Member # 3547
Those with big tires and full width axles......
How the heck do you fit it on the trailer?
It seems 83" between the fenders is the max commonly available (across North America from what I can gather)....and I'm guessing that with the std width of fenders - it's because you're then at some legal max width (102"?). Sure - I could have a custom wide trailer or flat deck with no fenders built, but: 1) No way I am ever going to be able to afford a new custom trailer - heck I can;t even afford a new std trailer - i"m looking for used 2) I'm not sure it would be so great having the weight up so much higher on a fenderless flat deck? So - does everyone just drive over the fenders and let the tires hang off the edges a bit?? Seems a bit spooky to me? What am I missing? |
bill search for tubed fenders or somethiing along those lines, i remember a post(think in general4x4) with a pic of someones trailer that they built a tube/pipe thing over the fenders that was strong enough to drive over and then widened the surface of the trailer with flat plate.......... then they drive over the fenders
94 Sidekick buggy, 16L 8v, auto, dual cases, toyota axles, locked, coils, and 36" Swamper TSL's. Last edited by mud-magnet; 08-10-2002 at 08:04 PM. |
here ya go bill, i got board and searched it for ya.......
http://www.pirate4x4.com/forum/showt...railer+fenders simple really, just drive over it........ might want to put a few beads of weld across the top, if its too steep just so it its wet you can still get up it.....
94 Sidekick buggy, 16L 8v, auto, dual cases, toyota axles, locked, coils, and 36" Swamper TSL's. |
Member # 8211
I've got a standard low-boy style car trailer and my rig started out as a K30 that now wears 42s. I take off the driver's fender, drive on with the drivers tire hanging off by about 4-5", just enough to clear the passenger fender (need a spotter to load the truck, sheesh...) and then center it up. My trailer has a side lip that sticks up about 1.5" over the bed. With the tires at low pressure, they bite on it pretty good so I'm not worried about slipping, especially not once it is tied down. Never had a problem...
Russ 85 K30 truggy, 350 TBI, TH350, 203/205, D60/C14, 4.56 Locked, 42" TSLs, 4" lift, 112" wheel base, front leafs, rear double triangulated 4 link with coils. |
Member # 1792
I would build some stout fenders and add to the trailer.Wouldn't be too hard to do.This what my buddy did with his.Actually he bought some diamond plate fenders.It works fine for him.
CJJuggy.FI406/465/205/D60/14bolt FF on 39.5 Swampers.Kids 70Jeepster fullwidth on 34/9.50 swampers. |
I run on a flatbed gooseneck trailer and i have fullsive chevy with 6" lift and 38" and it has no problems i found mine used for $650. There are a couple of good trailers I saw in a classified that is called AG ADS it comes out of Salem, OR its web address is www.capitalpress.com
Kristen 85 chevy, 350, T400, d60, corp 14 -4.56 gears, locked front & rear with 44" boggers 84 Toyota 02 F250 Diesel |
Member # 4073
Very simple and cheap solution to too-narrow fenders. Get a couple 2x8's or whatever, cut them down to increasing lengths, shortest length the same length as the fender. Stack them and screw/nail them together, longest on the bottom and shorter as it goes up till you get to the same height as the fender. Basically making a pair of stair step ramps to get the tires to clear the fenders by going up and over and back down.
......______ ...../............\....fender .....----------- ...---------------..........stacked boards ..------------------ Edit, spaces weren't included in my diagram for some reason.
Dustin S. I had a brain-eating disease that died of starvation. Last edited by Dustball; 08-11-2002 at 09:27 PM. |
Member # 603
Dustball's suggestion is what most do around here. Problem with driving over the fenders, even if they can take it, is that if the tires are wet/muddy, it can make for a really interesting loading situation. BTW, another problem with going over the fenders is if your wheelbase is REALLY short you end up having to park one end of your rig up on them still.
TEX
www.probog.com Thanks to: www.heiseroil.com Extreme Performance www.kmelectronics.com Bear Creek Auto Recyclers www.svrehorsepower.com |
#12 (permalink) |
My short-term solution was to put stock tires on the front of my rig to squeeze between my fenders.. but I got tired of 1) changing tires all the time and 2) welding the fenders back on periodically.
![]() I decided I didn't have time/want to spend the $$ building new full-on fenders, and since the fenders were in decent shape anyways.. I took some 2x2x.120 square tubing and made some trapezoids, just taller and wider than the current fenders. I bolted these to the sides of the trailer frame. I then welded some angle across the 2x2 to make ramps. Not heavy enough angle, so round 2 I put some bracing under the overhanging edges to stiffen 'em up, and some stand-offs down to the trailer deck. It DOES require 4wd to go over the fenders, and with a 100" WB, I still have a few inches to move back n' forth on the deck if I need to. Nice part is 4 bolts per side and the ramps come right off, leaving me with a standard width car hauler to haul stockers around, or autocross rigs, or... In my case, I only needed about 2" per side wider, so I would've had to make the fenders wider to the inside as well to give me something to hit with the tires (hanging the outside 2" of the front tires on a pair of ramps would've been more fun than I wanted), which would've eliminated the trailer for "car hauling" duty.. Once on the deck, the tires do hang over the edges just a bit, but not by much. If I get worried about it, I'll either bend some tube and make some pseudo "nerf bars", or go simple and weld some 2x2 or 3x3 angle to the sides to widen it by 3" per edge.
-Tom KE7VUX |
#13 (permalink) |
Member # 8211
I had thought about doing something similar except using stake pockets and pins...
