Running power to utility winch on trailer - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 11-03-2008, 12:10 PM   #1 (permalink)
1TonOfSh!t's Avatar
Member # 113803
Looking to put a mile marker 2.5 utility winch on my snowmobile trailer. Question is can I run the power through the 7 pin connector or will the amp draw be too much for the oem gage wire to handle? I'm feeling "no" but i want to hear if anyone has done if before with no problems. Thanks
1TonOfSh!t is offline   Reply With Quote
Old 11-03-2008, 12:24 PM   #2 (permalink)
nissancrawler's Avatar
Member # 76684
Good god, no. I ran 2 gauge to a battery on the trailer, along with a master disconnect in case something went haywire.
You wouldn't need as big of wire, but the dinky wire in the connector won't work.
nissancrawler is offline   Reply With Quote
Old 11-03-2008, 12:31 PM   #3 (permalink)
EricCartman's Avatar
Member # 95696
Do you know the current rating for the winch? I checked on MileMarker.com, and I couldn't find the spec. If I had to guess... I would say it was ~ 58Amps (700w/12V).
That would be way more current than a 7 pin connector could handle.
I've never done this before... but I would think you would either want a battery in your trailer, or some sort of quick disconnect, like the ones shown here: http://www.4wheelparts.com/Winches-W...5148&t_pl=4590
Good luck,
Cartman
EricCartman is offline   Reply With Quote
Old 11-03-2008, 12:46 PM   #4 (permalink)
Member # 1636
You could mount a battery on the trailer and use that power circuit from the 7-pin connector to charge the battery while you're driving.
chris demartini is offline   Reply With Quote
Old 11-03-2008, 12:48 PM   #5 (permalink)
jhama78's Avatar
Member # 3377
Send a message via AIM to jhama78
X2 on this idea.
-j-rOd
[COLOR="Lime"][SIZE="3"][B][URL="http://www.pirate4x4.com/forum/showthread.php?t=654042"]85 Roach Build Thread[/URL] [/SIZE][/B][/COLOR]
[COLOR="Silver"][B]
84 Toy Farm Beater
85 Toy Trail Roach 223:1
85 Toy SR5 xcab DD
88 4Runner Fambly Beach Ride
07 Dodge 2500 4x4 Quad Cab, 5.9 CTD[/B][/COLOR]
[B][COLOR="Lime"][SIZE="4"][FONT="Arial"]Nobody ever lays on their deathbed wishing they'd spent more time at work...[/FONT][/SIZE][/COLOR][/B]
jhama78 is offline   Reply With Quote
Old 11-03-2008, 01:23 PM   #6 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
x3!
nissancrawler, I like your disconnect switch/controller box!!
MT4Runner is offline   Reply With Quote
Old 11-03-2008, 01:24 PM   #7 (permalink)
Soundguy's Avatar
Member # 32677
As long as you wire it correctly because you wouldn't want to try using the winch with that engaged because it'll pull from that wire just like it's doing from the on board batter and smoke the system. You need to have a switch inline so you can break that connection before using the winch.
Soundguy is offline   Reply With Quote
Old 11-03-2008, 01:38 PM   #8 (permalink)
Member # 33456
what about a small "charger" like one on the brake away kit?
Would that work to keep from overloading the 7 pin
massxj is offline   Reply With Quote
Old 11-03-2008, 01:46 PM   #9 (permalink)
Member # 44439
Just wire a relay into the charge wire for the trailer battery. Truck starts, relay kicks in and starts charging. Truck turns off, relay opens and isolates batteries. Just don't winch with the truck running in this case, obviously.
Personally offended by people who think only girls can be sluts
89smurf is offline   Reply With Quote
Old 11-03-2008, 02:04 PM   #10 (permalink)
Soundguy's Avatar
Member # 32677
OR wire a relay into the winch controller which kills the + line from the truck when the forward or reverse button is pressed on the winch controller. That way you can never screw up.
Old 11-03-2008, 02:53 PM   #11 (permalink)
Member # 44439
Ah, touche. I like your idea better.
Old 11-03-2008, 03:02 PM   #12 (permalink)
Member # 86685
Unplug the trailer connector when you winch. problem solved
s10er8 is offline   Reply With Quote
Old 11-03-2008, 03:14 PM   #13 (permalink)
woodchuck2's Avatar
Member # 116651
I bought the 30' jumper cable set up from Northern Tool and cut off the clamps. I wired it directly to one of my batteries and ran it along the frame of the truck and the quick connect hangs next to the trailer plug. The car trailer has a 2500lb winch on it with a 750CCA marine battery and a quick connect harness. If i use the winch i just plug in the quick connect, no problems pulling and i have never had the battery drain down when winching. The little winch can pull on a 4k car single line with no problems. I winched on a 75 3/4 ton Chevy 4X4 loaded with a seized rear wheel but i had 3 snatch blocks. Still pulled it on. Not bad for a $89 Harbor Freight junker.
79 F-150 302,np435, rest of the truck has been sold and is now retired.
woodchuck2 is offline   Reply With Quote
Old 11-03-2008, 03:33 PM   #14 (permalink)
Member # 44439
As simple as that is, I like stuff that's trick. And relays are about as trick as I get
Old 11-03-2008, 05:00 PM   #15 (permalink)
Soundguy's Avatar
Member # 32677
I wouldn't do that, what if you're loading something on the trailer at night on the side of the road? You don't want to have to turn off the running lights to use the winch.
Old 11-03-2008, 05:09 PM   #16 (permalink)
Member # 86685
I couldn't think of a scenario where you would have to have trailer lights while you winch but that is definately one.
Old 11-03-2008, 09:37 PM   #17 (permalink)
Member # 121589
I've got a Mile Marker 8k lb winch mounted on my car trailer that I use to pull draggers and scrap onto the deck. I got a large deep cycle battery in a tool box on the front of the trailer that is charged by the 7 pin connector from the truck. No relays, no switches- 2 years of heavy use and I've never run the battery dead or burned any wires. My drive to the scrap yard charges the battery enough that I can reel in the line the rare times the battery is used often enough to run low. 90% of the time, I don't even run the battery low so that's not really an issue.
For your size winch and the pulling weight of those sleds, I think you'll be fine with a decent sized battery charged by the 7-pin
binksman is offline   Reply With Quote
Old 11-04-2008, 11:31 AM   #18 (permalink)
Member # 44439
What gauge wire are you using for your 7th pin charge wire?
Old 11-04-2008, 05:52 PM   #19 (permalink)
Member # 10379
Would this be easy enuf
with a battery ?
http://www.walmart.com/catalog/produ...ct_id=10339301
"[SIZE=7][COLOR=black]ATOR Sucks !! click link below[/color][/size]"
[url]http://www.pirate4x4.com/forum/showthread.php?t=575873
[/url]
fabricator is offline   Reply With Quote
Old 11-05-2008, 01:57 AM   #20 (permalink)
Member # 76684
I just used a heavy diode. I also put a switch in line, and shut it off when winching. The diode is just in case I forget.
One switch for charging, one for flashers (I can leave my trailer on the road with lights flashing, if need be), one for loading lights I'm putting on the trailer.
Old 11-05-2008, 01:58 AM   #21 (permalink)
Member # 76684
with a battery ?
Maybe, but I would kill that thing the first day I put it on the trailer. I can guarantee a boomer/chain/safety chain/winch hook/something would smack the bitch.
Old 11-05-2008, 12:08 PM   #22 (permalink)
1TonOfSh!t's Avatar
Member # 113803
Over the weekend i found the 12v source in the 7 pin...it's about a 12 gage wire. I thought for sure it was a little thicker than that. looks like i'm runnin wire the length of the truck. thanks anyway guys.
Old 11-05-2008, 01:41 PM   #23 (permalink)
Member # 91648
http://www.andersonpower.com/product...onnectors.html
Easy to mount, easy to use high amperage connector.
Alex.
GMGuy is offline   Reply With Quote
Old 11-05-2008, 03:10 PM   #24 (permalink)
RustoleumWhite's Avatar
Member # 4506
Or just run it off the (car type) battery on the trailer. Toss your charger on it every once in a while.
Whats what I do with mine, mostly cause I have been too lazy to rewire the trailer to charge from the truck or rig up some other means. Only when I've let the trailer sit for a LONG time with no use on the battery (winching etc) without charging it has dead battery been an issue. And for your smaller winch and loads (sleds weigh allot less than a junk car/truck) you should be golden.
I wheel a mean jackstand
RustoleumWhite is offline   Reply With Quote
Old 11-06-2008, 08:53 AM   #25 (permalink)
Member # 22301
how about a dc-dc battery charger? not the cheapest option, but it would work and it's simple.
http://www.powerstream.com/DCC.htm
phillyzj is offline   Reply With Quote
