Trailer Rollers for the rear of your trailer - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-17-2008, 09:30 PM   #1 (permalink)
DOUG38S's Avatar
Member # 17107
Send a message via AIM to DOUG38S
What has everyone had good experiences with? I've seen everything from heavy duty casters to weld on steel rollers to keep the rear of the trailer from draggin on the street and ground. I saw some this weekend that were steel rollers that are welded to the trailer frame and looked like they could take a beating. Made by renegade maybe? Anyone?
Reason being I just picked up a 3 day old fresh off the plant floor Roadmaster 24ft enclosed with the extended ceiling, finished interior and all the goodies. I want to keep it nice when going up the long ass driveway and not dragging the aluminum off the rear.
BIGELOW MOTORSPORTS EST. 2003
DOUG38S is offline   Reply With Quote Quick reply to this message
Old 08-17-2008, 09:45 PM   #2 (permalink)
Member # 78096
i used swivel casters (600-800 lbs each) from Tractor Supply and welded them onto the back of the frame where the stock \/'s were located. Works great.
Jeep07 is offline   Reply With Quote Quick reply to this message
Old 08-17-2008, 10:38 PM   #3 (permalink)
ZUK Herder
supazuk94's Avatar
Member # 28426
great idea my FIL is getting sick of me clearancing his driveway with my trailer
-jay
"It's my belief that someone with a Samurai ran over a Gypsy's dog or something years ago, and he laid a curse on the whole lot."
-UZI 9mm
thanks to:
supazuk94 is offline   Reply With Quote Quick reply to this message
Old 08-18-2008, 10:17 AM   #4 (permalink)
7.62FMJ's Avatar
Member # 66780
Check out an RV dealership.
Or, you could weld a 'U' shaped "skidplate" to the bottom on each side. Cut a piece of 8" or 10" pipe in half, or bigger depending on your clearance.
A
Piss!
7.62FMJ is offline   Reply With Quote Quick reply to this message
Old 08-18-2008, 03:48 PM   #5 (permalink)
Member # 14572
check out some rollers for conveyors, I think that is what you are looking for.
bpm4x4 is offline   Reply With Quote Quick reply to this message
Old 08-18-2008, 06:41 PM   #6 (permalink)
Member # 8783
ditto. casters SUCK in comparison...... have thos eon a few rollback beds so containers roll onto the bed easier and doest mare up nice paved driveways.
1 ton bronco
custom zuk or two
BurnedBronco is offline   Reply With Quote Quick reply to this message
Old 08-19-2008, 01:02 PM   #7 (permalink)
Member # 38704
Know of a source where you can buy these?
Thanks,
Willy
William Crawley
1988 MJ
reson46 is offline   Reply With Quote Quick reply to this message
Old 08-19-2008, 01:10 PM   #8 (permalink)
DOUG38S's Avatar
Member # 17107
went down to the local rv dealership today and they really didnt have anything that I thought would work. The casters are gonna get ripped off as soon as a rock catches it sideways. the rest of the steel rollers were pretty small.
Old 08-19-2008, 01:57 PM   #9 (permalink)
Mechanos's Avatar
Member # 6704
Check out a truck body manfucturer or something along those lines for some kind of roller like they put on the back of roll-off dumpsters or other truck equpiment that uses the palletized loading system. They may be kind of big for your application, but definitely beefy.
It's
IHeavy
aka TORC
KC0UIC
Nothing is foolproof to a sufficiently talented fool.
Mechanos is offline   Reply With Quote Quick reply to this message
Old 08-19-2008, 02:04 PM   #10 (permalink)
Member # 5021
Why not mount a strip of UHMW across the bottom and use countersunk bolts?
Don't be "THAT GUY" on the trail.
The Rockslut is offline   Reply With Quote Quick reply to this message
Old 08-19-2008, 04:07 PM   #11 (permalink)
Member # 23566
Send a message via AIM to SirMrManGuy
Search conveyor rollers at mcmaster.com I think thats what you are looking for. Seems like all you would need to do is weld a few simple tabs onto the bottom of your trailer.
95 Nissan Pathfinder, D44 front/H233 rear, dual ARBs, 4.56s, 36 Iroks
SirMrManGuy is offline   Reply With Quote Quick reply to this message
Old 08-20-2008, 07:47 AM   #12 (permalink)
Member # 1418
What about just using some tube?
Like get a peice of 1.5" hanging under the rear of the trailer from "legs" on the end that go up to the trailer,sleeved with a piece of 1.75 tube so it will rotate?
Its not like it would need bearings ......
84 4runner influenced by a F-toy, rustbucket cj2a with title, and a 22re, ..... Potato V4.0
Kyron is offline   Reply With Quote Quick reply to this message
Old 08-20-2008, 04:58 PM   #13 (permalink)
Member # 20276
seen some today that didnt swivel. They do work. Compared to a frame digginf into the concrete. Look up magnam trailers, trailer-wheel and frame , huskey trailer. they all hole sale dealers to the public. Most are out of houston,tx.
01 RAM 2500 24V CUMMINS DD/Krawlerhauler
85 Yota Buggy 4.3/tb350/x2ler/2.5tons/42"s
Ramrock is offline   Reply With Quote Quick reply to this message
Old 08-20-2008, 10:43 PM   #14 (permalink)
H M F
Im4yotas's Avatar
Member # 8758
Those rollers take a serious beating. You want something heavy duty. I've installed some badass steel rollers on ball bearings and ~5/16" plate mounting brackets on several trailers.
One trailer was hauling a huge camera crane and lots of camera equipment for a movie studio. Haulmark enclosed, triple 10k axles, it was obvious the driver wasn't too worried about beating the trailer up. So he was turning out of a parking lot with a steep driveway, hitting the rollers. It was a tight enough turn that the ass end was moving sideways instead of forward. Folded the main frame rail over 45 degrees.
I cut the rollers off and they were still in perfect condition. So after the frame was fixed, I moved the rollers to the outer corners where a few tubes met up at 3 different angles.
The rollers sold for $60 each. I can find out more about them if you like.
Drive it like Tim!
Im4yotas is offline   Reply With Quote Quick reply to this message
Old 08-21-2008, 07:14 AM   #15 (permalink)
Member # 38704
Where did you buy them?
Thanks,
Willy
William Crawley
1988 MJ
Old 08-21-2008, 09:01 AM   #16 (permalink)
Member # 17042
http://www.rjays.com/Trailer-parts/t...-wheels-01.htm
Haven't used these but that is what they're intended for. Just weld them on and drag away...
[QUOTE=Myanarchy;9475039]maybe if more kids got involved in projects we'd have less kids living in projects:flipoff2:[/QUOTE]
76scoutman is offline   Reply With Quote Quick reply to this message
Old 08-22-2008, 12:32 AM   #17 (permalink)
H M F
Im4yotas's Avatar
Member # 8758
Thanks,
Willy
These are the ones I used. We have them at the shop here at Garret - www.gctrailers.com
Drive it like Tim!
