Enclosed Trailer interior light and stuff wiring? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-04-2010, 07:52 PM   #1 (permalink)
Pook's Avatar
Member # 3370
My enclosed has some interior lights stock, but it doesn't have it own battery so the interior lights only work when plugged in to the towrig. Dumb thing is the marker lights on the truck need to be on and my dodges auto turns them off after a few minutes
I'm thinking I will add an onboard Deepcycle so I can have lights whenever I want, but I also want to wire some other stuff in. I'll make it plug into the RV battery cable wire fromt he tow rig so it charges when driving, maybe add an converter so I can plug in 110v and charge the battery run stuff.
I am an Electrician so I can wire stuff no biggie, but I have never seen what people use as far as panels for power distribution on a trailer before? Are they just using aftermarket 12v fuse blocks or cct breaker setups like delcity sells?
or does someone sell a nice boxed panel ready to go for trailers? I like doing things neat and tidy... I know I can piece my own system together but why reinvent the wheel if there is a reasonably priced part that will speed up the job.
Pook is offline   Reply With Quote Quick reply to this message
Old 06-04-2010, 08:22 PM   #2 (permalink)
Soundguy's Avatar
Member # 32677
If you want something like a real RV you'll need something like this, I'm sure you can find a smaller one if you look.
http://www.dan-marc.com/1-80d.html
It's basically a 12V fuse panel with a 120 volt AC input line that will convert via a transformer to 12V DC and let you run on shore power if you have access plus it'll charge the battery when you're plugged into 120V shore power.
Texas is no place for pine trees.
Soundguy is offline   Reply With Quote Quick reply to this message
Old 06-05-2010, 12:59 AM   #3 (permalink)
Pook's Avatar
Member # 3370
Awesome, Thats what i want. I think my brother might have one in his old camper he is crushing. I better go check it out tomorrow.
If not for $132 how could I go wrong.
Old 06-05-2010, 12:00 PM   #4 (permalink)
Soundguy's Avatar
Member # 32677
I was going to say to look for something out of an old camper, they're pretty basic and you don't need much if you just want to hook up a few lights. Most of them will have a 30 amp 120 VAC input with a couple spots for breakers so you could hook up AC appliances like an air conditioner or microwave.
Old 06-06-2010, 03:50 PM   #5 (permalink)
woodchuck2's Avatar
Member # 116651
I am also an electrician by trade and i installed a marine battery in my trailer with a 2k/4k surge inverter from harbor freight. I tapped the battery into the trailer light circuit which utilizes the full time power circuit at the plug. So anytime the trailer is plugged in the battery is getting charged. I did however have a problem of blowing fuses under the hood when putting a large load on the inverter. I yanked the 30 amp fuse and installed a breaker that automatically resets itself. Be careful of breaker you get as some only reset after the ignition has been shut off, the ones i chose for my trucks automatically reset when they cool even if the load is still present. I can run almost all my power tools off the inverter but i mainly use it for charging batteries.
79 F-150 302,np435, rest of the truck has been sold and is now retired.
woodchuck2 is offline   Reply With Quote Quick reply to this message
Old 06-07-2010, 03:25 PM   #6 (permalink)
Pook's Avatar
Member # 3370
Thanks I'll check into it.
Old 06-07-2010, 03:51 PM   #7 (permalink)
Not a Wenzelite
MT4Runner's Avatar
Member # 44480
Maybe a solenoid on the ignition circuit so you only power the trailer to charge its battery when the ignition on the towrig is on. When you turn the truck off, you run on just the trailer battery? (or is yours already set up like this?)
I have one of those panels connected to the pair of 12V batteries in my Toterhome...but they're the engine starting batteries, and my 12V cooler drug them down stupid low at KOH. I need to add in a deep cycle "coach" battery.
MT4Runner is offline   Reply With Quote Quick reply to this message
