Shefron is offline   Reply With Quote Quick reply to this message
Old 04-21-2009, 02:04 PM   #24 (permalink)
Member # 104517
Easiest way is to look at the RPO codes in the glovebox. It'll have LB7, LLY, etc. to tell you which one it is. All 03's are LB7's, whereas in the 04's you have to look. All the 04's I've looked at have been LB7's suprisingly but I guess I've been looking at early 04's.
R.I.P. Jason Payne
chevy_man is offline   Reply With Quote Quick reply to this message
