am i dumb to keep a 1/2 ton?
ok, i have a half ton, reg cab short bed 4x4 dodge, with a 318 auto, 3" lift, and 33" bfg mud. i like the truck alot, it does everything i want it to awesome. Only thing is i woudl like to start towing with it. I dont have a trailer hitch on it, which is why i havent towed with it yet. Only problem is that the truck i want to tow is another reg cab short bed dodge to wheel. could always sell the wheeling truck for a lighter toy or such, but i think the dodge woudl still be just as un-powerful, and unstable on the highway. Just if i sell it, i would want an ex cab cummings.. but i maybe woudl have to buy another reg cab, which i wouldnt want too much. so i dont know what to do.. also, i have already put a new tranny and transfer case into it.. along with head gaskets by the previous owner, so now it is in really good shape, plus, i have too much $$$ into it. SO what shoudl i do?
thanks Garrett |
Member # 8211
Sorry to have to say this, but, IMO, that rig will suck as a tow rig for a full size. Even if you dump more money into it to upgrade it, it is just not the rig to use. I had a quad cab Ram with 360, low gear option, towing package, etc. and it was adequate for towing my K30 buggy on a trailer (about 6-7k with all gear). However, I was concerned about the tranny, especially since I expect to spend allot more time towing the buggy to events that happen to be on the other side of long grades and mountain passes. Dodge autos are not known for robustness when towing, and the 360 was a great engine, but it still would struggle more than I like on a long grade. Can't imagine trying that with a 318 AND tall tires. So, the point I’m getting to is that I traded that truck (which was way better suited for towing than yours) for a 2500HD. Not putting down your truck, sounds like a very nice little multi-purpose rig (with the exception of the 318 which I don’t personally like), but it is not a tow rig at the level you need…
Just my opinion. Good luck
Russ 85 K30 truggy, 350 TBI, TH350, 203/205, D60/C14, 4.56 Locked, 42" TSLs, 4" lift, 112" wheel base, front leafs, rear double triangulated 4 link with coils. |
I'll pretty much second that. Towing a 5500lb trailer was non existant in my truck with the same options as Baddog. 8,000lb I could tell when there was a grade, and the engine worked its ass off. The auto I'm sure worked more. you'll be closer to the 8,000lb range with a light trailer and towing a fullsize. Probably closer to 9,000lbs.
Even if you do keep your current truck you'll need to: Regear to 4.56 3.5" exhaust free flow exhaust 3-4 core radiator Tranny Temp gauge K&N Air filter (always a good cheap add-on) If you like your truck, get a lighter smaller trail rig.
currently i have 2 tranny coolers, a B+M tranny temp gague, 3.55 gears (need 4.56), a K+N filter, 3" rancho lift, doubble rs9000's up front, singles in the rear, 15x8;s, 33x12.5 muds, 2.5" free flowing exhaust (catsound cat, and magnaflow muffler), mopar performance a-518 od tranny, etc. If i were to tow with it, i would be looking into maybe towing a 5th wheel, or gooseneck, on a 18-22' trailer (under 10klbs) or a class V trailer hitch with a weight dist. hitch. I woudl probabalyl also add air bags on top of the springs. WHile l liove the truck, i did just find a 93 cummins reg cab long bed 4x4 dulley with an auto, and 2 car hauler for just a tad more than i can sell this one for, so i am thinking about it.
keep the comments comming. Garrett |
Member # 8211
Yeah, you definitely don't want to use a bumper hitch with a SWB and that much weight/length towed. Goose neck or fifth wheel will help allot but, still…
Russ 85 K30 truggy, 350 TBI, TH350, 203/205, D60/C14, 4.56 Locked, 42" TSLs, 4" lift, 112" wheel base, front leafs, rear double triangulated 4 link with coils. Last edited by BadDog; 08-09-2002 at 10:38 PM. |
it is just how much do i want to daily drive a big tow rig, expecally in bay area and los angles traffic.. but i do hear where you are comming from (makes me wonder how my buddy always tows his horse, and cargo trailers with his half ton chevy)
Garrett |
Member # 8211
I've lived and worked all over the country including big cities. Seattle, Phoenix, and LA to name a few. I don't find that a Ram Quad Cab or Crew GM is a problem as long as it is combined with a short bed and SRW. Now dually, that's another story all together. Sounds like this is the way your planning to go so, just be careful and take it easy. You get on some wavy road with a little curve or too aggressive steering and your going to be in trouble if your not careful… Good luck.
if i get a dulley, will i have problems on back roads? i seem to find them alot, and my ram handles them great.. sometimes forget i am in a lifted truck, until the rear starts comming around. Just i dont like that my 33" dont ever break loose.. but then, i dont think that is bad.
![]() and also, i really want a club cab short bed dodge, if only i could afford it.. maybe one day. |
#12 (permalink) |
Member # 8211
If your talking about narrow roads with a dually then, yes, I've had a considerable increase in "Pucker factor" crossing narrow bridges (and one dam I know of in N. AL is a real PIA) and on narrow roads, especially when you meet another just as big or bigger. If your talking about loosing the back end, then that is also something of a yes. Dual wheels will tend to hydro plane worse without a load and there are other similar problems associated with dual rear wheels when unloaded. Those things are built to tote a load, running empty is a secondary concern. I wouldn’t recommend a dual wheel truck to anyone who doesn’t use it primarily for tow/haul OR if the strictly need the capacity however infrequent. A heavy ¾ to 1 ton SRW with 130”+ wheel base (roughly a standard cab LWB or bigger) will do anything most of us will ever want to do without seriously jeopardizing daily driver practicality, comfort and safety. Heck, I plan on using my new 2500HD on easy scenic runs like local Crown King and such. I’m planning on adding a set of “velvet rides” to take some of the harshness out of the rear springs when unloaded but, with a locked rear and 33s I think it will be capable enough for that stuff. And I *LOVE* driving this thing anywhere. My wife's Bonne has been relegated to her personal "grocery getter", we take my truck (just like my previous Quad Cab Ram) everywhere we go as a family. I’m quite at home with it in town, at the mall (parking lots usually aren’t too much trouble if you don’t mind walking a bit) or on the freeway…
Russ 85 K30 truggy, 350 TBI, TH350, 203/205, D60/C14, 4.56 Locked, 42" TSLs, 4" lift, 112" wheel base, front leafs, rear double triangulated 4 link with coils. Last edited by BadDog; 08-09-2002 at 11:17 PM. |
#13 (permalink) |
Ok, it doesent look like i will be able to sell this truck, so should i A) build it and tow with it, B) Try to keep my junk street legal and work to not break, and carry too many spare parts, or C) tow with my old 77 reg cab short bed 2wd lowered dodge with a 360 auto, 3.23 gears, and 275/60/15 tires?
P.S. if there is a good 89-93 dodge in MINT condition for sale.. pass the info my way. |
