Diesel blowing White Smoke- Normal or Bad? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-24-2008, 09:36 PM   #1 (permalink)
Member # 38269
I have an 89 Dodge Ram 350 with the 5.9L Cummins Turbo Diesel, It is not intercooled. It starts up fine and will idle all day without over heating. If I drive easy around town it is fine too, as soon as I hit the highway and am in constant boost the temp. needle climbs all the way to HOT. If I hit boost around town it starts blowing white smoke when I come to a stop. Someone told me it's the head gasket and when the boost pressures the cylinders it opens it up and lets some coolant out the exhaust. The coolant doesn't seem to be going anywhere so I'm puzzled because the smoke doesn't smell like coolant either. Some other guy told me just change my oil, put lucas oil stayblizer in it and then flush the radiator, put new coolant in there with prestone radiator stop leak and that should seal any imperfections from both ends. And a 3rd individual told me the smoke is just unburnt fuel clearing out and the over heating is because t-stat needs to be replaced? I am new to diesels and I don't know these engines that well. I am sure these are all good possibilities, so I am just wondering if anyone has had similar problems or can shed some light on if the white smoke is normal?
So my question is: Is it normal for non inter cooled turbo diesels to run that hot or is it just a coincidence that its blowing white smoke and I am associating cooling issues with the smoke?
P.S. How hard is it to run an intercooler and would it be worth it power wise as well as cooling wise?
Thanks
Murphy's law, thats all I have to say about that!
BrokenPartsVille is offline   Reply With Quote
Old 08-24-2008, 09:43 PM   #2 (permalink)
Member # 103495
my understanding concerning diesels is that white smoke is unburnt fuel and black smoke is partially burnt fuel...
edit: running an intercooler would be totally worth it and the only way to go.
hotrod07 is offline   Reply With Quote
Old 08-25-2008, 12:44 AM   #3 (permalink)
Elwenil's Avatar
Member # 41063
Once again, wrong forum. Learn to read people...
1988 Dodge AW450 Ramcharger - 318TBI - NP435 - NP205 - D60s
Elwenil is online now   Reply With Quote
Old 08-25-2008, 05:02 AM   #4 (permalink)
Member # 41653
isnt white smoke a sign of running lean??
Gotta Love people who have "soon to have/be" in their signatures....Im soon to be thin,rich and nice..
yea right..
"They are little angels but they are trying to fuck the wings off each other!"
--Sturgell
Black eyes last but a week, the shame of sodomy lasts a lifetime.-TheRedHorseman
wanderer-RRORC is offline   Reply With Quote
Old 08-25-2008, 05:51 AM   #5 (permalink)
Mechanos's Avatar
Member # 6704
You'll need the aftercooler, grille, boost tubes and intake plenum from a Gen I truck. Then just bolt it on.
It's
IHeavy
aka TORC
KC0UIC
Nothing is foolproof to a sufficiently talented fool.
Mechanos is offline   Reply With Quote
Old 08-25-2008, 07:18 AM   #6 (permalink)
Dana 44 Polisher
Member # 13731
If you truck is running HOT and blowing white smoke you have a problem -- I haven't seen many, if any, older 12V's that run hot.
As for the benifits of an intercooler -- do it.
uglyscout is offline   Reply With Quote
Old 08-25-2008, 02:17 PM   #7 (permalink)
Member # 70933
White smoke can be caused from burning water. That might explain your engine getting hot also.
[SIZE="4"]Total Metal Innovations 541-223-8608[/SIZE]
[SIZE="3"]Weld on Beadlocks with the only Patent Pending Integrated Anti Coning Technology
[url]http://www.pirate4x4.com/forum/showthread.php?p=14083618#post14083618[/url][/SIZE]
[email]Tyler@totalmetalinnovations.com[/email]
Rockrunner86 is offline   Reply With Quote
Old 08-25-2008, 02:44 PM   #8 (permalink)
mikevyota's Avatar
Member # 91662
Have you gotten fuel from a different than normal source? Maybe mixed with some #1? I've had this happen to me before.
White smoke is usually oil leaking from around an injector, past a piston ring or a sign of a lean condition. I think lean is more gray though. Does your temp gauge go hot, then come quickly down, then hot again during normal driving, or only peg when your under throttle? And do you have an EGT monitior?
82' Yota Truggy, 97 F250 CC PSD, 79' Bronco
---DesertRunner Fabrication---
mikevyota is offline   Reply With Quote
Old 08-25-2008, 03:07 PM   #9 (permalink)
braxton357's Avatar
Member # 14685
Send a message via AIM to braxton357
No...
How bad is it blowing white smoke? Like on startup, or a cloud of it?
In vino veritas
70 turbocharged 351w fastback mustang
73 linked 5.8efi Bronco
99 QCLB 4x4 twin'd cummins on meth.
braxton357 is offline   Reply With Quote
Old 08-25-2008, 03:11 PM   #10 (permalink)
Knee Grow Brewer
southern k5's Avatar
Member # 25230
Bad injector, change them out and youll be good
Originally Posted by Hef View Post
I refuse to let ignorant, emotional "thinking" create public policy that infringes upon my constitutional rights, especially when such policy has already failed and caused the very incident thy compels the ignorant to cry for more of the same.
southern k5 is offline   Reply With Quote
Old 08-25-2008, 03:23 PM   #11 (permalink)
Poor White Trash
Norm's Avatar
Member # 4387
I'll bet someone screwed with the timing on the pump, maybe a aggressive fuel plate .
"My Border Collie is smarter than our president"
Norm is offline   Reply With Quote
Old 08-25-2008, 03:34 PM   #12 (permalink)
Knee Grow Brewer
Member # 25230
VE pump = no fuel plate and no fuel plate = black smoke
Old 08-25-2008, 09:13 PM   #13 (permalink)
Member # 8783
Originally Posted by braxton357 View Post
No...
ditto......
if its lean, it just is slow and makes less power, it wont smoke unless theres not even enough fuel to havea half assed chance of burning.
black equals to much fuel
constant white and overheating i would be looking at somehting sucking oil through and burning the oil, or a water burning issue....
you could be dumping so much fuel to cause the overheating issue, but it would be black, and you would have probably melted a piston before it got pegged into red.
pay someone who "knows" what there doing to do a 1 hour diagnostic and you will have a much better, non "throwing parts" option of fixing then...........
also do not believe shit that anyone tells you if they are not famiar with diesels(familiar as in working on them, not just owning them) i have seen so much bad info told to my customers and told to me that it makes me sick as a diesel tech.
infa red your upper hose when its hot to make shure the T sats is opening and infa red the rad to make shure it is flowiong and cooling effeciently. quick 2 minutes to avoid what the one idiot told you.
1 ton bronco
custom zuk or two
BurnedBronco is offline   Reply With Quote
Old 08-25-2008, 09:24 PM   #14 (permalink)
B-rock's Avatar
Member # 11056
Send a message via AIM to B-rock Send a message via Yahoo to B-rock
Post up over on www.cumminsforum.com
They have a first gen section. they will get ya going right again soon.
93 YJ, SOA. 37's locked
'08 6.7L 4 door 4x4 LB. Mineral gray. Lorenz bilstein leveling kit. SRT hood.
AFE CAI. Mag-hytec's. SMARTY ME. 120HP injectors. II stage 2 turbo.
B-rock is offline   Reply With Quote
Old 08-26-2008, 09:07 PM   #15 (permalink)
Member # 38269
I changed the oil today put a little bit of lucas stabilizer in it seemed to make it not smoke as much, but I still have an overheating problem with same situation, at idle it's fine, not sure if it's a boost related...but I'm going to put new t-stat and coolant in it anyways because it hasn't been changed in a while..the truck was sitting for a little bit.
I didn't know they had a Bulletin Board for cummins, i'm gonna post it over there if I don't resolve it tomorrow. I'll still check in here to let you know how it turns out..thanks all for the help
Old 08-26-2008, 09:16 PM   #16 (permalink)
Charlie don't surf!
77bawls's Avatar
Member # 72494
3 things can cause white smoke
1: Unburnt fuel
2: Coolant leak in the combustion chamber
3: Plugged air filter
Experience= 9 years at a Dodge dealer.
Originally Posted by southernfriedcj8 View Post
Are you hittin' on me?
Originally Posted by BeefCakeScout View Post
I was, but if you won't kiss me after I blow you then i'll find someone else
http://folding.extremeoverclocking.c...e.php?u=317103
77bawls is offline   Reply With Quote
Old 09-01-2008, 06:09 PM   #17 (permalink)
tsrcj7's Avatar
Member # 103461
Sounds like a seal in the turbo
tsrcj7 is offline   Reply With Quote
