Member # 1159
What is the proper Ph for coolant in PSD
I got the coolant test strip kit from napa and proceeded to do the test. Well...the ph was 11 so I added the ford coolant additive like I was told. This dropped it to a ph of about 8.5. Do I need to add another bottle to get it to ph 7?
I called the dealership but the diesel mechanic was out to lunch (literally...not mentally )and so the "counter guy" said he thought the ph was supposed to be 7. Anyone know? Thanks. PS The test strips test for 3 things, ph, coolant/water %, and nitrite (I think). Does the nitrite level matter?
Member # 1533
PH levels tell you nothing about the coolant additive level. You really should get some Fleetguard test strips which actually measure the supplemental coolant additive level. PH only tells you if the coolant is acidic or alkaline. You can get Fleetguard strips at any International dealer or at Diesel Injection Service in Texas (mail order). www.dieselpage.com
Member # 2752
It is good that you are testing this. The additive is critical. You need to get the test strips though. The strips test for Glycol concentraion, Molybdate, and Nitrite. I am not sure what the pH is supposed to be (I would think between 7 and 8), but it takes three bottles of FW15 or 16 to charge an empty system. Too much of the stuff will cause problems as well. The test strips are like $5 for a pack. Well worth the trouble.
86 Samurai w/gun rack, 92" WB, VW 1.9 TD, Toyota 5-speed and dual cases with 4.7 gearset, Toyota axles with Longfields, 5.29's, ARB's f&r, YJ's, 35's, FJ-60 power steering, high steer, ............. <>< <>< <>< Hey, if this rig is for wheelin', what are all these animal parts doin' in here? |
Member # 1159
Thanks for the info. I'll go get the FOrd test kit strips. The darn napa ones didn't come with anything for directions
.The system was totally flushed (new water pump) when I bought the truck about 4 months ago. I added one bottle since but haven't been able to figure out the napa test strips...hence the Q on the board here. Thanks again. |
Member # 11760
use something like NAPAKOOL or you'll be sorry! that you didn't. keeping the ph up to the proper level will keep the erosion of the cylinder liners at a minumum, and your PoS diesel happy.
87 zuk |
#6 (permalink) | |
Member # 7430
"Man, your playlist has Merl Haggard and Megadeth- You're like the Hillbilly From Hell!!" |
#7 (permalink) | |
Member # 1533
Member # 11760
hmmm. lets see NAPAKOOL is a "sca", and if you keep your ph to the recommended level then you will be doing just what the manufacturer recommends. IN OTHER WORDS SERVICE YOUR PoS DIESELS COOLING SYSTEM YEARLY AND YOU PROBABLY WILL NEVER HAVE PROBLEMS WITH CAVITATION(WHICH CAUSES EROSION),OR ANY OTHER RELATED PROBLEMS. Or you could just buy a CUMMINS.......
87 zuk |
Member # 1159
I'll be ordering the fleetguard strips today.
Funny thing... the ford dealership here in olympia said "we don't have those" when asked about test strips. That seems just weird to me. Does it seem weird (or sneaky or ignorant) that they don't carry something to test the "very important" (as they said on the phone) additive levels? |
#10 (permalink) | ||
Member # 2752
#11 (permalink) | |
Member # 1533
#12 (permalink) |
Member # 7430
At least the new PowerStroke will solve the cavitation/erosion bit. Just think, an actual diesel block, not a BOMB'ed gas casting.
This is gonna be good I wonder how high they can turn up the fuel before they start blowing trannies. (Again)
#13 (permalink) |
Member # 1159
Thanks for the info guys
Nice explanations of cavitation etc I found info on what the nitrite level should be and did another test strip...came out perfect! So I am set for a while. |
#14 (permalink) | |
Member # 1533
Cummins engines experience cavitation also. With the Cummins you replace the sleeve when the cylinder walls finally get eaten through. This is a common occurence on big rigs. With the Powerstroke the entire block must be replaced thus the preventative care needed to prevent cavitation. Last edited by CSP; 08-07-2002 at 01:13 PM. |
#15 (permalink) | |
Member # 7430
The 6.9/7.3L PS is a direct derivation of the IH MV series gas motor. The MV gas displacements were 427 and 446 CID. The 7.3 diesel displaces 444 cubes. I can provide whatever proof you require. It isn't a Navistar motor, either. Designed by International Harvester, now produced by the International Truck and Engine Corperation. The Navistar name has been dead for several years now.
#16 (permalink) | |
Member # 1533
