Member # 85104
WD Hitch
I am looking at a Reese Strait Line WD Hitch (1,200/12,000)
Who has one of these Reese WD Hitches? Do you like it? What are some of the pros and cons with going with a WD Hitch vs. Regular hitch?
02 GMC 2500HD 8.1L - Tow Rig 98 Cherokee - Wheelin Rig 88 Wrangler - In progress |
Evil Twin
search been discussed before....
Straight Line w/ dual cam sway control, Love it. Makes a small/light or short truck tow like a champ.. I run 800# bars with ~1200-1500 overall TW. I pull 22' with 135" WB G3500 van, makes it tow great + put some weight on the van. Van is only ~5500# empty and the loaded trailer is more, so it allows me to put ~1000# onto the van (via the ball/hitch/bars). Pro - transfer more weight onto front of tow rig. No sway. Con - 30min for initial setup. Ummm need big socket to tighten bolts? Cost? possibly explain why you are considering one... Also, buy a tongue scale so you can get your tongue weight then mark off your trailer where your high/low points are..
Mike Yager - Jeep TJ Build Up - Ecotec, Toy axles etc.. Ecotec - Technical Info E450 Ambulance VRAY (YAger RV) VRAY 2006 E450 - Ambulance Cummins Diesel Swap |
Member # 85104
Ive wanted to go with one for a while, but never really NEEDED one.
Ive got a chance to get one for a good deal on CL. Ive heard stories about it wanting to pick up the rear tires of the truck if your getting into non even roads. Also, I need to back my trailer into tight spaces alot, which requires me to just about jackknife it getting it in there. Having the WD hitch, and sway control, is it still possible to turn it sharply like this? EDIT: Its going on my 3/4 ton GMC, I dont overload the truck often, but I have gotten close to its max, and I think I would feel more comfortable with sway control and WD
02 GMC 2500HD 8.1L - Tow Rig 98 Cherokee - Wheelin Rig 88 Wrangler - In progress Last edited by drewguere; 09-16-2009 at 04:41 AM. |
#6 (permalink) | |
When I go to the local park 30 minutes away...I dont use the bars or sway control(26 ft enclosed).....but it makes a world of difference with it out on the highway with crosswinds or passing semi's |
Evil Twin
I usually load/unload in the street and do all my maeuvering without the bars on. My tongue is pulled out an extra 12" so I can knife it way over past 90 and with the bars installed they hit anything past say 80deg. It takes 30secs to unclip the pins an unload them... I have a V shaped alum tonge box that i toss all the pieces into.
It looks complicated but its really not. Bottom line you need to HAVE the tonge weight in the first place before you can re-distribute it to the tow rig. If your worried about lifting the rear tires its becasue you don't have enough tonge weight in the first place. This is easy for us to fix by simply rolling your rig up 6-10". But this can be a problem with a camper where you can't easily move several hundred pounds. (and IMHO where much of the bad advice comes)
Member # 76684
Now, please don't take this as dogging WD hitches, I'm not, they definitely have their uses.
The first thing (which I would assume somebody on here is doing) is to have proper loading in the first place. It's amazing how many people think they are a bandaid for piss poor loading. I can't count how many people have came up and asked me how in the hell I could be pulling 7k+ with my half ton without one...and I have zero issues doing so, up to 10k#'s. These same people have vehicles or loads positioned on their trailer so horribly it scares me to think what would happen if one little piece of their wd hitch failed. Again, probably not worth much on this board, and seeing as how you're getting to your limit, I definitely understand wanting one, just putting it out there for others.
[QUOTE=nahmus;9175355]asking chit chat to stop before they are done is kinda like asking piranhas to stop after one bite.[/QUOTE] |
#9 (permalink) | |
Member # 45512
I agree with you but I'm guessing some trailers just aren't big enough to get it just right. My trailer wags if the hitch is too lightly loaded, the truck needs some weight. I can adjust by moving the Jeep, some may need the WD hitch to accomplish this.
'70 Jeepster, 4.3, SM465, toy axles, spring over, etc |
