Propane regulators for campers.... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-02-2010, 02:37 PM   #1 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
Is the Propane regulator found inside a camper the same as one you find on a gas grill?
I have a leaky one on the camper and a good one off the gas grill but I don't know if they flow different.
Mark
Old 02-02-2010, 02:50 PM   #2 (permalink)
Member # 89926
If the grill was set up for propane it should be the same. If it was set up for natural gas it would have too small an oriface in it to work properly.
LB
I may be old, but, I got to see all the great bands!
Long Beard is offline   Reply With Quote Quick reply to this message
Old 02-02-2010, 03:04 PM   #3 (permalink)
Not a Wenzelite
MT4Runner's Avatar
Member # 44480
Do the camper ones flow better?
I took one off a grill and put it on my camper, and now my oven pilot won't stay lit if I'm running my furnace.
MT4Runner is online now   Reply With Quote Quick reply to this message
Old 02-02-2010, 03:30 PM   #4 (permalink)
Member # 13384
Send a message via AIM to SolidAxleDurango
They should be the same. 11" WC.
08 Kawa ATVs / 14 AC Wildcat X <- we ride / 07 Ram <- we pull / 12 Keystone Avalanche <- We sleep
SolidAxleDurango is offline   Reply With Quote Quick reply to this message
Old 02-02-2010, 03:32 PM   #5 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
Well, the one I have looks like this.
http://www.campingworld.com/shopping...egulator/26059
I guess it's a 2 stage.
I don't know how important that is or is not.
I guess a BBQ one is only single stage.
Mark
Old 02-02-2010, 03:42 PM   #6 (permalink)
Member # 13384
2 stage = more consistent flow. But really shouldn't matter. Some grill's come with 2 stage even.
Old 02-03-2010, 12:49 AM   #7 (permalink)
Member # 13268
They are NOT the same. An RV runs at 11" WC. That is about 6 oz of pressure per square inch. BBQs will be 10, 20, 30 PSI etc. You must use two stage regulator on an RV, a single stage is illegal.
But on the day I die, I'll say at least I fu*king tried!!
Motornoggin is offline   Reply With Quote Quick reply to this message
Old 02-03-2010, 04:27 AM   #8 (permalink)
Member # 13384
Originally Posted by Motornoggin View Post
...BBQs will be 10, 20, 30 PSI etc...
Unless you're talking smokers, fish cookers, or other high pressure devices....
Most consumer-grade grills you'll find at Lowes/Home Depot run on the same 11" WC (albeit single stage).
Old 02-03-2010, 06:36 AM   #9 (permalink)
Member # 56696
The one off the grill will not keep up on your rv, the furnace pulls some serious flow. You probably want to stay with the two stage regulator. You really don't want to experiment with propane....
80 toyota buggy, 4.3 vortec on 'pane, rmvb th350, yota doubler, linked, coilovers, 44's
bayouhazard is offline   Reply With Quote Quick reply to this message
Old 02-03-2010, 07:05 AM   #10 (permalink)
Member # 72000
could you use a 2 single stage regulartors? one for the stove,one for the furnace?
scotty
85 grand waggoneer(what's left of it)
77 scout II truggy
84 chevy home made crewcab
Delightfully Tacky,Yet Unrefined
nightcrawlers is offline   Reply With Quote Quick reply to this message
Old 02-03-2010, 09:41 AM   #11 (permalink)
Member # 13384
The regulator has nothing really to do with the amount of flow. I've run my home 10K watt standby generator (156,000 btu/hour consumption rate) off of my 20 lb propane tank and regular old grill regulator... Runs fine... Not long mind you, but runs fine.
You could.. But that would be impractical.
I don't know about Motornoggin's commen about using single stage as 'illegal'... I highly doubt there's any law about it.. There is the RVIA which has codes to which RV's are built... But as far as I know compliance is voluntary, as well as membership in the organization. Largely I see it as a self-governing, lobby organization. Given that 98-99% of RVs sold have the RVIA seal on the side, anyone building RVs would be foolish to not want to become a member or comply.
Anyway.. the merit of the two-stage comes when you have multiple appliances with different rates of consumption turning on and off at different times. The two-stage keeps a much more even flow when these events occur.
Old 02-03-2010, 10:07 AM   #12 (permalink)
Not a Wenzelite
MT4Runner's Avatar
Member # 44480
That explains a ton.
Old 02-03-2010, 10:46 AM   #13 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
Great, looks like I am going to try and find a camping store that stocks one now
Mark
Old 02-03-2010, 07:27 PM   #14 (permalink)
Member # 13268
Ok, so I'm not a BBQ pro.
I will find the law.
Shouldn't be too difficult. They are pretty common. If you have a dual tank setup, the RV regulator will allow you to pull from one tank at a time, instead of both at once. If you can't fined one, PM me and I can get one shipped to you.
Old 02-05-2010, 08:13 AM   #15 (permalink)
Member # 75158
I put a bbq one on mine. Runs Fridge, stove, oven, heater with no issues at all.
I had the heat and fridge on, turned on 2 sides of the stove to cooks some eggs and fired up the oven for hashbrowns. No issues what so ever.
I have no idea what the different stages are for. I needed one quickly and the 11WC rating was the same so I tried it.
1989 4Runner SAS on 37"s, dual cases 4.7 rear, Twin stick, 4.88 gears, locker, offroad seats, 4 point harness. Just plain sick!!!!
2002 F-250 Superduty Lifted on 35's
littlyota is offline   Reply With Quote Quick reply to this message
Old 02-06-2010, 12:13 AM   #16 (permalink)
FYRMAN's Avatar
Member # 4358
Send a message via Yahoo to FYRMAN
A two stage regulator knocks the pressure down in two stages. The first stage takes tank pressure down to about 30 psi. Second stage takes the pressure down further, to around 11" water column. That's it. A two stage regulator has abslutely nothing to do with anything else. It is true that they can "only flow XXX number of BTU's". (I put that in quotation marks because someone will argue it, and I don't feel like digging specs up surfing from my phone.) They can only handle so much demand. Don't you dare tell me you can run your big dog generator on one cause I know it won't work. The reason you can't run it long is because you are overworking the regulator and tank, and freezing them up. Single stage regulators are illegal for use on RV's, but you won't find any governing body that would write you a ticket for it. You can bet your ass that the court system would find you guilty if you blew something up and hurt someone.
[COLOR="Red"]Central Washington Muff Dive and Rescue Team[/COLOR]
FYRMAN is offline   Reply With Quote Quick reply to this message
Old 02-06-2010, 01:09 AM   #17 (permalink)
zuking101's Avatar
Member # 36646
For all with single stage regulators on RV's
Heres it is so all can suck a nut......
http://www.rversonline.org/02Propane.html
zuking101 is offline   Reply With Quote Quick reply to this message
Old 02-06-2010, 05:54 AM   #18 (permalink)
Member # 13384
Originally Posted by FYRMAN View Post
...Don't you dare tell me you can run your big dog generator on one cause I know it won't work...
Don't dare tell you? Ok. If the pic had sound, you'd hear it running...
All post installation testing was done using a 20lb grill tank. It's first full hour it ran before we did any load testing. Load tested and auto-transfer switch testing completed as well.
Plumber ended up being scheduled for about a week later to run the natural gas line.
..The reason you can't run it long is because you are overworking the regulator and tank, and freezing them up..
Not the regulator. The tank.
With the tank, full it runs great... As it gets down to about 1/2 full, you can tell. As I understand it, it has to do with the rate of evaporation with the volume of remaining fuel.
Old 02-06-2010, 06:02 AM   #19 (permalink)
Member # 13384
The one off the grill will not keep up on your rv, the furnace pulls some serious flow...
This whole amount of flow conversation is off-topic and irrelevant anyway.
Bayouhazard threw this thread off-track with the above uninformed statement. Someone who says that has no idea about the BTU consumption of RV appliances.
The answer to the OP questions
Q: grill reg - will it work?
A: Yes. It is advisable? Probably not.
Old 02-06-2010, 10:35 AM   #20 (permalink)
zuking101's Avatar
Member # 36646
Hell when I was building my jeep chevy v8 on pane I moved the truck around on bbq tank. It would do fine til I blipped the throttle to about 3K and you would hear the safety valve on BBQ tank go click.
To much flow caused trip (safety valve in case hose shears or something)
The dual regulator is a safety factor so the 11" w/c valve doesnt take all the abuse of load. And yes there is different BTU ranges on these regulators you start exceeding btu loads and you get yellow tipping flames (Deadly) from low water column pressure.
I work with LP daily and would advise not to take cheap road on this subject at all, It can become a life/death situation very quickly.
