5th wheel to bumper pull adapter?? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-25-2009, 04:52 PM   #1 (permalink)
Member # 78722
I have a GN trailer, that I tow with my pickup, but I want to tow it long distance's with my motor home (tag style hitch) is there anyway of converting it, and swithching it back & forth???
Doug H is offline   Reply With Quote Quick reply to this message
Old 08-25-2009, 09:44 PM   #2 (permalink)
1962 YellowSubmarine
YellowSub1962's Avatar
Member # 1494
I've seen adapters on farm type trucks, but I don't know how good they are for long high speed hauls.. I know there was a contraption out there with wheels on it to do exactly what you're talking about, but I think you could buy a bumper pull trailer for what it cost. There was a thread on it in this forum a while back.
Are you sure your MH is rated to tow the weight you're talking about?
Peter S. Di Primo - Waterjet, laser, metal forming, CNC work, Fiberglass and Carbon work, patterns and molds. No job too small.
Prototyping and small production is our specialty, but we have the network to handle large jobs as well.
Email me if you need something cut, bent, formed, milled, machined, etc.
Help Fight Global Warming- turn your A/C on high and open all your windows.
Alcohol, Tobacco, and Firearms should be a convenience store - NOT a government agency!!!!
YellowSub1962 is offline   Reply With Quote Quick reply to this message
Old 08-25-2009, 09:47 PM   #3 (permalink)
Member # 69410
Send a message via AIM to 1stgenxxx
......use a diferent tralier
89 x-cab 40"s sbc/th350/205 RIP
01 Rattle box, 98 Cherocar
1stgenxxx is offline   Reply With Quote Quick reply to this message
Old 08-25-2009, 11:32 PM   #4 (permalink)
jasonmt's Avatar
Member # 3236
$5k+ for a "Tow Buddy" seems like a good reason to buy a different trailer.
http://towingdiversity.com/id2.html
[QUOTE=Roxywheels]The trolls always out themselves :laughing: :roxy:[/QUOTE]
jasonmt is offline   Reply With Quote Quick reply to this message
Old 08-25-2009, 11:55 PM   #5 (permalink)
Member # 11484
What's a regular used single axle (jeep) converter worth?
Pretend you could bypass the brakes and the pins/plates were the same size;
MR4WD is offline   Reply With Quote Quick reply to this message
Old 08-26-2009, 12:39 AM   #6 (permalink)
jasonmt's Avatar
Member # 3236
$1k or under, a 2" kingpin is pretty standard but a single axle "A" converter dolly is going to weigh in at or above 2500#'s.
Old 08-26-2009, 01:50 AM   #7 (permalink)
Member # 138487
I built two miniature versions of a semi-truck converter dolly over the years for customers.
One was for a guy who wanted to pull a 3 horse slant trailer behind his diesel pusher motorhome (borrowed from a family member). I built the frame out of mainly 3x5 structual channel and installed a 7000 lb brake axle and set it up with an adjustable height 2-5/16 coupler. Decked it out with two aluminum diamond plate skins to cover up all the ugly plus a toolbox and aluminum rims that matched the trailer
The other was for a guy who delivered new trailers from the factory to dealers who was hauling a pair of gooseneck stock trailers at once. Used the same basic design but lightened it up a bit and the trailers were new and always empty. Used a 5200 lb brake axle on this one and it was pretty well basic as could be
Needless to say I didn't charge 5 grand like that tow buddy deal somebody posted a pic of but it neither of them was much more than a bumper pull trailer and store alot easier than an extra trailer in your driveway. If you have the means to fabricate one yourself, you'd be even better off as you wouldn't be paying the labor and overhead to have a fabricator build you one
1983 Dodge W250: 440 HP big block under the hood sitting on 38.5 Boggers......And it goes on
psycoticredneck is offline   Reply With Quote Quick reply to this message
Old 08-26-2009, 02:05 AM   #8 (permalink)
Member # 3455
Send a message via ICQ to MoonDog
Whats the legality of one of those things? Would it count as pulling doubles?
Since there is no pivot between that thing and the tow rig, even with the 3 point mounting that they mention on the site, I have a hard time believing it wouldn't bend your hitch up and scrub the tread off the tires really quickly. I can't imagine trying to make tight turns or even back up and maneuver a trailer like mine that has 2klbs of pin weight while trying to slide those tires around that far behind my truck,
'84 Toyota HooptieRunner
MoonDog is offline   Reply With Quote Quick reply to this message
Old 08-26-2009, 07:30 AM   #9 (permalink)
Member # 11484
The tires turn. Ever see a cement truck with a booster axle? Same thing but different.
Old 08-26-2009, 08:37 AM   #10 (permalink)
PAToyota's Avatar
Member # 37600
Send a message via AIM to PAToyota Send a message via Skype™ to PAToyota
Sounds like you need one of these: http://www.pirate4x4.com/forum/showt...php?p=10227335
94 GMC 6.5TD K1500 Yukon SLE / 93 Chevy 6.5TD K2500
85 Toyota 22R RN60 4x4
PAToyota is offline   Reply With Quote Quick reply to this message
Old 08-26-2009, 05:29 PM   #11 (permalink)
Member # 3455
Actually I was wondering about that, but reading reviews elsewhere online says the wheels do not turn
And how do those booster axles work anyway? if they have some kinda caster angle to make them track while going foreward do they still work when backing up?
Old 08-27-2009, 08:30 PM   #12 (permalink)
Member # 11484
Beats me! Page jasonmt. That fuckers an encyclopedia of everything truck related.
Old 08-27-2009, 10:16 PM   #13 (permalink)
Member # 8783
spring assist on the steering to return them to center. the weight on them with the truck turning overpowers the springs though.......... hence they turn with the truck.
1 ton bronco
custom zuk or two
BurnedBronco is offline   Reply With Quote Quick reply to this message
Old 08-27-2009, 10:48 PM   #14 (permalink)
Member # 80052
Send a message via MSN to the_experience3006 Send a message via Yahoo to the_experience3006
The Tow Buddy never used to caster the wheels and they tried to justify it by showing wide spaced tandems on some flat deck semi trailers. I thought it was a poor excuse. Back when I was cruising their site long ago they were talking about releasing a castering version though.
[QUOTE=abig84;9192789]i swear id be gay if it wasn't for all the gay sex that's involved[/QUOTE]
[QUOTE=TexasBlake;10305687]She's not that hot. I was just looking for a quick lay and she all wanted to like go on dates and shit.
[/QUOTE]
the_experience3006 is offline   Reply With Quote Quick reply to this message
Old 08-27-2009, 10:57 PM   #15 (permalink)
jasonmt's Avatar
Member # 3236
A picture is the easiest way to explain, most newer self steering axles have a lock out on the steering mechanism and/or lift up when the vehicle is in reverse. Up here self steering lift axles are becoming more common due to the SPIF regulations coming into effect in Quebec and Ontario:
Old 08-28-2009, 07:29 AM   #16 (permalink)
MattyB4x4's Avatar
Member # 32726
I have seen a goose to bumper pull adapter...let me see if i can find some pics
Toyota buggy - duals + 4.7, 40's, linked rear/fox airs, shift knob
ΜΟΛΩΝ ΛΑΒΕ
MattyB4x4 is offline   Reply With Quote Quick reply to this message
Old 08-28-2009, 08:19 AM   #17 (permalink)
MattyB4x4's Avatar
Member # 32726
ok, i couldnt find anything on google. It was a dump style trailer...but same concept. I do not remember if it was a pintle style or regular hitch hook up, but that shouldnt matter.
Here is my professional artist rendering. Red = trailer, Green = adapter that I cannot seem to find on the interwebs.
ΜΟΛΩΝ ΛΑΒΕ
Old 08-29-2009, 08:26 PM   #18 (permalink)
Member # 13268
Your title says 5th wheel, but your post says gooseneck. Which is it?
But on the day I die, I'll say at least I fu*king tried!!
Motornoggin is offline   Reply With Quote Quick reply to this message
Old 08-30-2009, 06:48 PM   #19 (permalink)
Member # 91648
I think this pic came out of the big dumb load thread;
GMGuy is offline   Reply With Quote Quick reply to this message
Old 08-30-2009, 08:36 PM   #20 (permalink)
Member # 78722
[Gooseneck... I typed it wrong..
QUOTE=Motornoggin;10246061]Your title says 5th wheel, but your post says gooseneck. Which is it?[/QUOTE]
Old 08-30-2009, 09:13 PM   #21 (permalink)
Member # 72000
pssssht! who needs to back up?!
scotty
85 grand waggoneer(what's left of it)
77 scout II truggy
84 chevy home made crewcab
Delightfully Tacky,Yet Unrefined
nightcrawlers is offline   Reply With Quote Quick reply to this message
Old 08-30-2009, 09:17 PM   #22 (permalink)
Member # 72000
you could prolly fab somethin up like your pic,but i question wether its a good idea... i gooseneck has the axles further rearward than your typical bumper pull and has alot more tongue weight.
even with a WD hitch youd need to load stuff further back than normal and id think youd need to beef the hell out of the motor home frame/hitch.
scotty
77 scout II truggy
Old 08-30-2009, 09:48 PM   #23 (permalink)
jasonmt's Avatar
Member # 3236
It is not like it is an impossible task, there are literally millions of trailer combination's out there with 2 or more points of articulation that are successfully backed up on a daily basis.
Old 08-31-2009, 09:07 PM   #24 (permalink)
Member # 138487
you can back one of these up...it just takes a little more thought to do it. I've built two of these over the years for people although the tongue on this one is a bit longer than the ones I built
If I can back this up, anyone proficient at towing can back up single trailer with a converter dolly
Old 09-01-2009, 03:58 PM   #25 (permalink)
Member # 91648
Truck drivers, farmers. Search youtube for backing doubles, and backing triples.
Alex.
