Trailer leaf spring bushings-Upgrade to bronze, or stick with Nylon? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-06-2010, 12:43 PM   #1 (permalink)
Member # 4406
The nylon leaf spring bushings on my 10k tandem axle trailer are toast. Dexter offers bronze bushings and wet bolts (drilled for grease, w/a zerk on the end) that look like they would work. Has anyone tried upgrading from the nylon to the bronze bushings, and was it worth it? Or is this a horrible idea?
Thanks,
Pete
Life should not be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways , beer in hand, body thoroughly used up, totally worn out and screaming "WOW, what a ride."
pcorssmit is offline   Reply With Quote Quick reply to this message
Old 04-06-2010, 01:27 PM   #2 (permalink)
Eskimo's Avatar
Member # 10429
Don't the "big trucks" use bushings like that on their leaf springs? If so, that would seem to be an sign that they last..
FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/ORI's/42's - Sold.
Eskimo is offline   Reply With Quote Quick reply to this message
Old 04-07-2010, 07:00 AM   #3 (permalink)
Member # 4406
I'm not sure what the big trucks use for spring bushings.
Pete
Old 04-07-2010, 07:51 AM   #4 (permalink)
angryblack's Avatar
Member # 142394
Dont know if this will help but what about having some made out of delrin?
I am not familiar with the shape of the bushings but they cant be that hard to make from a solid rod of delrin. Harder than poly but not as hard as bronze.
Maintenance clerk wanted for fulltime work in Food manufacturing. It's a clean refridgerated enviroment usually at 34-40 degrees.
The plant is located in the nj 07004 area. PM me for details.
angryblack is offline   Reply With Quote Quick reply to this message
Old 04-07-2010, 08:33 AM   #5 (permalink)
Member # 132020
The answer is "yes". On the steering axle. Drive axle(s) different story.
spreader is offline   Reply With Quote Quick reply to this message
Old 04-07-2010, 03:35 PM   #6 (permalink)
Member # 4406
Not a bad idea, but I can't see it being "economically feasable" when both the nylon and bronze are available off the shelf.
Pete
Old 04-07-2010, 06:27 PM   #7 (permalink)
angryblack's Avatar
Member # 142394
Thats true, i just dont know the cost of the off the shelf stuff..I had great success with delrin in my sho tuarus.
If i had a cheap Harbor frieght lathe id make leaf spring bushings from it again
I just see bronze wearing out a bit too fast unless you grease often
Old 04-08-2010, 10:54 AM   #8 (permalink)
RustoleumWhite's Avatar
Member # 4506
While I like the idea of bronze and grease I don't know if would be worth it.
The "nylon" last what, 10-years or so, are dirt cheap and super easy to replace. How much longer are you going to get out of the bronze?
If you were a long-hauler, and went through plastic bushings say every year I would give the bronze a try and see how they hold, but for a recreational user I wonder if it would be worth it.
Just thoughts off the top of my head, and one less thing I would need to "maintain" and remember to grease all the time.
I wheel a mean jackstand
RustoleumWhite is offline   Reply With Quote Quick reply to this message
Old 04-08-2010, 01:17 PM   #9 (permalink)
Member # 4406
Thats the conclusion I came to. I wound up ordering new bushings, bolts/nuts, and shackles from etrailer. It came to ~$48, and since I needed to order a new hitch for my truck, I got free shipping since the total was over $150.
As for the cost of just the bushings, they're ~$1/each for nylon, and $4 for bronze.
Pete
