Flat tow t-18 & D-20 combo - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-05-2002, 09:22 AM   #1 (permalink)
Member # 412
Did a search and could not find what I was looking for. Dose anyone know if I need to disconnect drive lines if I am flat towing my Jeep with a T-18 and D-20 combo? D-20 has the tera-low kit not sure if this makes a difference or not. Thanks!
WWW.RPS4WD.COM
RYSYJ is offline   Reply With Quote Quick reply to this message
Old 09-05-2002, 12:56 PM   #2 (permalink)
Keith Strong's Avatar
Member # 477
Send a message via Yahoo to Keith Strong
Nobody flat tows a D20?
[CENTER][SIZE="5"]
[/SIZE][/CENTER]
Keith Strong is offline   Reply With Quote Quick reply to this message
Old 09-05-2002, 06:33 PM   #3 (permalink)
Member # 117
Send a message via ICQ to jonscj7
Leave the trans in gear, put the trans case in neutral and hope it spins enough oil to lube it. Best bet is to remove the rear drive like from the rear end then just tie it up and remove the caps just to be safe.
Jon
67' Blazer?? narrowed 11", 454 TBI,TH400,203/205. D60, D80: 37 spline, discs 42's
jonscj7 is offline   Reply With Quote Quick reply to this message
Old 09-15-2002, 03:00 PM   #4 (permalink)
Member # 1087
I flat tow mine all the time
I even have a turbo 350 auto.
What I did was put a Warn full floater kit in the rear and I just twist the hubs to free,leave the trans in park and off I go.
vingerroon is offline   Reply With Quote Quick reply to this message
Old 09-15-2002, 04:44 PM   #5 (permalink)
CrazyHorse's Avatar
Member # 3420
Send a message via ICQ to CrazyHorse Send a message via AIM to CrazyHorse
you have to pull the driveshaft for a dana 20 t case, as they won't lube the output in neutral...
John Foottit 70 Bronco Buggy
Contact me about Custom Cabinetry www.beniciacabinetry.com
CrazyHorse is offline   Reply With Quote Quick reply to this message
Old 09-15-2002, 06:59 PM   #6 (permalink)
CSP
Member # 1533
That's the Dana 300 that has that problem, not the 20. As someone else said leave the tcase in neutral and the tranny in gear. You'll be fine. A friend of mine has been towing his Dana 20 equipped '79 for over ten years like this with no problems whatsoever. Trips range from 150 to 600 miles at a time on this rig also.
CSP is offline   Reply With Quote Quick reply to this message
Old 09-18-2002, 10:59 AM   #7 (permalink)
michigander's Avatar
Member # 8402
I've always put both my T18 and D20 in N, should I leave the the T18 in gear? Does it make a difference?
Inviscid Motorsports #9009
Thanks to; Ironman Offroad - Motorcity Machines - Branik Motorsports
michigander is offline   Reply With Quote Quick reply to this message
Old 09-18-2002, 03:19 PM   #8 (permalink)
CrazyHorse's Avatar
Member # 3420
no, that's the dana 20 too, I fried two output shafts flat towing (shafts turned blue from the heat, and then fractured) with the t case in neutral, then was informed of the requirement to remove the driveshaft when flat towing, and haven't lost one since... Of course now I tow on the back of a gooseneck trailer...
