Power inverter in Truck???? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-12-2002, 08:17 PM   #1 (permalink)
Member # 7226
Just had a question. i bought a 700watt/1500watt max, power inverter for my truck I have a 95 f250 PSD was wondering how would be the best way to hook this inverter up I am looking to hook it up in my pickup bed, do I hard wire it up to my batteries if so what kind of wire would be the best, do i run a third battery setup whats the best way to hook this up to utilize the most power I am not running anything major of this inverter probably some appliances, TV maybe radio etc. Thanks
Carlos
2000 XJ 5.5 RE, 35 MTR's, Detroit's F&R, M8000
LOS-YJ is offline   Reply With Quote
Old 08-12-2002, 08:47 PM   #2 (permalink)
EMIEVEL's Avatar
Member # 9482
I have one and I love it. Definately hard wire it to the battery, it should have an on/off switch already, right? I used 12 guage wire because I didn't want it getting too hot, but I probably didn't need wire that thick. You're not exposing the inverter to outside elements are you?
If you plan on using it a lot when the truck is off, I would run a deep cycle battery. You can wire it so the altenator charges it, and so it won't drain the truck battery when used for a long time.
EMIEVEL is offline   Reply With Quote
Old 08-14-2002, 09:23 AM   #3 (permalink)
Eskimo's Avatar
Member # 10429
Use one of the power outlets to power a battry charger... perpetual power!!
Rich Q.
FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/ORI's/42's
Eskimo is online now   Reply With Quote
