Using a Durango for towing? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-22-2002, 06:20 PM   #1 (permalink)
XTRMTOY's Avatar
Member # 3309
I'm considering buying a new SUV and am looking at the Durango with the 5.9L. My wife will drive it most of the time and she does not want a full size. That's the reason for the Durango. As big as I can go without going full size.
Anyway... I plan on towing a 4700lb 4Runner on a car trailer (to be purchased). I will try to go with a fairly light trailer. I'm assuming 1500 lbs for the trailer, so this Durango will tow around 6200lbs plus some gear and spare parts. I know Dodge gives a max towing capacity of around 7200lbs, but will it tow this load reasonably well and safe?
Most of my towing trips (5-8 a year) will range between 150 and 600 miles.
Thanks for the opinions.
Mat
XTRMTOY is offline   Reply With Quote
Old 08-22-2002, 07:55 PM   #2 (permalink)
Member # 6579
A few years back I had a Grand Cherokee with the small V8. It toed like a muther. Surprised many on our 23 hour trip to Tellico. Pulled a 4500lb Jeep on an 1800lb trailer with ease. Shocked the others towing with 3/4 -1 ton pickups. I would probalbly put an auxillary cooler for both tranny and engine and run an equilizer hitch. It still makes me smile when I think how that rig ran up those hills in Tenessee.
It's just a Zuk
chevota01 is offline   Reply With Quote
Old 08-23-2002, 12:24 AM   #3 (permalink)
FYRMAN's Avatar
Member # 4358
Send a message via Yahoo to FYRMAN
The Durango screams for an equalizer hitch when you throw a car trailer behind it. They squat real bad and get loose in the rear.
[COLOR="Red"]Central Washington Muff Dive and Rescue Team[/COLOR]
FYRMAN is offline   Reply With Quote
Old 08-23-2002, 08:16 AM   #4 (permalink)
Member # 7163
4700lb 4Runner? I didn't know they could be that heavy.
I'd look into a Featherlite or other aluminum trailer. They weigh in at like 1800 lb or something. How much is a Durango rated to tow? You might need the 2WD to keep weights down.
Edit: 4x2 and the 5.9L is 7550lb.
Edit: CW is 6050 on the 4x2, 6400 on the 4x4.
Bryan
Oxjockey is offline   Reply With Quote
Old 08-23-2002, 08:35 AM   #5 (permalink)
XTRMTOY's Avatar
Member # 3309
Yep! I weighed the runner at the truck scales a couple weeks ago and got 4690 lbs. Of course my runner does have a 350 Chev, TH350, dual tcases, 37" boggers, custom bumpers, custom nerfs, and a full roll cage. And actually that weight is without a top and rear glass.
I just cheched and the max recommended trailer weight for the 4x4 Durango with the 5.9L and 3.92 gears is 7300lbs. I'll be ok from that point of view. I'm more concerned if it will have enough power, what braking will be like and how stable it will be.
Mat
Old 08-23-2002, 08:42 AM   #6 (permalink)
Member # 7163
With a brake controller and good electric brakes you'll be fine. Sway away and good rear antisway bar will be in order if there's a problem.
Bryan
Old 08-23-2002, 10:35 AM   #7 (permalink)
Eskimo's Avatar
Member # 10429
I don't get it... everyone says don't tow with a 1/2 ton truck, like a Ram 1500, and then tells someone to tow with a 4-door Dakota (AKA Durango), smaller than a 1500?
JMHO, I'm guessing it'll be SLOW going up the mountain passes, better have brakes on both trailer axles to stop (since the trailer & load will weigh as much or more than the tow vehicle), and the tranny won't like it much at all.
Wasn't there a special on TV about a year ago that many SUV's are close to their max GVWR with just 4 average people in them, and not much else?
I'm shying away from a Tundra tow rig (rated 7100lbs towing) for this reason.
My rig is around 5000lbs + trailer. Going oil-burner.
Rich Q.
FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/ORI's/42's
Eskimo is offline   Reply With Quote
Old 08-23-2002, 04:32 PM   #8 (permalink)
GRMhick's Avatar
Member # 87
Location: I live in hotels tear out the walls I have accountants pay for it all
Send a message via AIM to GRMhick
i looked into them. they have the power, but they are narrower than a fullsize, and they squat BAD. i would put a load equalizing hitch on it, and maybe some air bags over the springs. anything to get the rear up, because i see them towing and they sway bad..
GRMhick is online now   Reply With Quote
Old 08-24-2002, 01:08 PM   #9 (permalink)
BigDan's Avatar
Member # 745
I would stay away from the 5.9L powerplant. Its the last model there making them, the desighn has been aroung for 20+ years and is really outdated. Wait a month or so and get the brand new 5.7L "Hemi" its hat 320+ HP and is a "next generation" engine. The old dinosaur 5.9L only has 10 more HP then the new 4.7L dodge and mercedes-benz designed engine 3 years ago. It won engine of the year a few years back. So IMHO WAIT for the new 5.7LHemi.
I actually drove a 02 1500 ram with the 5.9L and I WAS NOT impressed, I walked away and bought a CUMMINS...but that is a whole other topic
1979 Toyota LS1, TH400, Stak 3 speed, D60/14 Bolt, 42" IROK's
BigDan is offline   Reply With Quote
Old 08-24-2002, 02:58 PM   #10 (permalink)
XTRMTOY's Avatar
Member # 3309
I've put the Durango purchase on hold for a month or two untill I can find out what the 2003 model will be like and if it will have any changes. According to the dealer I talked to, no changes for 2003. I have a feeling the Durango will get a redesign and hopefully the new 5.7L in 2004. I guess we'll see.
Anyway, I may be getting a new F150 as a company vehicle. I should find out mid September. If that happens, I'll just use that for towing the 4Runner.
Mat
Old 08-24-2002, 06:49 PM   #11 (permalink)
GRMhick's Avatar
Member # 87
yeah, the 5.9 is an older motor, but then so is the 350 that eveyone is using. I have a 5.2, and almost bought a 5.2 durango, IMO, the 5.9 durango with 3.92's will have plenty of power, i really like them, but i guess it is just me.
Old 08-27-2002, 08:43 PM   #12 (permalink)
Member # 977
I had a Durango and it squatted like crazy towing my zuk on a small light trailer...loved it for everything else. You'll need airbags or something.
eXtreme web-wheeler!
scwafish is offline   Reply With Quote
Old 08-29-2002, 05:49 AM   #13 (permalink)
TEX
Member # 603
Buddy of mine tows a 25' travel trailer with his 5.9 Durango. I had to make a Bonzai run up to get his trailer for him a couple of weeks ago 'cause the Durango broke down. Motor's shot, he figured the tranny would go first (me too actually). At any rate, his trailer was clearly lighter than what I tow - '80 Toy Longbed on 16' trailer. And he says it pushes his Durango all over the road. He's looking at 8600 GVWR crewcabs as a replacement.
TEX
www.probog.com
Thanks to:
www.heiseroil.com
Extreme Performance
www.kmelectronics.com
Bear Creek Auto Recyclers
www.svrehorsepower.com
TEX is offline   Reply With Quote
Old 08-29-2002, 08:30 AM   #14 (permalink)
GRMhick's Avatar
Member # 87
Yeah, i have heard of a few engines going out at 35-40k miles in durangos, but not in rams Never quite understood that. Maybe that is one of the reasons why i bought a 4 runner insted of the durango.
Old 08-29-2002, 08:35 AM   #15 (permalink)
TEX
Member # 603
Owner of our local tire shop had his crap out at 37k in a Ram. My buddy's was at 66k. My dad's '94 5.9 Ram has 115k and is fine. Two trannies though
TEX
www.probog.com
Thanks to:
www.heiseroil.com
Extreme Performance
Old 08-29-2002, 08:38 AM   #16 (permalink)
Member # 7163
I like the power I had in my 5.9L, but it pinged like a bitch and ran hot - constantly. I just ran plus and dealt with it. I was also on my second tranny at 100k miles when I traded it in...before I got a third!
Bryan
Old 08-29-2002, 10:13 AM   #17 (permalink)
Member # 4878
Send a message via ICQ to Travis Waldher Send a message via MSN to Travis Waldher Send a message via Yahoo to Travis Waldher
The 5.9L Magnums:
At least my 96 REQUIRED 92 Octane, any less and it would ping, almost idling. It does say premium required on the dash.
It has been running warm lately.. can't find the cause, thinking free flowing exhaust and 4 core radiator may cure it. But, I would rather find a bigger rig.
Travis Waldher is online now   Reply With Quote
