Member # 480
03 dodge 2500 HEMMI
5.7 LITER 345HP 375lbs torqe .... stock that is the shit to bad it is a dodge
[FONT="Impact"][SIZE="5"]"YOU BETTER BRING SOME CLOROX,CAUSE I CAN'T BE FADED"[/SIZE][/FONT] [SIZE="3"]YOU PUSS YOU SHOULD HAVE TOOK THE HONEY BUN LINE[/SIZE] |
Not really, when Fords new diesel cranks out 325 hp and 550 ft/lbs. I'm sure the Dodge will run well but it's probably lacking in low end for serious towing.
I've got a shotgun, a rifle, and a four-wheel-drive, and a country boy can survive. |
#4 (permalink) | |
Member # 144
That's because you're a pinko fascist. - Haole I know what antidisestablishmentarianist means |
I knew he was talking about the gas hemi. Great top end power, but a lot less torque than a diesel or the other companies gassers. Be a hell of an engine in a half-ton though.
#6 (permalink) | |
you tow where your powerband is! I mean.. .it sounds like your putting down the engine because it doesn't produce its power at 1400rpms. Well.. with a diesel redline around 3-3400 rpms... that is about the equivalent to running a gas engine at 3-4,000rpms. oh yeah... when is the most power being produced in a stock V8 gas engine? Thats right... between 3-4,000rpms. a lot less torque than other companies gassers? man you are so full of shit... comparing small block V8s, which is what the 5.7 is. Dodge hemmi 5.7L V8 - 345HP/375ftlb Ford, 5.4L V8 - 260hp/350ftlb Chevy 6.0L V8 - 300HP/360ftlb GMC 6.0L V8 - 300HP/(Assuming 360ftlb, same as chevy) Hmm... looking at that... I'de say the hemi outpowers them all. hmmm.... Comparing a gas engine to a diesel? well.. thats stupid. yeah.. the diesel will produce more torque than a gas engine. Of course, not everyone needs a diesel, so the 5.7L Hemmi is a good thing. BTW - It sounds like your a Ford biggot... so... I'll have you know. Dodge's new diesel puts out 305HP/555ftlb, up.. thats basically equal to a Ford's diesel. Maybe a little better. Last edited by Travis Waldher; 09-29-2002 at 10:08 AM. |
I stand corrected, if somewhat misunderstood. I saw that as soon as I wrote that, that I would come across as a "ford biggot" Fact is right now all three companies are building good trucks that will undoubtedly get the job done. When I made the comparison to gas engines from other companies what I had in mind were the Ford V-10 and GM 8.1L since thats the competion in the HD truck market. My mistake, comparing apples to oranges though since the dodge is small block, as you pointed out.
Back on topic...When is the Hemi going to be available in the Dodge? I went looking at them yesterday and every single HD I saw was a Cummins.
#8 (permalink) | |
Member # 2632
Stephen |
Member # 745
Man I wish all the HD's I saw were Cummins, all I've seen has been Hemi's. Great gas engine I think its the best one out there(just by the number's) they havent proven themselvs yet. Sure as hell beats the old 5.9L.
1979 Toyota LS1, TH400, Stak 3 speed, D60/14 Bolt, 42" IROK's |
#10 (permalink) | |
Member # 11484
In order to quanitfy your statement, you'd have to list the rpm values that each motor peaked at. |
#11 (permalink) | ||||
Member # 13961
Ford: SAE Net Horsepower 260 @ 4500 SAE Net Torque (lb ft) 350 @ 2500 Dodge: SAE Net Horsepower 345 bhp@ 5400 SAE Net Torque (lb ft) 375 lb.-ft.@ 4200 Unfortunately, this doesn't help us any because i have no idea what numbers the Hemi puts out at 2500rpm, or what the Triton puts out at 4200rpm. (if you want to compare torque anyway) Maybe somebody could get some solid figures on tow ratings? You talk about the Ford 5.4L blowing the new Hemi away with e-prom upgrades and whatnot. Remember something. This is the first year of it's introduction which means there is a shitload of room for improvement in the future. Out of all the literature i've read on the new Hemi, it is severely de-tuned. You can thank the beancounters for that. You talk like the Ford Triton 5.4L is hand built by God or something... Yeah, it's a good engine..but give Chrysler some friggin credit for stepping out ahead of GM and Ford for once, they deserve it. Last edited by intense4x4; 10-01-2002 at 03:58 AM. |
#12 (permalink) | |
Member # 10429
GM 5.3/6.0 are based off the new SMALL BLOCK.. The 8.1, now THAT's the big block. LS1 guys are using the 6.0 block in the F-bodies once they get to the HP level where they need an iron block.
Rich Q. FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/ORI's/42's |
#13 (permalink) | |
Member # 4758
HP is the rate at which torque is produced. Hence the formula for HP, HP=(Torque*RPM)/5250. It's the combination of Torque and RPM that get you up the hill quicker, and that's what HP is a measurement of. |
