Propane Injected PSD - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-23-2002, 10:42 AM   #1 (permalink)
Member # 10049
I have been checking out a 80HP propane injection kit for my '00 F-350 PSD. Anyone know/hear anything about these?
here is a link to the kits
http://usdieselparts.com/bullydog.htm
Jimbo
pumpkinhead is offline   Reply With Quote
Old 10-24-2002, 09:39 PM   #2 (permalink)
Member # 1599
Location: Indianapolis, IN. Home of the Brickyard 400, Indy 500, and USGP!
Send a message via Yahoo to SpaceGhost
Want the real scoop? Check these links:
DieselStop formerly ford-diesel.com
Diesel Innovations home of some bad ass Strokes
and lastly TS Performance
Not sure what all you have done to your truck but Propane isn't the first mod. Got gauges, intake, and exhaust? Automatics need help too, Sonnax and tricumulator springs, Suncoast Torque Converter. Chips are optional, but get to those links, call those guys, Dennis at TS and David or Chris at DI, they are all enthusiasts and very fast!
My next mod, before propane is a Torque Converter. I can flash past mine with only the intake, exhaust and a bad ass flip chip. When that happens it doesn't shift till you lift. The other advantage of the hp converters is the near lock up when unlocked, the stock unit slips way too much, leaving your shifts soft and lame, and fuel mileage way short.
I have no idea what I'm talking about, my best 1/8 mile time is 9.99 with the coverter mangling the shifts. Thats at 32lbs of boost and no traction (2wd, stock tires) till 3rd gear. That still left soot allover the import bling rides, and was only a little slower than the Lightning.
Enjoy, you have a killer starting point,
Mike "SpaceGhost" Smythe
R U gettin' it?
UROC Team #180 running:
BFG's 37" Krawlers, Gordon Beadlocks, HP60's, T-Max w/Blue Diamond Rope, Green Filters, Marlin's ToyBox, 3.8 Atlas II, and "I got the shaft from Jesse" but I couldn't have done without Badlands Machine Shop (765-762-2981)!
SpaceGhost is offline   Reply With Quote
Old 10-25-2002, 08:05 AM   #3 (permalink)
Member # 10049
Thanks Spaceghost, that is the kinda info I am looking for.
Jimbo
Old 10-25-2002, 08:49 AM   #4 (permalink)
ROCK & ROLL OFFROAD
Member # 3906
Send a message via AIM to Jeepmangled87
My buddy at work has this on his 02 Superduty, and it will smoke the tires really good. He says it seems to have helped quite a bit, he loves his and says its the best things he ever done to his truck.
Jeepmangled87 is offline   Reply With Quote
Old 10-27-2002, 06:08 PM   #5 (permalink)
Member # 7324
an enterprising individual could make a simple setup that really works and is reliable for a fraction of the cost of a kit. i used a 5 gal bbq tank, acetylene regulator, 12v valve, a 4 p.s.i switch total cost about 125$
if the factory would have built it that way, they would have fucking nailed it!
spudwrench is offline   Reply With Quote
Old 10-28-2002, 09:06 AM   #6 (permalink)
Member # 474
Ah, I see a tech article in the making How is the propane metered into the system, or is it like a nitrous system where it only opens the valve when the peddle is to the floor? Any pics/write-up would be appreciated.
Rock on with the RockDogs!
KrustyKruiser is offline   Reply With Quote
Old 10-31-2002, 04:30 AM   #7 (permalink)
Member # 8729
Send a message via AIM to marcutah Send a message via Yahoo to marcutah
interesting conversation, good info here.
91 Tracker 6" Calmini lift 32x11.50 BFG MT TA
Locked rear!
marcutah is offline   Reply With Quote
Old 10-31-2002, 02:44 PM   #8 (permalink)
Member # 3277
cheap propane inj please tell us how!
why say anything if you have nothing to say
90 toy w/ twincamtacopower coilovers tube and stuff
40-O is offline   Reply With Quote
Old 10-31-2002, 06:50 PM   #9 (permalink)
Member # 7324
its very simple, ill try to explain it. i suck at internet so i cant post pics now.
i have a 5 gal tank located in custom mount in gang box on flatbed. gas runs through hose (i got at welding shop) from bottle to acetylene regulater and then 12v valve. the valve cost about 40$ (ill have to dig up the scource for youall) fom there it runs straight into the air duct between filter and turbo. awile back i vented the crankcase to the atmosphere( to keep oil out of intercooler) so i had natural spot to run the hose. i carefully tapped the housing 3/8" npt. and put a fitting there. no orifice or anything, just hose and brass fitting in duct.
i got a cool little project box from radio shack to mount the switch.its black plastic with an aluminium faceplate. i put a toggle switch (napa, no cheap ass plastic switches please) and two indicator lights on it and mounted under dash.
i put a 4 p.si. pressure switch (napa, Hobbs switch, just like used for oil pressure.) on the hose under the turbo. that way when turbo boost = 4p.s.i the switch closes. i tried a foot pedal switch but this works much better. gas only comes on when engine under load, and works with cruise control)
now wire it up so when you flip switch on it turns on light #1 (armed) and sends power to pressure switch on engine. other side of switch goes to ppane valve out back, and light #2 (go baby,go)
set regulator at about 5 p.si and run it. keep turning it up till engine doesnt like it then lower pressure to safe. it takes awile to get it just right, i run a bout 15 or so.
aftermarket kits may be more more precise with with fuel delivery, i dont know, ive never used them. i can tell you this works, its power you can definately feel! ive never cared about mileage so i dont have any numbers for you, but it will improve diesel consumption. egt's dont get that hot, but pay attention to that while going up the cajon pass at 85+ mph.
ican send someone pics if they will post them here for me.
Old 10-31-2002, 06:55 PM   #10 (permalink)
Member # 7324
oh yeah, and dont forget the little chrome toggle switch extension so you can slap it on/ off without looking!
Old 11-01-2002, 08:31 AM   #11 (permalink)
Member # 2800
email them to me at acplaine@pacbell.net - good write-up - thanks
Carpe Diem!
COMPLAINE is offline   Reply With Quote
Old 11-01-2002, 02:35 PM   #12 (permalink)
Member # 2800
Thumbs up spudwrench's pics
spudwrech's first pic:
Carpe Diem!
Old 11-01-2002, 02:36 PM   #13 (permalink)
Member # 2800
spudwrench's second pic:
Carpe Diem!
Old 11-01-2002, 02:37 PM   #14 (permalink)
Member # 2800
spudwrenches third pic:
Carpe Diem!
Old 11-01-2002, 02:38 PM   #15 (permalink)
Member # 2800
spudwrench's fourth last pic:
Carpe Diem!
Old 11-01-2002, 06:14 PM   #16 (permalink)
Member # 7324
hey, thanks COMPLAINE for posting them. the pics look cloudy because i dropped the camera in a creek. i guess you shouldnt do that.
Old 11-03-2002, 07:51 PM   #17 (permalink)
JR2
Member # 13475
Send a message via Yahoo to JR2
I little more expensive than propane...but will make your truck hum and you don't have to carry a propane bottle (aka BOMB) in the back of your truck
www.edgeproductsinc.com/ford_ez.html
Insert signature here...
JR2 is offline   Reply With Quote
Old 12-10-2002, 07:35 AM   #18 (permalink)
Member # 717
Send a message via ICQ to Desert Jeepin Send a message via AIM to Desert Jeepin Send a message via Yahoo to Desert Jeepin
Do you have a source for the valve yet???
Desert Jeepin is offline   Reply With Quote
Old 12-10-2002, 08:21 PM   #19 (permalink)
Member # 7324
i cant find the receipt but im pretty sure it said Meeder Equip Co. look there. ill keep digging.
