Ramps - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-26-2002, 05:30 AM   #1 (permalink)
Erik D_lux's Avatar
Member # 1007
Ramps
I am looking to make better ramps on my trailer that either slide in or fold up. I am planning on fabing this myself so basic ideas are good too. Does anybody have some pics that they could show me of a pretty slick set up?
Erik D_lux is offline   Reply With Quote
Old 09-26-2002, 07:05 PM   #2 (permalink)
Member # 7938
I will take some pics of mine tomorrow. I have a dove tail and they slide in from the back.(handy back there)Do you have a dovetail or a flatbed? Most of them I see slide in under the bed on the side.
KS Toy is offline   Reply With Quote
Old 09-26-2002, 08:01 PM   #3 (permalink)
Erik D_lux's Avatar
Member # 1007
I have just a regular flat bed. Right now I have some ramps but there is nowhere to store them on the trailer, so when I drive down a dirt road it is noisy as all hell with them bouncing around. I can pretty much figure out a ramp design, I am just looking for the mounting/storage options. Pics would be great thanks.
Old 09-26-2002, 09:07 PM   #4 (permalink)
Member # 4878
Send a message via ICQ to Travis Waldher Send a message via MSN to Travis Waldher Send a message via Yahoo to Travis Waldher
my ramps just sit on top of my trailer bed under the rig. to solve the rattling problem....
It's called ratchet straps.
Travis Waldher is online now   Reply With Quote
Old 09-27-2002, 07:58 PM   #5 (permalink)
Member # 7938
Mine...
Old 09-27-2002, 07:59 PM   #6 (permalink)
Member # 7938
Close up...
Old 09-28-2002, 11:21 AM   #7 (permalink)
Hillbilly's Avatar
Member # 857
I don't have any pics, but I built mine to fold up and I hate them. This winter I'm going to redo them to slid in at the back like what's posted above.
Hillbilly is offline   Reply With Quote
Old 09-29-2002, 03:37 PM   #8 (permalink)
Erik D_lux's Avatar
Member # 1007
Thanks for the pics. Anybody else have any handy?
Old 09-30-2002, 06:22 AM   #9 (permalink)
Member # 7163
Not a good pic, but mine are the fold up type. They were lengthened by the PO, and they slide side to side on a solid steel shaft to accomodate different width vehicles.
I don't know what the PO did, but they're all tweaked. Fairly solid, too.
Bryan
Oxjockey is offline   Reply With Quote
Old 09-30-2002, 01:18 PM   #10 (permalink)
Member # 8211
Don't have any pics but, mine has what would amount to racks welded under the deck so that the ramps slide in on them from the side. Basically, each "rack" consists of 2 pieces of angle iron welded under the frame so that the horizontal leg of each is on the bottom and pointing across at each other. These are mounted side by side with a hole drilled in the center "wall". I slide the ramps into their racks, where they rest on the angle iron legs, and then use a long loop pad lock through both ramp sides and the hole in the center wall.
Easy to do, and it works well enough. I rarely have to load anything that can’t climb in without ramps (like my rig can), but, when I do, they are there and handy…
Russ
85 K30 truggy, 350 TBI, TH350, 203/205, D60/C14, 4.56 Locked, 42" TSLs, 4" lift, 112" wheel base, front leafs, rear double triangulated 4 link with coils.
BadDog is offline   Reply With Quote
