short or long - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-07-2002, 11:30 PM   #1 (permalink)
Member # 8717
short or long
is a short wheel base better to tow with or a long wheel base
dually or not?
I see said the blind man
sarge is offline   Reply With Quote
Old 08-07-2002, 11:55 PM   #2 (permalink)
Member # 107
Send a message via AIM to The Jerk Send a message via MSN to The Jerk Send a message via Yahoo to The Jerk
it can be done with a short wheel base but its not fun, th elonger the WB the more stable and comfy it will tow. dullies of course can handle more as well, but a good long bed and or ext cab 3/4 -1 ton truck single wheel will pull just fine, jIMmy
RockZombie:68FJ40 LPG350/sm420/d300/d60/d70
The Jerk is offline   Reply With Quote
Old 08-08-2002, 07:16 AM   #3 (permalink)
Member # 4527
I tow with a crew cab short bed super duty. Granted the extra two doors make the truck longer than a two door, but I've pulled a 24' gooseneck with no problems at all. No problems with bumper-pull trailers either... FWIW.
You might consider what the truck will be used for when you're not towing. Mine is my DD and I don't like the turning radius of the longbed, or the tight squeeze's presented by the dually.
hope this helps!
Ray
[URL=http://www.fun4x4.net]'93 Jeep YJ[/URL] / [URL=http://www.blackhummer.com/powerstroke]'99.5 F350[/URL]
Tx4x4Fun is offline   Reply With Quote
Old 08-08-2002, 09:09 AM   #4 (permalink)
Member # 8211
Ditto what Tx4x4Fun said. I've got a 2500HD crew cab short bed 4x4 Duramax/Allison.
Russ
85 K30 truggy, 350 TBI, TH350, 203/205, D60/C14, 4.56 Locked, 42" TSLs, 4" lift, 112" wheel base, front leafs, rear double triangulated 4 link with coils.
BadDog is offline   Reply With Quote
Old 08-08-2002, 09:40 AM   #5 (permalink)
Member # 8843
Send a message via AIM to offroadr35
same here...CC short bed SRW PSD. The crew cab short bed still has as long a wheelbase as any other configuration other than the CC long bed. i wanted the CC for passengers but didn't need a long bed and didn't want to sacrifice turning radius. Just remember, longer and wider is always more stable. However there comes a point where the advantages gained by going longer and/or wider don't outweigh the consequences.
-Steve
offroadr35 is offline   Reply With Quote
Old 08-08-2002, 12:34 PM   #6 (permalink)
Member # 2752
As far as the dually thing goes, DRW vehicles do have more rear axle capacity if you need that, but they are not more stable for nromal driving. The lateral stability is based on spring spacing, not wheel spacing. You are trying to control body roll on the pavement, and the springs are what does that. The spring spacing on SRW and DRW is usually, if not always, the same. Now if you plan on trying to roll the truck over, it becomes a different story....
86 Samurai w/gun rack, 92" WB, VW 1.9 TD, Toyota 5-speed and dual cases with 4.7 gearset, Toyota axles with Longfields, 5.29's, ARB's f&r, YJ's, 35's, FJ-60 power steering, high steer, .............
Hey, if this rig is for wheelin', what are all these animal parts doin' in here?
Tusker is offline   Reply With Quote
Old 08-09-2002, 01:02 PM   #7 (permalink)
Member # 2071
Longer is better.
I tow with a 4dr long-box one-ton SRW.
No tail-wagging the dog problems... but then, my truck is 20' long end to end, and I tow with a 16' deck car trailer (probably about 20' overall)
Downside is, with a long gooseneck, I wouldn't be able to flat-tow a third rig behind it, for fear of being over-length on secondary roads.
I'm also told with a gooseneck the long wheelbase tow-rig isn't as important, since the gooseneck is more stable to begin with.
So if you want to pull a BIG gooseneck (3 cars?) a single-cab long-box would make a good tractor, and maybe the shorty wouldn't be too bad, either.
-Tom
KE7VUX
tsm1mt is offline   Reply With Quote
Old 08-09-2002, 10:26 PM   #8 (permalink)
Member # 11392
If you go with a crew cab short box you'd be as long or longer than a standard cab long box which was the standard for towing for years. Any of you remember the Ford trailer specials. standard cab long box but the drive axle was set futher to the rear than normal. Those were great for a pull trailer setup.
70~K5 is offline   Reply With Quote
Old 08-15-2002, 07:30 AM   #9 (permalink)
Member # 498
Send a message via ICQ to WheelingPiazza Send a message via AIM to WheelingPiazza
At the ranch we tow with both a 4 door short box(flatbed) and a 4 door long bed dully
Both pull the ball trailers and the gooseneck trails with out thinking about it.
I plan on pulling a trialer or my jeeps with a cab over so I went to a longbox 4 door.
Steve(YES finally got the truck)
KI6PZZ, One of the wheelingpiazzas.
Dysfunctional Rockcrawlers (TDO)
WheelingPiazza is offline   Reply With Quote
Old 08-15-2002, 04:48 PM   #10 (permalink)
Member # 2119
Assuming you are reffering to a standard cab long box or longer, you are fine. I would not try with a standard cab short box or blazer/bronco. They are kinda squirrely and the drivetrain usually isnt sturdy enough(3.08 gears, etc...). Ive heard of alot of people using them but one unbalanced load and you are swearving and jack knifed or rolling on the freeway.
How many licks does it tak.... AWWW JUST SUCK IT
wheelinjp is offline   Reply With Quote
