Member # 1635
Running a Dana 44 front as a trailer axle?
Has any one hear of this? I was told, by a very good source, that is was common in the 60's and 70's to do this for a home made trailer.
The Dana 44 has to be a king-pin type, and you weld the king pins togher. Guess the hub is why they did this, easy to lube. So, how would the brakes work?
Proud Catholic | My Dana Articles and Info -> http://77cj.littlekeylime.com/web_rs44.html |
Member # 1533
If youre gonna run a 44 don't use a front one for God's sake. Use a rear and forget all the crap about kingpins and welding them together. Gotta be weaker than the 14 bolts you were asking about earlier.
Dana 44 Polisher
Member # 13731
I have seen a lot of homemade trailers and never have seen a front axle used for a trailer. Why would you want to? If your going to go to the trouble of welding the axle solid why not just start with a rear axle?
#4 (permalink) | |
Member # 1635
My knowledge on this is very small, hopefully someone can step up to the plate.
#5 (permalink) | |
Member # 5021
GySgt - Retired
they make trailer hubs that are fully lubed.. with gear oil.. like the semi trailers... you can convert from an older hub.. to those.. they are about 75 bucks.. if memory serves me.. check out some of the trailer stores on line for them.. and be done with it..
besides.. it only takes me about 2.5 minutes to pull my hubs.. and thats with a tire wrench.. and a screw driver... if your that anal.. then use a rear axle... but your deck will be higher since you have the center differential housing there..
Front Toward Enemy 2009, 2011 & 2013 King of the Hammers BUCK Wild Racing Team 911 Degenerate Team 505 Team 488 O.G. "Wreckin' Crew" |
Member # 479
I wouldn't even think of that. If weight is that big of a concern for your trailer, then you need to rethink your trailer. Could you imagine a weld breaking at highway speed? Talk about rear steer!! I am honestly scared by the thoughts (or lack of) that some people have towards their trailer. It's just as important folks as the rig that pulling it or the one that's riding on it. GEEEZ
Kyle Pope |
Member # 1635
The Rockslut: good point. I've seen 14B with rims and ok tires go for $100. Thinking of this route also.
Oxjockey: King Pin Dana 44's are some what common. At least I know teh years to look for. plus no one wants them so they are cheap POPE: Hey, I'm just asking the question The source I heard I trust, so I'm sure it been done. Not saying I'm going this route just wnat to see what people had to say.
