Brake controller hookup - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-16-2002, 08:24 PM   #1 (permalink)
RE:Todd's Avatar
Member # 422
Cool Brake controller hookup
Honest opinion, are they easy to hook up? I've been checking out different install directions, trying to decide if it's worth the $175 to buy and have the controller installed, or if I should do it myself. It seems like they would be easy to fawk up. The vehicle in question is a 97, CC, dually, Chevy, longbed, 2wd.
Todd Steele
TINBENDERS
Formula Toy #006; Thanks to Deaver Spring, High Angle Driveline, Longfields, Rock Buggy Supply, PRP Seats, Marlin Crawler, Coast Motor Supply and RockStomper.
[url=http://www.tinbenders.org]TinBenders.org[/url]
RE:Todd is offline   Reply With Quote
Old 10-16-2002, 10:00 PM   #2 (permalink)
FYRMAN's Avatar
Member # 4358
Send a message via Yahoo to FYRMAN
I will tell you exactly what you need to do when you install a brake controller in 97 Chevy truck..... In about 20 minutes I will start typing... have an answer for you in 30... But yes, you can install a brake controller in your truck in an afternoon, no problem.
[COLOR="Red"]Central Washington Muff Dive and Rescue Team[/COLOR]
FYRMAN is offline   Reply With Quote
Old 10-16-2002, 10:49 PM   #3 (permalink)
FYRMAN's Avatar
Member # 4358
Chit... got a little busy... look here...
I'll try to get something up in a few, but it really is easy.
What controller are they selling you installed for that price?
Old 10-16-2002, 11:48 PM   #4 (permalink)
FYRMAN's Avatar
Member # 4358
The only oddball things you will need are two 8mm nuts to go on the 12+ posts in the fuse box under the hood of the truck. They don't come with the truck, so you will have to find them somewhere. If I remember right, they are fine thread.
Pop the hood and pull the cover off of the fuse box on the driver's side fender. There should be two silver, threaded, posts at the back (firewall) side of the box. Just in front of those posts should be two 30 amp maxi fuses. Pull those fuses and set them aside. You don't want to risk frying anything while you hook chit up.
Under the brake boster will be a bunch of wires taped/wrapped up in split loom. Look for a bundle that seems to just keep folding over on itself. You may see a heavy guage dark blue wire, and a heavy guage orange wire wrapped up in the tape. Pull those two wires loose. Watch your knuckles because they may just "let go" while you are in the middle of a good pull. The tape is going to peel away from the wires and your hands will be a sticky mess, so you might think about a glove, or have some hand cleaner handy to wash off with before you go messin around under the dash of your truck.
The orange wire will have a square ring already attached to it. That wire can just slip over one of the posts on the fuse block. Use one of the 8mm nuts to tighten it down. You will have to drill a hole through the firewall, or find a rubber grommet, to push the blue wire through. I usually just drill a 3/8" hole through the firewall, just to the driver's side of the brake booster. You will see a small circle with a tiny divet between the backside of the under dash fuse box, and the brake booster. Go right through that little divet and you won't hit anything. You might think you have when you hit the back side of the carpet, but unless there is any kind of aftermarket box behind there, you will be fine.
The orange wire you hooked to the post on the fuse box is the battery charge wire. That is a 12v+ source to charge travel trailer batteries, batteries you might use for a trailer mounted winch, interior lights on an enclosed car hauler or utility trailer, etc... That wire will always be hot once you plug those maxi fuses back in. The blue wire you fed through the firewall is the brake wire. That is the wire you will hook to the output wire on the brake controller.
Now you need to use a peice of 12 guage wire to run power from the empty post on the fuse box, through the hole you made in the firewall, and hook it up to the brake controller that you are going to mount under the dash somewhere. I usually mount my controllers down low, and to the right. Just about in the middle of your right shin as you are driving. I drill up into the bottom of the dash, so that if the truck is ever sold or traded, and the controller is removed for use in the next truck, the holes won't stick out like a sore thumb.
Now you have your brake wire and your power wire under the dash. Now you have to find the brake light switch wire that will trigger the controller. *I'm gettin this next bit of info right out of the Tekonsha install manual.*
Your 97 Chevy is special. It is the only year Chevy truck that uses this wire, so anyone else using these instructions will be lost when they look under the dash. As a matter of fact, I have come across 97 Chevy trucks that weren't even like this, so if any of this seems like it's not right, stop and PM me and I will help you find it the best I can. First things first, don't mess with any wires that are held together with yellow clips or yellow tape. Those wires are for the airbag, and messin with those could set it off. You can move them around, but don't disconnect any of them, and don't probe any of them looking for the brake light wire.
*the wire you want*
The convenience center at the firewall just under the emergency brake pedal... Remove 6-8" of tape covering the main loom of 40+ wires. You will find a smaller bundle of wires.
You will find:
  • 5 WHITE wires
  • 4 lights guage wires (16 guage)
  • 1 heavy guage wire (14 guage)
  • Multiple wires wrapped in yellow tape... the ones you don't want to mess with.
Probe the 4 light guage wires with a test light. The wire that is cold until the brake pedal is pushed, and does not flash with the hazard lights is the correct wire. Splice into that wire with a wire tap, then wrap up the rest of the wires.
Take your last wire to the negative side of the battery, or to a good chassis ground, and you are done wiring the controller.
At the back of the truck, on the driver's side frame rail, you will find the other ends of the blue and orange wire taped up against the wire loom. Wire those wires to the appropriate terminals on the plug in the back, and you are damned close to being done.
Straighten up your wires and make everything looks really clean. When you are done you probably won't see where any wires were added or hooked up unless you really look for them. When you are happy with the way things look, pop the fuses back in the the slots that they came out of in the under hood fuse box.
If you need more help, just yell.
Old 10-17-2002, 05:55 AM   #5 (permalink)
Dana 44 Polisher
Member # 13731
I didn't read the above post it ran to long for my tastes but....
The job is a piece of cake - I used to work at a trailer place and install brake controllers all the time. The newer the truck the easier the job usuaulyl went. A lot of the new trucks that came with a 'tow package" (what a joke... but thats another discusion...) have pre wired brake controller connections under the dash - hook up a few wires and you done!
As for messing one up - pretty tough - if you set it up wrong - it will 1) look your trailer brakes and you won't go anywhere 2) Not work at all. 3) Ummm.... I don't know work fine?
Good luck regardless - don't be afraid of electrictiy - you use it to weld don't you!
uglyscout is offline   Reply With Quote
Old 10-17-2002, 01:06 PM   #6 (permalink)
RE:Todd's Avatar
Member # 422
Cool
I printed this out and I'll check it out when I get home. I'll holler if I have more questions.
Thanks
Todd Steele
TINBENDERS
Old 10-17-2002, 03:34 PM   #7 (permalink)
RE:Todd's Avatar
Member # 422
Cool
1 place is a DrawTite 5100 time delay for $175, or $190 for a Tekonsha Sentinal. Another place is the Tekonsha Voyager installed with plugs and all for $175.
Todd Steele
TINBENDERS
Old 10-17-2002, 07:15 PM   #8 (permalink)
FYRMAN's Avatar
Member # 4358
I do the Tekonsha Voyager for $156. Have you decided what controller you are going to use?
Old 10-17-2002, 08:36 PM   #9 (permalink)
RE:Todd's Avatar
Member # 422
Cool
I'm going with the Voyager! One of the sites I looked at said something about a hookup into the check engine socket at the bottom of the dash, left side of the steering wheel. Have you heard anything about that? On Sunday, I'm going to dig through the truck and figure this chit out. I'll PM or post here if I can't figure it out when looking at the rig. Thanks again .
Todd Steele
TINBENDERS
Old 10-17-2002, 10:46 PM   #10 (permalink)
FYRMAN's Avatar
Member # 4358
NO! Don't plug-in anything into the socket. The only thing to be plugged into that socket is a EFI scan tool. You won't get any of the wires you need out of that plug anyway.
In 1999, Chevy started installing a plug like you are talking about for the brake controller, but that was only in certain trim levels of the Silverado. They became even more common in 2000, and virtually every Chevy has them after 2001.
Ford has been using the plug for years now... Since 1992. Dodge has always been hit and miss. Dodge is so messed up, they may have a plug for the brake controller under the dash, but there may not have been a wire runnin back to the bumper of the truck...
Old 10-18-2002, 08:12 AM   #11 (permalink)
Member # 7354
Tundras don't have any pre-wired under the dash. I paid like $221 to get one installed. They sold me the Draw tight 5100, however I would prefer a controller with dials compared to the the little plastic sliders. The slider is hard to modulate, I end up moving it too far in each direction when I wanted to make minute adjustments.
SeanP
If you are not pissed off, you are not paying attention.
SeanP is offline   Reply With Quote
Old 10-18-2002, 09:07 AM   #12 (permalink)
Member # 11392
SeanP
Instead of trying to move the slider try tapping on the side of it. It makes small adjustments easier.
70~K5 is offline   Reply With Quote
Old 10-20-2002, 12:59 AM   #13 (permalink)
Brutpwr's Avatar
Member # 481
Wink
The newer Tekonsha (sp?) brake controllers along with the newer trucks go pretty easy. Just ask to see the operators manuel that comes with the controller. For most vehicles it will be spelled out pretty thoughly--wires etc and where to find them and sometimes references to airbag wires that you don't want to mess with! There are a few (Jeep Grand Cherokee's I believe) in the instructions that say see dealer for details!
Jason
Brutpwr is offline   Reply With Quote
Old 10-21-2002, 02:49 PM   #14 (permalink)
StinkyFab Racing
StinkBug's Avatar
Member # 4946
Hey FYRMAN how much different would those instructions be for a 94 blazer sport (fullsize)? thanks.
Dallas
Dallas Ashley
StinkyFab Racing (SFR) - Custom Fabrication
Your Source for: CNC Cutting & Engraving, Cages, Custom Suspension, Complete Vehicle Builds, and more!
Overall Winner, 2012 KOH EMC. Gettin it done in a stocker!
Co-Dog #4432-KOH 2011 #88-KOH 2010, Crew Chief - KOH 2009, 2008
StinkBug is offline   Reply With Quote
Old 10-22-2002, 08:52 PM   #15 (permalink)
FYRMAN's Avatar
Member # 4358
Dallas
1994 Chevrolet S, T, and Suburban series trucks: The white wire on the cold side of the stoplight switch.
C, K, and G series trucks: The yellow wire on the cold side of the stoplight switch.
Old 10-30-2002, 01:08 PM   #16 (permalink)
oldjeep's Avatar
Member # 3511
Forget the voyager, the tekonsha Prodigy is a piece of art. No screwing with the setup and you can get them for around $175 at www.agri-supply.com
Chuck P
The clowns'? Oh, yeah, the clowns. We fight them too — entire armies, spilling out of Volkswagons. We do our best to fight them off, but they keep sending 'em in!
www.oldjeep.com
oldjeep is offline   Reply With Quote
Old 11-24-2002, 06:15 PM   #17 (permalink)
RE:Todd's Avatar
Member # 422
Cool
FYRMAN, a couple of questions.
The orange wire going to the back, hook in to the 12V or auxiliary connector on a 7 prong??
Should there be an extra green wire from the factory 4 at the tailgate? Is it another ground like the white??
Everything else seemed to work well. I've got the controller installed (Easy with your directions, thanks a bunch), working on the connectore at the bumper. I'm doing the trailer side tomorrow.
Todd Steele
TINBENDERS
Old 11-24-2002, 11:54 PM   #18 (permalink)
FYRMAN's Avatar
Member # 4358
Orange wire will go to the number 4 terminal on a 7 way plug. On a 6 way plug you can put it to the center terminal, or to the "S" terminal.
Chevy should have 5 wires around the back of the truck. White is ground, yellow is left turn and brake light, dark green is your right turn and brake light, light green is your back up light, and brown is the running lights. For a ground, I normally run at least a 12 guage wire right to the frame of the truck with a 1/4" self tapping screw. Call it overkill, but I've seen controllers not work because of a ground wire that was too small.
If you need help with the trailer, I'll be home between 1 and 2 for lunch. PM me if you need to.
Old 11-25-2002, 06:40 AM   #19 (permalink)
RE:Todd's Avatar
Member # 422
Cool
Light green is the backup, okay, should I wire it to the center pole of the 7 prong, or leave it dead ended?? My car hauler doesn't have backup lights.
I put the orange to the #4 connector. (My directions say 12V, don't remember the terminal number but 4 sounds right.)
Thanks again, the directions for the controller were dead on .
Todd Steele
TINBENDERS
Old 11-25-2002, 08:29 AM   #20 (permalink)
FYRMAN's Avatar
Member # 4358
You can put that light green wire to the center. That is what that terminal is for. Alot of people have different ideas on what that terminal is for, so if you put that light green wire there, be careful when you try to back up.
When you step up to that toy hauler RV, it will have back-up lights. Go ahead and put that wire there.
Old 11-25-2002, 10:53 AM   #21 (permalink)
RE:Todd's Avatar
Member # 422
Okay, but I just got done dead ending it in the plug. Blew the turnsignal fuse this morning when I went to backup . I'll do the trailer plug when I get home tonight .
Todd Steele
TINBENDERS
Old 11-25-2002, 07:09 PM   #22 (permalink)
RE:Todd's Avatar
Member # 422
Cool
1 last question, there is a white wire and a blue wire going to the brake axle. I assume the blue is brake controller output and the white returns to ground??
Todd Steele
TINBENDERS
Old 11-25-2002, 07:14 PM   #23 (permalink)
FYRMAN's Avatar
Member # 4358
Trace them both out and see if one of them goes to ground somewhere. Trailer manufactures use different colors for different things.
If I had to guess, I would say that you are right... white for ground and blue for brake.
Old 11-26-2002, 10:41 AM   #24 (permalink)
RE:Todd's Avatar
Member # 422
Cool
They both come out of the hub assembly. My trailer is wired from the factory with a standard flat four and a separate 2 wire connector. The separate 2 wire connector is the two wires for the brake assembly. My thought on this is that the blue should receive brake controller output to the brake assembly, with the white running it to ground after the brake. All of the other wires are accounted for in the plug.
Todd Steele
TINBENDERS
Old 11-26-2002, 01:37 PM   #25 (permalink)
FYRMAN's Avatar
Member # 4358
Cool beans... I thought you were talking about just a couple loose wires for the brakes. If neither of those two wires go to ground anywhere, you can use which ever you want. As long as you get power in and power out, it doesn't matter. I would use the Blue for brake, and the white for ground, just to help the poor dumb slob (guys like me) that gets to work on it down the road. Double up and stub a short wire off of that white wire for a chassis ground, just to be double sure it gets a good ground.
