Air bag vs Timbren - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-27-2010, 08:26 AM   #1 (permalink)
Poseur SUV
Paul Gagnon's Avatar
Member # 610
Send a message via ICQ to Paul Gagnon
Air bag vs Timbren
I am getting a Lance model 825 camper and I'm not sure if I'll even need any sort of helper but my RV dealer swears by Timbrens. http://www.timbren.com/ I'd never heard of them before. Are they better than air bags?
Paul Gagnon
Sherwood Park, Alberta eh?
"No Brain, No Pain"
Paul Gagnon is offline   Reply With Quote Quick reply to this message
Old 04-27-2010, 08:46 AM   #2 (permalink)
Member # 125550
airbags would give you more options
different psi for different loads like the camper and then camper plus trailer
03dodgeoffroad is offline   Reply With Quote Quick reply to this message
Old 04-27-2010, 10:58 AM   #3 (permalink)
Member # 130003
Another vote for bags!
Harold Phipps is offline   Reply With Quote Quick reply to this message
Old 04-27-2010, 11:03 AM   #4 (permalink)
Member # 86113
I've got some airbags on my F250, and a set of Timbrens on my wife's 4Runner. I like the Timbrens on the 4Runner because it only hauled one thing - the boat. Didn't necessarily need to make adjustements. I like the bags on the truck because you can adjust depending on what you've got. For you, I would put bags on the truck so that you can add pressure in case you want to pull a trailer, etc.
TexasA&M is offline   Reply With Quote Quick reply to this message
Old 04-27-2010, 01:15 PM   #5 (permalink)
Member # 1418
side note: people use them as bumpstops too
84 4runr influenced by a F-toy and rustbucket cj2a with title, with 22re, ..... Potato V4.0
Kyron is offline   Reply With Quote Quick reply to this message
Old 04-27-2010, 01:52 PM   #6 (permalink)
Member # 71891
timbren: cheaper, simple, reliable,
air bags: more parts, more wires, more plumbing, more adjustable,
95 ford bronco, 351W - one tons, 38's, lockers, no discernible driving ability
93 F250, 7.3T, ZF5
jam0o0 is offline   Reply With Quote Quick reply to this message
Old 04-27-2010, 02:05 PM   #7 (permalink)
Member # 96920
Send a message via AIM to guz71
The timbrens are not adjustable like the bags but they are progressive. I have had mine for while now and I have been happy with them, Ive had 100 to probably about 3000Lb. on them and they have handled everything nicely. I like the fact that they are always ready to go, but opinions on them seem to vary from a vehicle specific stand point.
guz71 is offline   Reply With Quote Quick reply to this message
Old 04-27-2010, 02:23 PM   #8 (permalink)
1962 YellowSubmarine
YellowSub1962's Avatar
Member # 1494
Well Paul, you've seen what I haul with my Firestone Bags and they've done me well. I really like the adjustability of them, and I went with the dual gauge in cab adjustment so I can adjust each bag seperate and on the fly as load dictates or road conditions...
I had absolutely zero issues with mine till KOH this year, I'm pretty sure I hyper extended it like 10 times gettng to where we were camped. Now I have one leaking out the threads in the bottom mounting bolt and I haven't looked at it since. Did TDS and Jambo with a slow leak, but the in-cab controls make it a snap to air back up every 100 miles or so till I can fix it
I'll likely put bags on every tow rig I own from here on out.
Peter S. Di Primo - Waterjet, laser, metal forming, CNC work, Fiberglass and Carbon work, patterns and molds. No job too small.
Prototyping and small production is our specialty, but we have the network to handle large jobs as well.
Email me if you need something cut, bent, formed, milled, machined, etc.
Help Fight Global Warming- turn your A/C on high and open all your windows.
Alcohol, Tobacco, and Firearms should be a convenience store - NOT a government agency!!!!
YellowSub1962 is offline   Reply With Quote Quick reply to this message
Old 04-27-2010, 04:53 PM   #9 (permalink)
250f4life's Avatar
Member # 51984
Another vote for the Timbrens, been thousands of miles in my f250 towing 25k and handles and feels like stock. They are to cheap not to try atleast.
250f4life is offline   Reply With Quote Quick reply to this message
Old 04-27-2010, 05:38 PM   #10 (permalink)
Member # 121245
I have timbrens also on a 02 f250. I like the bolt on and go. I haul a 34ft gooseneck carhauler, 18ft tag , and 32ft travel trailer camper. I'll put them on my next truck if I can wear this one out.
Whiten is offline   Reply With Quote Quick reply to this message
Old 04-27-2010, 07:54 PM   #11 (permalink)
Member # 20983
I love my timbrens for towing heavy. F-250 with a 20ft 12k enclosed, or a equipment trailer 17-18k total trailer wieght. empty you dont even notice they are there. The only part that sux is really small stuff. 400-500 lbs in the bed put the truck almost on the timbrens. Makes the big bumps a little jaring. In my case its a daily driver, weekend buggy hauler. So they are great for me. Simple and gets the job done
Over powered Comp Buggy
ipkyss is offline   Reply With Quote Quick reply to this message
Old 04-27-2010, 09:06 PM   #12 (permalink)
pilothillcrawler's Avatar
Member # 76609
Location: Pilot Hill, CA now Woodland, CA; 1 hour further from the con :(
I have a 2500HD GMC and just put a set of 3500 overloads on. Went to the junk yard and found a set of 3500 springs, took them apart and put the overloads that sit on top of the pack on the top of my 2500HD pack. Also, got the overload bump stops from the yard and everything bolted right up. I like it alot, firmer than they were but not as stiff as my dads 3500 dually.
YJ on custom frame 350 sm465 twin stick Dana 300, 35 Spline 60's f/r, arbs f/r, hydro, on 42" IROKS
pilothillcrawler is offline   Reply With Quote Quick reply to this message
Old 04-27-2010, 10:26 PM   #13 (permalink)
Poseur SUV
Member # 610
Picked it up this afternoon. It actually sits quite nicely. Of course the water tank is empty so the stance will likely change. Right now it is just kissing the back of the overloads. I'll definitely need something when I start to pull a trailer.
Took it to the highway scale tonight and here is what the weights look like (truck and camper only, no people):
Loaded:
front 2230kg/4916 lb
rear 2500kg/5511 lb
total 4730kg/10428 lb
Empty:
front 2250 kg/4960 lb
rear 1460 kg/3218 lb
total 3710 kg/8179 lb
FYI: 2010 F350 with 5600 lb front GAWR, 6900 lb rear GAWR, 11400 GVWR.
It's funny but the unloaded rear axle weight of the truck is 350 lbs more than my entire Mustang.
Paul Gagnon
"No Brain, No Pain"
Old 04-28-2010, 11:17 AM   #14 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
Nice camper Paul!
I run airbags as well.
The bonus with the air bags is it made me install an air compressor on the truck.
Mark
Old 04-28-2010, 02:15 PM   #15 (permalink)
RSWORDS's Avatar
Member # 49595
I love my Timbrens, (I won them on here) never used Airbags but I''m sure they are awesome too.
RSWORDS is offline   Reply With Quote Quick reply to this message
Old 04-28-2010, 03:07 PM   #16 (permalink)
Member # 11921
I have liked Timbrens for their simplicity and price. They work very well. (I have themon my Chevy 2500 (rear) and my Dodge (front), probably will end up with them on all 4 corners of both at some point). Air bags have some nice features but require user input, and I already spend too much time prepping for a trip, so I like to have less.
The in-cab setup is nice but a little spendy and has a lot more parts/potential for problems. I have been keeping the electronics stock on my Chevy for reliability.
My build thread:
ramv is offline   Reply With Quote Quick reply to this message
Old 04-28-2010, 08:59 PM   #17 (permalink)
Member # 86086
Send a message via AIM to three60fish
I think that most of the people on here that are recommending Timbrens are towing something. You are not towing, you are hauling in your bed. I really thing the bags are the way to go. Yes tongue weight affects the back of your truck, but not like an entire camper in the bed does. I think the bags are going to offer you more capacity and adjustability, something that would be better for an in-bed camper.
Short story:
Timbrens-for towing/pulling stuff
Bags-for hauling raw weight in bed
just my $.02; I have bags as I put 3-5k lbs of landscape material in my bed regularly
three60fish is offline   Reply With Quote Quick reply to this message
Old 04-28-2010, 09:35 PM   #18 (permalink)
Well Done Man!
welndmn's Avatar
Member # 398
Paul should also be towing a rig every so often, so the adjustably of the air bags IMO would be better.
I use my camper and town the bronco.
This means I can use different pressures for when I have the trailer on or not.
Mark
Old 04-28-2010, 09:37 PM   #19 (permalink)
89breaker's Avatar
Member # 64213
Bag it and have unlimited flexibility and stability.
89breaker is offline   Reply With Quote Quick reply to this message
Old 04-28-2010, 10:33 PM   #20 (permalink)
Poseur SUV
Member # 610
No, I'm not towing in that picture of my truck at the RV dealer mere minutes after picking up the camper. I will be towing my Explorer.
I also use this truck for work and often travel on gravel roads, oilfield service roads, forestry roads, ice roads and other generally rough conditions so ride quality and suspension travel when empty is important too. The truck rides rough enough as it is (but still a thousand times smoother than my old F250 did), I don't want whatever helper I get to break my back.
Paul Gagnon
"No Brain, No Pain"
Old 04-29-2010, 05:17 AM   #21 (permalink)
Member # 11921
I would totally disagree with 360 fish. Timbrens are most noticable (and helpful) in my truck with a load in the bed or heavy tongue weight.
I don't think either will hurt your empty ride, however you will have to air down the bags.
I think it comes down to your preference. Do you want to fine tune and get the load capacity just right all the time, or do you a prefer a solution that doesn't require any user input and will be adequate, but likely not perfect.
When I am web hauling I feel a need for airbags, but when I am actually working my truck, I don't have any complaints with the Timbrens.
My build thread:
Old 04-29-2010, 05:30 AM   #22 (permalink)
Member # 83301
never run timbrens but have bags in our 3/4 ton. love them. we have a compressor under the hood and we run them empty till its time for a load. i wouldnt be without them. tho timbrens would be sweet for the front during plow season
'79 chevy k30 vortec 350/sm465/205/205/5.13's with big tars and toob
Old 04-29-2010, 08:32 PM   #23 (permalink)
250f4life's Avatar
Member # 51984
Short story:
Id like to see a pic of 3-5k lbs of landscape material in your bed? I mean really 5k lbs is your pinestraw made of concrete?
Old 04-30-2010, 07:37 AM   #24 (permalink)
Eskimo's Avatar
Member # 10429
Seriously? you felt the need to comment on that? Lanscape material can also be packed dirt, concrete pavers, rocks, or any number of other things...
FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/ORI's/42's - Sold.
Eskimo is offline   Reply With Quote Quick reply to this message
Old 04-30-2010, 09:39 AM   #25 (permalink)
Member # 86086
Thanks for the backup eskimo, but I got this one
Who the fuck are you?
This is 1-yard of topsoil with no air in my bags. Do you need me to take another one on monday when I get the 2-tons of screenings for the patio I'm laying as well? Go fuck yourself; unless you were kidding in which you are simply stupid.
EDIT: and here's a link to something citing the approximate weight of a yard of topsoil, I would be happy to show you the receipt from the 2 yards I picked up last wed which would be in the 4-5k range. so again
http://americantopsoil.com/FAQ.htm
Ramv-touche, I do like the idea of not having to mess with anything, I've never used Timbrens so I'd say since they are cheap enough he should probably try those first and see if he is satisfied, then go from there.
