Chubby Chaser
Auto Trans Towing Q
So we just got a motorhome that we're using to tow the Cruiser that weighs 4490 pounds. The motorhome is a '98, 24' Tioga with the Ford V-10, and I don't know which trans.
I know the rule was that you always towed with the overdrive off. Is that still the deal, or just when climbing grades?
Eric Anderson TIN BENDERS Hendrix XR Chassis #001 Ultra4 #66 4Wheel Parts, Raceline, PSC, Bilstein, Marlin Crawler, Smittybilt, HendriX, PacificFab, G2 Axle, PAC Spring, G&J, MAXXIS Roxy's in the industry and I'm a sponsored professional driver. The two of us together make a powerhouse. Accepting the things I cannot change. |
Re: Auto Trans Towing Q
I only tow with OD off. The only time I ever drop it in to OD is when I am doing 75-80mph on very level ground, no head winds.
I also don't let the tranny do the shifting. I'll through it in to 1st, 2nd as needed. So far a year of towing an 8,000lb Trailer with a 1/2 ton dodge 360 auto and 3.92 gears. I have had no automatic issues. (and yes.. a diesel is in my future someday when I can afford it) |
Member # 5089
On our 95 Ford F-350 with the auto, I drive with the overdrive ON. I tried it without it and overheated the trans fluid enough were it all puked out. The ford manual says to drive with it on unless, it is hunting for gears. I have drove it over the passes towing the jeep a few times now, and everything is fine. I also put on the biggest trans cooler we could get. I would check the manual just to be sure. (if you have it)
Member # 324
I'm with dusty on this one. I put 180,000 miles on a E4OD in a f250 towing a bunch of heavy loads without a problem. Also i changed the fluid and filter every 25,000 miles. I talked to the guy that has the truck now and it made it to 220,000 before the trans
and he didnt service it after he got it.
Family, Friends, riders and racers, its who we are. |
#8 (permalink) | |
Member # 144
That's because you're a pinko fascist. - Haole I know what antidisestablishmentarianist means |
Eric...
it's got the ford 4R100, it's the same auto in all teh new Super Duty's V8 V10 and PSD's i've towed over 20k on my 2k1 V10 truck in OD changed the fluid at 20k, and was going to do it again but traded it in instead just spend a few bucks and buy a good tranny temp guage (i can get ya some order info if ya want) and don't let it ever get over 190, and change the fluid every 15-20k and she'll be fine... i jsut towed my double car setup to donner and back, 1800 mile round trip, in OD all the way except when it chose to kick down, and i never saw the tranny break 180...
Thanks to the companies that make it happen: Bilstein Shock Absorbers, Trail-Gear, Trent Fab, PRP Seats, Raceline Wheels, PSC, MJ Motorsports |
#10 (permalink) | |
Member # 422
Todd Steele TINBENDERS Formula Toy #006; Thanks to Deaver Spring, High Angle Driveline, Longfields, Rock Buggy Supply, PRP Seats, Marlin Crawler, Coast Motor Supply and RockStomper. [url=http://www.tinbenders.org]TinBenders.org[/url] |
Member # 324
The gauge i had on my auto i got at NAPA. It was mechanical and you just have to drill a hole in the pan and weld a bung on for it. As for temps mine would get up to 260-280 on the really hard pulls for it like hwy 49 between Auburn and Placerville with the gooseneck and 2 rigs on it.
#13 (permalink) |
Member # 324
It made it to 220,000 miles, way above average for an E4OD. Quite often the truck, trailer and load were over 30,000 lbs. I was always told 300 degree was when the life started going downhill fast. There were times when it got over 300 but not often. Kinda interesting was with the truck empty with no trailer at high speed (close to 100mph) the trans would go to 250+
#14 (permalink) | |
RE:todd you got a chevy, now i gotta do my homework i have part number's on a posty on my desk for the 4R100!
#15 (permalink) |
Chubby Chaser
Thanks alot for the input, it really helped
#16 (permalink) |
Member # 582
This is the best info I have.....
And, I've allways felt that anything over 260 deg. is where ATF starts to break down. Synthetics are another chart. Cory Automatic Transmission Fluid Oxidation Automatic transmission fluid will provide 100,000 miles of service before oxidation occurs under normal operating temperatures of about 170°F. Above normal operating temperatures, the oxidation rate doubles (useful life of fluid is cut in half) with each 20° increase in temperature. The approximate life expectancy at various temperatures is as follows: 175°F 100,000 miles 195°F 50,000 miles 212°F 25,000 miles 235°F 12,000 miles 255°F 6,250 miles 275°F 3,000 miles 295°F 1,500 miles 315°F 750 miles 335°F 325 miles 355°F 160 miles 375°F 80 miles 390°F 40 miles 415°F Less than 30 minutes This information clearly shows why transmission oil coolers and the various maintenance intervals are recommended for severe usage. Above 300°F, the metals inside the transmission will warp and distort in varying degrees depending on the severity of overheat. Because this damage occurs and fluid life is so seriously impaired, rocking out of snow, mud or sand should never exceed a very few minutes.
FJ-40 HP 2F SM420, 4:88, Locked F&R, 98" WB, Sawsalled, Welded, dented, 36" SX's, 3spd gears in a 4 spd case, Newfields, Lots of other mods all done by Me... Towed to the trail with a 97 Crew cab 4X4 PSD (slightly improved) |
#18 (permalink) | |
Member # 163
85 runner with some stuff... |
#19 (permalink) | |
Member # 422
#21 (permalink) |
Member # 2243
What was or is the purpose of taking the AT out of OD when towing? Is it because the tranny works harder, heats up and in effect reduces it's like expectancy?
Just the other day I towed a 1/2 ton PU on a double axle wood bed trailer with my 92 W250 CTD and kept the OD off, however after dropping off the 1/2 ton PU I felt confident enough to tow an empty trailer back home with the OD on.
"After all is said and done, a hell of a lot more is said than done." Clark Olmstead |
#22 (permalink) | |
Ford suggests using OD with the power strokes and as long as it's not hunting for gears on the road, use it. My trany converter (with stock program) doesn't lock the converter till in OD, they get hot when unlocked. More so when backing up.
Mike "SpaceGhost" Smythe R U gettin' it? UROC Team #180 running: BFG's 37" Krawlers, Gordon Beadlocks, HP60's, T-Max w/Blue Diamond Rope, Green Filters, Marlin's ToyBox, 3.8 Atlas II, and "I got the shaft from Jesse" but I couldn't have done without Badlands Machine Shop (765-762-2981)! |
